fuel line to fuel pump leaks at fitting - BMW M5 Forum and M6 Forums
Old 16th June 2012, 22:00   #1
l8apex32
l8apex32's Avatar
Garage: Carbon Black M5
I just did a DIY fuel pump swap, 2001 M5. The process is well documented and a good video of the process is on YouTube.
However, my flex fuel line would not leg go of the plastic fitting on the top of the fuel pump assembly. I cut myself pretty good on one finger trying to squeeze and pull and that didn't work. I used pliers to squeeze and pull, and that did NOT work either.
I did almost all of the process with the flex fuel line still connected. That makes getting the fuel level sender mechanism out hard and getting it back in very hard to impossible. Eventually I pulled even harder with pliers and the flex hose finally came off. That thing was a bear and I'm not a fan of this design.
The new rubber seal that comes with the pump is another challenge. Over all, replacing the fuel pump was way worse than I expected.
Now that its all back together, finally, it leaks. Looks like the flex fuel line is leaking at the attachment to the yellow top of the fuel pump assembly. Anyone know how to replace that line?
Thanks.
l8apex32 is offline   Reply With Quote
Tags
fuel line, fuel pump
Does this sound like a bad fuel sender or fuel pump? madyspop E39 M5 and E52 Z8 Discussion 10 19th February 2013 10:16
DIY: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire JoeFromPA E39 M5 and E52 Z8 Discussion 68 5th September 2012 02:25
Quick Fuel Pump / Fuel Supply Question Zen M E34 M5 Discussion 13 19th June 2012 07:25
Fuel sender/fuel filter/fuel pump/ temperature gauge jack eiler E39 M5 and E52 Z8 Discussion 6 2nd May 2012 17:08
Help - How do I disconnect fuel rail from fuel line? andyfanton E39 M5 and E52 Z8 Discussion 1 12th March 2010 22:03
