29th June 2012, 08:15
#1
m5 imola red
ses codes, where to start??
I just got my codes scanned and this is what they show:
code 72, OA, OF, B9. where do i start?? Is the CPS codes triggering the vanos codes?? Car runs and drives fine. Thanks!!
29th June 2012, 09:57
#2
M5 E39 Supercharged
For me its pointing towards a 'going bad' bank 1 Exhaust CPS mate.
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
29th June 2012, 10:51
#3
2003 BMW M5 TiAg
I see fault codes for both bank 1 and 2 exhaust cps there. Is there any reason why he shouldn't just replace both of them?
"Those who wander, aren't always lost."
29th June 2012, 10:59
#4
M5 E39 Supercharged
Well if it was my M5 then all 4 CPS and Vanos Solenoids etc etc etc, would be new.
The reason I suggest Exhaust CPS B1 is because it is the only CPS code showing in theory.
72 and B9 are relating to the solenoids, and I believe when we see solenoid codes and a CPS code then its a CPS issue.
However if we just saw 71, 72, B8 or B9 on their own with no CPS code then it points towards the Solenoid Board.....all theories of course.
So I am reading his codes as follows 0A along with 72, 0F and B9 .... 0A is the culprit.
The Following User Says Thank You to M5 London For This Useful Post:
29th June 2012, 11:10
#5
2003 BMW M5 TiAg
So I am reading his codes as follows 0A along with 72, 0F and B9 ....0A is the culprit.
Exactly what I wanted to know...
this is why M5board is the most comprehensive automotive forum for any one car.
The Following User Says Thank You to M5erchant M5arine For This Useful Post:
30th June 2012, 18:23
#6
m5 imola red
thanks guys, im going to change all four cps's.
30th June 2012, 19:15
#7
'01 M5 Carbon Black
Another good rule of thumb is to relate it to known maintenance history, expense of various repairs, and research into which codes could be considered "trigger" codes versus which ones are "consequence" codes..Myself, I believe you are on the right path here..CPS are known consumable parts..Vanos boards, solenoids are somewhat problematic, however they also are a little rarer that CPS's…Good Luck with CPS replacement…S
2nd July 2012, 03:18
#8
Banned
bmw
do you used your code reader clear it?
2nd July 2012, 04:37
#9
when I had a CPS code, exhaust side bank 1 i believe, it also threw a Vanos code. Replace the CPS and I've never had the Vanos code again.
01 M5 Anthracite/Caramel
93 Mustang Cobra 31k
96 Accord Shaggin Wagon (beater)
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
