We'll see. I'll be checking it all out once all is "normal" as I may have a bad pump
but not long ago, I was using "bad logic" and you were telling me "its just a switch"
So, as sailor said, my pump may be "not right" and there could be some variables. I have a new relay on the way too, and maybe that is the weak link! As I said, I will measure again in the future
But, the voltage applied is definitely shown to vary based throttle and engine speed (seems that pump condition shouldn't matter much if the car is running, the conditions of which the relay controls voltage can be tested). If that changes with a new relay, then I'll definitely see it and post it up. As for all the other details, sailor will certainly enlighten us.
