Peake code 90 and 91 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 16th June 2012, 06:23   #1
taninbim
Garage: 2003 Gray M5
While driving today, I noticed that my throttle was acting very strange. My car was suddenly very jerky and almost stalled on me a few times. After reaching my destination, I let the car idle for a bit and all seemed OK. I parked and went on with my business. When I tried to start the car again, the engine would turn over and fire up, but wouldn't stay stable and the rpms would eventually drop to a point where the car would stall even with some throttle applied.
After getting home with the help of a tow, I looked up what he problem might be and found JoeFromPA's recent post, which was very handy.
Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire
Unfortunately, I don't have a copper wire handy so I cannot test the last step. My question is this: if the relay still makes a click when the ignition is in position #2, could it still be faulty? I had a friend help me with that test and I can feel the initial click when the key is moved to position #2.
Given that the car will start up, I think that the fuel pump might be OK, but I certainly could be wrong. After a bit of searching, it could be my fuel trim levels or even the MAFS from some of the posts that I read.
I'm trying to see if I can get a bit more diagnosis done before spending money on parts that I might not actually need. In the meantime, I'll see if I can find some copper wire.
Thanks.
taninbim is offline   Reply With Quote
Old 16th June 2012, 06:44   #2
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Need more info. What are your running symptoms if any. Have you tried unplugging the MAFs, what changes do you note?
Sailor24 is offline   Reply With Quote
The Following User Says Thank You to Sailor24 For This Useful Post:
taninbim (16th June 2012)
Old 16th June 2012, 07:10   #3
taninbim
No, but I should have looking in hindsight. It looks like bad MAFS.
When the MAFS are plugged in, the car will now run for a few secs before stalling out (no throttle applied). If I unplug the MAFS, the car will remain stable and settle in around 600-700 rpms with some minor idle hunting.
I was so focused on the fuel pump and relay that I didn't think to check the MAFS by unplugging them. Greatly appreciate the help.
Old 16th June 2012, 07:25   #4
Sailor24
Sailor24's Avatar
Your description looks like Mafs so keep them unplugged, you will get codes and your IAT will not be plugged in but.... If you feel the car overall performs better then invest in MAFS. The new MAFs will knock you socks off.
Old 16th June 2012, 21:04   #5
taninbim
Might be more than the MAFS.
If I keep the MAFS unplugged, the car will continue to run on idle. However, with any throttle and engaging the clutch, the rpms will suddenly drop possibly stalling the car. Letting up on the throttle might recover the situation.
I can read the following Peake codes.
29 = MAF 1
39 = MAF 2
90 = fuel control, bank 1
91 = fuel control, bank 2
01 = fuel relay
The last entry, 01, is actually new. It only showed up today when the CEL came on.
Old 16th June 2012, 21:33   #6
Sailor24
Sailor24's Avatar
Often it takes more than one thing to be wrong before they act up. They adapt so well. With the Mafs unplugged the will have some hiccups.
The real story is hidden in the 90 and 91 but you likely have no way of reading the long term fuel trim. Do you know anyone with an OBDII code reader those codes will tell you rich or lean.
Old 16th June 2012, 22:00   #7
taninbim
Unfortunately, I don't know of anyone with a reader.
I plan to replace the relay and MAFS for now. Hopefully that will get the car back into a usable state and I can take it in for further diagnostics to check the fuel trim levels.
Old 20th June 2012, 01:21   #8
taninbim
Replaced the relay today and unfortunately no change in the symptoms. The car is still not drivable. Also the car is now stalling after idling for a few mins even with the new relay and the MAFS unplugged.
Old 20th June 2012, 01:32   #9
Sailor24
Sailor24's Avatar
Have you tried jumping the relay?
After that you need to get a fuel pressure gauge and or someway to read fuel trim and calc load +g/s air going thru the MAF.
Short of that plug the Mafs back in and drive it see how it drives. I suspect it will do well for a bit then act like this again. Then you will be able to unplug the MAFs and it will be fine for a bit then go back to bad.
If you plug the MAFs back in and the car runs wellish do a MAF test(know what I mean) before the car changes.
Old 21st June 2012, 03:41   #10
taninbim
Installed the new MAFS today. So now new MAFS and new fuel pump relay. Unfortunately, no change in the symptoms. Since I don't have a more detailed reader, I brought it into a local shop for further diagnosis.
DIY: peake code reader 1b 69 code metalspeeddemon E39 M5 and E52 Z8 Discussion 9 11th May 2012 01:03
Recurring Peake code assistance, table 18 code C1 Misfire Cyl 1 Brent_M5 E39 M5 and E52 Z8 Discussion 3 8th November 2011 19:20
Peake Code 69 kiddhan625 E39 M5 and E52 Z8 Discussion 18 3rd October 2008 19:26
peake code b9 Stamper1 E39 M5 and E52 Z8 Discussion 1 6th September 2008 00:44
Peake Code Reader - Code 69 BrokeManWorkin E39 M5 and E52 Z8 Discussion 9 3rd February 2007 05:03
