Window Regulator? - BMW M5 Forum and M6 Forums
Like Tree1Likes
  • 1 Post By Georgia M5
Old 17th June 2012, 17:16   #1
E39_GixxerThou
Garage: 00 E39 M5
Window Regulator?
Hello all,
I think i need to replace the window regulator on my 2000 M5. The motor works and moves the cable, i think the cable has stretched and now my window will not go up all the way and doesnt go down as it should. i pulled off the door panel and can see the mechanism, the cable has developed a kink around the round part where it winds... any idea where i should start, any part # for just the regulator and cable?
E39_GixxerThou is offline   Reply With Quote
Old 17th June 2012, 19:36   #2
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Seems like you need to buy the whole regulator.
Front Left : 51 33 8252393
Front Right : 51 33 8252394
My driver's side let go recently, strands of the metal cable started breaking then jamming up the whole thing !
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 18th June 2012, 01:04   #3
Georgia M5
Georgia M5's Avatar
Garage: 2003 Jet Black M5, 1997 Black 540 Sport, 1997 Black M3 4 door
By the way, you can now buy the parts in the pic (the regulator sans motor) really cheap on EBay. Don't go through dealer.
Georgia M5 is offline   Reply With Quote
Old 18th June 2012, 14:27   #4
E39_GixxerThou
Garage: 00 E39 M5
I need the PASSENGER SIDE REAR! Ive came across a few but im not sure what i need exactly, if someone has a part number please help! thank you ahead of time...
Old 18th June 2012, 14:39   #5
M5 London
M5 London's Avatar
YOU SHOULD HAVE MENTIONED THAT ! One would always assume the fronts have failed due to the fact that they get more use, normally, than the rears !
51 35 8159836
and this is what the left rear one looks like, by the way, and they come with the motor unfortunately, unlike the fronts which you can buy without with motor :
Old 18th June 2012, 15:10   #6
Georgia M5
Georgia M5's Avatar
You can find the rear regulator without the motor on eBay. I've replaced both on my 540 using these parts with no problems.
Fortunately, I've not had to replace them on the M5 yet.
$38
97 98 99 BMW E39 528i 540i window regulator rear RH passenger side | eBay
Search eBay for the part number with no spaces.
Old 18th June 2012, 15:10   #7
E39_GixxerThou
Garage: 00 E39 M5
Nevermind found it!
Old 19th June 2012, 14:24   #8
E39_GixxerThou
Garage: 00 E39 M5
I searched Ebay under that part number and its for vehicles up to 99, my car was built in 2000, i doubt theres a diffrence but can anybody confirm this?
BMW 5 SERIES E39 1999-2003 Window Regulator - Rear Right | eBay
I think that will work for me but i dont need the motor!
Will that work for my car?
Old 19th June 2012, 15:11   #9
Georgia M5
Georgia M5's Avatar
According to realoem.com the parts changed in 1999. Probably because the old design was terrible.
Try:
51358252429 (left rear)
BMW E39 525i 528i 530i window regulator rear left NEW | eBay
51358252430 (right rear)
WINDOW REGULATOR 2002 BMW 5 SERIES E39 W/O MOTOR REAR R | eBay
Make sure you get the versions without motor.
I would email the first seller who is significantly cheaper and highly rated to see why he doesn't sell the right side as well.
Driver's window clunk/regulator problem - new regulator time? doc$holliday E39 M5 and E52 Z8 Discussion 17 23rd November 2011 20:08
Window detached from regulator? greg12m3 E39 M5 and E52 Z8 Discussion 5 17th March 2010 16:53
Window Regulator problem arotished E39 M5 and E52 Z8 Discussion 1 10th March 2010 22:56
Window Regulator DECOCQ E39 M5 and E52 Z8 Discussion 0 25th February 2010 18:11
Fixing Window Regulator? VetteRacer E39 M5 and E52 Z8 Discussion 2 9th May 2007 01:05
