Help:Multiple problems on the Beast! - BMW M5 Forum and M6 Forums
Old 20th June 2012, 17:54   #1
lehsmann
lehsmann's Avatar
Garage: MY 2000 E39 M5 Oxford Green Metallic
Hi guys,Ok,im gonna try to give as much information on my problems as much as i can to give the board a chance of helping me out:
My car is a '00 Beast with 174000 on the clock,Evolve AlphaN,Power Tune,Headers,decat and straight pipes
Work on the car since i bought it includes new radiator,new coolant pipes,new alternator,new thermostat,water pump,fan,fan clutch,new vanos O-rings.
Car shows only 1 fault (E-box fan)
1uring spirited driving(maybe 10-15 mins of around 200kph)when i stop at the traffic lights i will see a huge puff of white smoke(really really white and its a lot of smoke)
2:The car has a metallic rattle when you stab the throttle but on idle its just quiet BUT also when you accelerate from around 2k in 2nd the you can hear the rattle again till the revs cross 3500 then the rattle quitens down.
3:The car has hesitation when you change from 2nd to 3rd and from 3rd to 4th,jus a bit of hesitation then it pulls.
4:Cars drinks fuel like nobody's business.
Even though i have all these mods,i cant keep up wit a stock '00 and a stock '03 leaves me embarrisngly!
Proposed action plan
I have decided to order new CPS,Crank position sensors,all oxygen sensors(to try to cure the fuel consumption),New fuel pump and see how it goes!
2000 E39 M5 Oxford Green Metallic(DD)
Evolve AlphaN
Evolve Power Tune
Evolve Headers
Evolve IATS
Decatted OEM Exhaust
6000K Angel Eyes
6000K Fog Lights
6000K Low and High Beam
Wanted:Lower Oil Pan(even with stripped bolt threads is ok),DSC Control Module/ABS unit
1988 E30 325i Coupe White(Weekend Toy)
E34 535i Drivetrain
Express Works Suspension
Custom Exhaust
lehsmann is offline   Reply With Quote
Old 20th June 2012, 18:44   #2
desmotesta
desmotesta's Avatar
Garage: 2002 M5 TiAg
I am not an expert but before throwing parts at the car (like CPS and O2) I would try to have the car looked at for the White smoke and engine rattle.
Have you pulled any codes?
Is there a shop nearby that can pull codes?
The engine rattle, hesitation and white smoke are far too serious to be ignored -
02 TiAG M5 - 74K Mls, Matt's latest Alpha-N, Muffler delete, E60 SSK, UUC DSSR, Dinan Strut braces, Dinan Sway Bar
02 Audi A6 Quattro
04 Aprilia RS250 (Race)
90 Honda CB-1 (Wife's race bike)
2004 Yamaha PW50 (son's)
desmotesta is offline   Reply With Quote
Old 20th June 2012, 18:51   #3
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Is the white smoke from under the hood or out the exhaust? Are you using the right coolant/dist H2O mix?
Old 20th June 2012, 18:57   #4
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (4)
+1 on this. Could very well be a head gasket if white smoke is coming out of the exhaust.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
herrubermensch is offline   Reply With Quote
Old 20th June 2012, 23:26   #5
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Please check the compression as i asked you on the phone,mate.
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 21st June 2012, 08:35   #6
lehsmann
lehsmann's Avatar
Thanks for the replies guys.
The CPS and O2 sensors are due for replacement anyway as the ones on the car date back to the factory.
The smoke is comin out from the exhaust only when i stop after hard acceleration,during acceleration and normal driving there is no smoke at all,the smoke behaves like a car with a failed oil separator but iv heard our separators never fail.
The coolant is the one from the dealership and i pour one bottle of coolant then top up with water after radiator flushing!
I have tried to look around town to check if any of the shops can do a compression test but none of them want to mess with the S62.
The car has no codes except E-box fan!Which leads me to believe that the problem is hardware related.Also i think the engine rattle might be caused by old CPS failing to advance the timing quickly enough(but im not a mechanic so im just guessing)coz during idle there is no rattle,it only happens when you accelerate suddenly,then it quietens when the revs reach 3.5k,this only happens mostly in second gear when i try to accelerate hard from low revs.
I'll google the compression test procedure and try to check it with my indy.
Old 21st June 2012, 08:41   #7
mgdmb
mgdmb's Avatar
Garage: '00 M5 CB Faux S2
Sales Feedback: (3)
Compression test:
TECH: How to accurately compression test an S62 engine
mgdmb is offline   Reply With Quote
The Following User Says Thank You to mgdmb For This Useful Post:
lehsmann (21st June 2012)
Old 21st June 2012, 09:16   #8
lehsmann
lehsmann's Avatar
Thanks for the link mate,i have read over the compression test and it seems like something i can do myself,would you happen to have a link where i can get the compression tester specific to our cars?
Old 21st June 2012, 09:19   #9
vantaam5
vantaam5's Avatar
all compression testers are generic,there is nothing special about the equipment and procedure to the S62.
Spark plugs out,remove fuel pump fuse and go for it.
The Following User Says Thank You to vantaam5 For This Useful Post:
Old 21st June 2012, 09:42   #10
lehsmann
lehsmann's Avatar
Thanks Raikku,js saw some on Ebay,so i'll place an order.Jus popped over to Bimmerforums and saw some info that you might need to know to help you guys diagnose my problem better,
-I'm not getting any milkshake colour on my oil cap
-I'm not loosing coolant and in fact i never top up coolant between service intervals
-Car has never overheated(in my ownership anyway)
-Oil consuption is not high at all,top up with only 500ml between service intervals!
Its just white smoke that is evident when i stop after hard acceleration.
Electrical problems on multiple systems inc ABS and Locks DefTechDP E39 M5 and E52 Z8 Discussion 0 28th September 2011 04:11
Problems with the beast moe b E60 M5 and E61 M5 Touring Discussion 3 25th April 2010 04:28
Multiple attempts needed to start the beast! mattw88 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 6 6th April 2010 00:05
Some problems resolved on the beast today Daddy E39 M5 and E52 Z8 Discussion 3 21st January 2006 01:59
More problems with the beast...I really could use some help on this one.... TiAgM5Miami E39 M5 and E52 Z8 Discussion 16 5th June 2003 10:20
