Sticking Thermostat.. - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 25th June 2012, 16:05   #1
rennteknik
Garage: 2000 ///M5
I am posting this for educational value..
it seems when most thermostats fail they fail open.. well mine was sticking closed, and it appears to have been since I purchased the car earlier this year.
my oil temps sat on the 210 line since I had purchased the car.. water temp was always in the middle but straight up and down.
this was what I thought was normal.
I have a evolve tune
about two months ago I started getting some pinging when I accelerated hard, I thought it was a bad tank of gas.
filled up again and it continued.. switched stations and it persisted.. I was starting to wonder if i was getting 91 instead of 93.
then my oil temp started to move past the 210 mark about a month ago. two days after that the water temp gauge finally moved past "normal"
I parked the car and had my friend look at it. water pump was good, fan was good.. he said replace the thermostat.
when i finally replaced the thermostat temps all came back to normal, but I had pinched an oring, so it leaked..
2 attempts later and after pulling the plenum i was leak free and temps where rock solid.
using the functions in the cluster I get the coolant up to 83 degrees celsis and hold it unless I romp on it.. then I might see 85-86 briefly then back down to 83..
the oil temps sit to the left of 210 Fahrenheit and the car no longer pings on throttle tip in
the car is night and day different now. the evolve tune has really woken the car up.. I honestly really didn't notice it initially.. the car has been running hot sit I have owned it.
so if your oil temps seem a little high.. replace your thermostat.. it has made a huge difference in the way my car runs.
rennteknik is offline   Reply With Quote
Old 25th June 2012, 16:21   #2
Casparado
Casparado's Avatar
Garage: '02 E39 M5
My thermostat was sticking open, so I installed a new one. It seemed to be fine for a couple weeks, but then it started happening again! I doubt I got a brand new faulty thermostat. Anyone have any ideas on why my engine might be running cold occasionally? The SES light coming on sometimes is really starting to bother me, but every time I had the codes pulled it is the same thing. Also, the AC fan seems to be running when it shouldn't, if that helps anyone diagnose.
Casparado is offline   Reply With Quote
Old 25th June 2012, 16:24   #3
rennteknik
Garage: 2000 ///M5
bad sensor?
Old 25th June 2012, 18:31   #4
jselig
Garage: 2001 M5
Sales Feedback: (4)
Its these piece of s%-* thermostats. My 4 th one in 2 years just failed again after ~1month.
Im gonna try the E60 one. Totally different brand.
jselig is offline   Reply With Quote
Old 25th June 2012, 18:38   #5
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
I know what you guys going thru, 3 t-stats in 2 yrs. Last one, I did DIY, so far so good.
bimmerule is offline   Reply With Quote
Old 25th June 2012, 18:45   #6
mgdmb
mgdmb's Avatar
Garage: '00 M5 CB Faux S2
Sales Feedback: (3)
p/n on the E60 t-stat? I'm getting ready to be on #3 in 1.5 years...
mgdmb is offline   Reply With Quote
Old 25th June 2012, 19:16   #7
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
How are we diagnosing all these failed thermostats? What exactly are the symptoms you are all experiencing that leads you to this conclusion?
OP - did you put your t-stat in a pot of boiling water and watch it fail to open? If not, how do you know it failed closed?
DouglasABaker is offline   Reply With Quote
Old 25th June 2012, 19:50   #8
rennteknik
Garage: 2000 ///M5
did you read my post?
car was running hot, began to overheat..
water pump and fan clutch where good..
replaced thermostat and car runs cooler and all together better..
Old 25th June 2012, 19:52   #9
mgdmb
mgdmb's Avatar
Sales Feedback: (3)
In my case my coolant gauge was reading too far to the left, and Test #7 confirmed this morning that the temp was running between 75C and 77C, after 15 minutes on the highway @ 80-ish.
The top and bottom radiator temp sensors are new. I'll boil the t-stat once it's out to confirm; then I'll see if I can't get some black powder and 'fix' the old t-stat...
Old 25th June 2012, 20:23   #10
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Did you read his question?
First and foremost your answer does not answer his except to point out you have not diagnosed this correctly.
Do you know that there is a ring gasket inside the T-stat that will grab the t-stat when it is old and worn.
Have you replaced yours? It is called for every time the stat is replaced.
Have you removed the T-stat cover lubed the ring up and seen if the temp becomes normal?
Sailor24 is online now   Reply With Quote
The Following User Says Thank You to Sailor24 For This Useful Post:
jack eiler (26th June 2012)
Sticking brake caliper?? 1bad540 E39 M5 and E52 Z8 Discussion 12 30th August 2011 10:17
Odd Tube Sticking Out M-att E60 M5 and E61 M5 Touring Discussion 4 25th November 2008 19:58
rear brake sticking doc_76544 E34 M5 Discussion 4 11th April 2006 07:10
Pinging and sticking FK coilovers M5ROKIT E39 M5 and E52 Z8 Discussion 11 23rd July 2004 05:28
Sticking throttle? Jim Lamb E39 M5 and E52 Z8 Discussion 6 22nd February 2002 06:52
