Advice on Clutch - Pics included - BMW M5 Forum and M6 Forums
Old 25th June 2012, 00:04   #1
M5_MONSTER
Garage: Supercharged e39 M5, Stock F10 M5
Been running the CNS Dual mass setup on my car for a couple of years, covered around 10,000 miles and clutch started slipping around 2000-3000rpm and also started juddering and vibrating.
I noticed an oil leak so pulled out the tranny and it was the crank seal which has gone. Currently replacing it, but i wanted too get an opinion on the state of my flywheel/pressure plate.
I am replacing the clutch disk regardless as i have a feeling it has soaked in oil, and i do not believe i will fully be able too remove all of the oil.
Im wondering if the flywheel should be resufaced? Also if the pressure plate needs to be replaced or if its ok to run with???
The car is supercharged, and i drive very hard most of the time, but never slip the clutch or ride it.
Attached some pics.
M5_MONSTER is offline   Reply With Quote
Old 25th June 2012, 07:45   #2
Zubehor
Zubehor's Avatar
Garage: E39 M5
Sales Feedback: (12)
those are some serious heat marks on both the flywheel and pressure plate for only 10k miles. once you feel the clutch slipping do you lift or stay on the gas? is the surface still smooth or do you notice groves and imperfections?
i guess try replacing the clutch disk for now and hope it works but i have a feeling you might need a new pressure plate as well.
Zubehor is offline   Reply With Quote
The Following User Says Thank You to Zubehor For This Useful Post:
M5_MONSTER (25th June 2012)
Old 25th June 2012, 08:21   #3
M5_MONSTER
Thanks for your reply. Generally when i feel it slipping i lifted of the clutch but but it has been happening for quite a few weeks so slipped a few times now. The surface isnt smooth, it does have small ridges on the sufaces, not deep, but slight on both the flywheel and pressure plate
Old 25th June 2012, 11:15   #4
con_man
Garage: 2003 Sterling Grey M5
Personally, I would consider that toasted.
con_man is offline   Reply With Quote
Old 25th June 2012, 12:22   #5
Mach5M5
Mach5M5's Avatar
Garage: 2001 M5 Silver
+1
Mach5M5 is offline   Reply With Quote
Old 25th June 2012, 13:13   #6
Mongo
Mongo's Avatar
Garage: e39 M5 Carbon Black 2001
Yup Toast, imo
I would look at it this way...
if that was you brake disc's (rotors) and pads what would you do?
you got to look at time (yours) and part costs added together, say you go with that presure plate and flywheel, box it all up and you have problems the slightest of heat warp on either part and you are now doing a second strip down and replacing anyway
is it worth taking the chance all will be fine seeing as you have the SC and a leadfoot?
Mongo is offline   Reply With Quote
The Following User Says Thank You to Mongo For This Useful Post:
Old 25th June 2012, 13:22   #7
M5_MONSTER
Originally Posted by Mongo View Post
Yup Toast, imo
Totally agree with you on that one mate good advice. If it was the brake disc i would replace, but they are a lot cheaper but nevertheless I will be replacing the lot. I guess i just wasnt expecting too have to replace the whole kit 10,000 miles down the line, but no fault of the CNS kit just down to the oil seal, i should have done the seal originally when i installed the kit. But lesson learnt. Thanks for your advice
Old 25th June 2012, 13:55   #8
rao
Garage: Silver 540i
If an oil leak was causing the slipping the clutch would not show that kind of wear or heat.
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is online now   Reply With Quote
Old 25th June 2012, 14:37   #9
M5_MONSTER
Ok any ideas what would? If the clutch was slipping due to the oil leak, would the slipping not cause this kind of wear/heat?
Old 25th June 2012, 15:04   #10
rao
Garage: Silver 540i
I would bet that either the clutch was overpowered or the pressure plate was not functioning properly. That is showing a lot of heat, and a clutch bathing in oil does not generate a lot of heat.
Here are some pics of a clutch which was seeing a lot of oil (the culprit was not a rear main seal, but something very similar). A moderately high horsepower car with about 7500 miles on the clutch, flywheel and pressure plate.
Bellhousing (that's an oil leak ) :
Clutch disk - no heat, worn from slipping in the oil:
Flywheel - dirty but basically brand new (note you can still see the factory machine marks):
Pressure plate - looking brand new:
Amazingly that car showed very little signs of a problem, but that is another story.
The Following 4 Users Say Thank You to rao For This Useful Post:
chowdah (29th June 2012), herrubermensch (29th June 2012), M5_MONSTER (25th June 2012), Sailor24 (29th June 2012)
Allow me to introduce myself.. Pics included TZ04XJR E60 M5 and E61 M5 Touring Discussion 12 14th May 2011 01:33
**Urgent Advice Needed ** All S38 owners be warned - Dyno Graph Included crazy_199 E34 M5 Discussion 3 26th August 2010 19:26
**Urgent Advice Needed ** All S38 owners be warned - Dyno Graph Included crazy_199 E34 M5 Discussion 7 17th August 2010 16:35
My new M5 ( Pics included ) abood_M5_E60 E60 M5 and E61 M5 Touring Discussion 16 16th June 2006 01:21
My new M5 ( Pics included ) abood_M5_E60 Owners Gallery 7 15th June 2006 17:24
