20th June 2012, 18:25
#8
Carbon Black E39 M5
Did you ever post a video/sound clip? I always thought members here advocates stopping driving immediately in case of suspected rod bearing issue. Sounds like horrible customer service but needs to hear both sides of story. Good luck sorting it.
