Crankshaft Sensor Error - After New Clutch - Page 3 - BMW M5 Forum and M6 Forums
Like Tree2Likes
Old 30th June 2012, 00:16   #21
FRSpilot
FRSpilot's Avatar
Garage: 2001 M5 Carbon Black
Sorry for my error, when I said dowels, I meant to say they ordered the set that includes some of the other dowels.
How do you know which dowel sleeve is in the right hole?
FRSpilot is offline   Reply With Quote
Old 30th June 2012, 00:46   #22
hairball
Garage: E39 M5
No biggie. I just didn’t want you paying for things that aren’t necessary (even though those dowels are pretty cheap). I replaced mine when I did my clutch job a few weeks back. It's pretty easy to bang those things up with taking off and putting back on the flywheel multiple times, Anyway, just ask your guys to verify TDC (Top Dead Center) of the engine. It's been a long time since I've done this, but there should be a mark on the harmonic balancer on the front of the engine to determine this. I would assume (and others on this board can verify) that the mark on the front of the engine should correspond with the dowel position on the crank? If it was just a few weeks ago, I could have sent you some pictures on this, but my car is all buttoned up.
John
hairball is offline   Reply With Quote
Old 30th June 2012, 00:55   #23
FRSpilot
FRSpilot's Avatar
I called them to see what they found out. He said the new dowel came, and that it only fits in one hole... He was going to measure to make sure. Is that right??
Old 30th June 2012, 01:11   #24
hairball
Garage: E39 M5
I'm not sure about that? Makes sense though. I didn't really look at the size of the holes on the crank to see if one was larger than the others. Would seem logical and better off for you though. One less thing to worry about if they are right.
Old 30th June 2012, 22:47   #25
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
OK,these are the possibilities:
-the cut out for the 2 missing teeth is in the wrong position compared to the dowel pin
-if you have bent teeth,it is easy to set up a dial gauge on the block to measure the flywheel while rotating the crank.
If this turns out to be fine:
-measure the crank signal with an oscilloscope on the sensor and on the pins on the ECU
Report back then we trouble shoot further.
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following User Says Thank You to vantaam5 For This Useful Post:
FRSpilot (4th July 2012)
Old 30th June 2012, 23:10   #26
jfoj
Garage: 2003 M5 Sterling Gray & 2006 330cic (Vert) Silver Gray
Hopefully your problem is something simple where the dowel was tapered by it being put in the incorrect position and someone thought the flywheel was lined up??
Might suggest that before they put the flywheel back in, they put both on then bench side by side for a very close visual inspection.
Like Vantaam5 said, line them up so they are in the same position, with the crank sensor cutout in the same location, say 6 o'clock. Then try to locate the correct dowel hole on the old flywheel, use the dowel to verify fitment, then check the new flywheel to make sure it is in the same location relative to the crank sensor cut out.
I would then suggest marking the correct dowel hole with blue tape or a permanent marker.
Then make sure you find the correct position in the crank where the dowel fits and note the clock position.
Then assemble things knowing exactly where the proper reference is supposed to aligned.
Not sure if you can cheat and use a Voltmeter on the crank signal just to make sure there is a signal in case you do not have a oscilloscope or scopemeter handy.
Good luck.
jfoj is online now   Reply With Quote
Old 30th June 2012, 23:15   #27
jfoj
Another flywheel install problem link that might be useful??
Won't start after clutch install- ideas please
Old 1st July 2012, 00:06   #28
hairball
Garage: E39 M5
I just updated the Vantaam5 clutch / rear main thread DIY with some pictures of the Luk flywheel and dowel markings. Maybe it will help others?
Clutch change DIY with pics
Old 4th July 2012, 00:45   #29
FRSpilot
FRSpilot's Avatar
They did the dial gauge as you suggested and one of the teeth is off on the flywheel by more than a few MM. Is that enough for the car to not start and give a CKPS error?
The flywheel is part of the CNS package I bought awhile back. They seem pretty easy to deal with but I can't speak to them until after the holiday.
Old 4th July 2012, 08:37   #30
vantaam5
vantaam5's Avatar
Very possible that is the issue.
If the tooth is bent a few mm,it has a big impact on the signal,basically like there is a tooth missing.
Crankshaft Sensor Location? NOT CPS... blks4 E39 M5 and E52 Z8 Discussion 13 22nd February 2012 14:32
2 Error Codes (Crankshaft and Camshaft Position Sensor Bank 2 Sensor B) cpatzer E39 M5 and E52 Z8 Discussion 11 27th December 2009 08:08
Replacing crankshaft sensor? Boosted1 E39 M5 and E52 Z8 Discussion 4 3rd March 2009 15:39
Driving to Provence and Crankshaft sensor one of the last E34 M5 Discussion 2 20th April 2006 14:46
