Rear Suspension crunchy noise - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 14th June 2012, 20:47   #1
REKIII
REKIII's Avatar
Garage: 2001 Jet Black M5
Sales Feedback: (6)
I wanted to get a discussion going before I tear into the rear end (mostly because I don't know when I'm going to tear into it and I love driving the car).
Anyone who was near me at Timmayfest heard the horrible noises. Think of an empty aluminum soda (pop) can that you are wrinkling with your hand, not crushing, just wrinklink. Thats the sound.
Here is other pertanent info
Last summer I put all new rear suspension in. Every moving part with a bushing got repaced with new peices, there are only about 5K miles on all parts.
This is in exception 2 the rear control arms which had the bushings pressed out and monoballs installed.
I have older KWV3 coilovers
Brembo 4 piston BBK on the rear
New wheel bearings
New parking brake pads/springs/etc.
The outside CV joint on the drivers axle is leaking
parking brake works well
Hear is a fascinating point.....it only does it when the car is hot/warm. When i get in the car in the morning it is silent, all the way through my 10 mile commute to work. The longer I drive the worse it gets
It doesn't seem to make any noise when the car is smooth, only during accel/decel jerkiness and sometimes over bumps. Front to back motion seems to make it occur more, as I can't really get the car to crunch by jostling it with my body weight when parked.
Any thoughts? It seems like whatever idea I have there are several symptoms that prove that idea wrong. Maybe there are several things wrong, maybe all my new parts are shot. No idea.
Thanks for any input or thoughts.
2001 Jet Black M5
2008 Raven R1
2007 Black Sierra Denali
REKIII is offline   Reply With Quote
Old 14th June 2012, 21:02   #2
rao
Garage: Silver 540i
I'd be suspicious of the monoballs, but then again I always am
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is online now   Reply With Quote
Old 14th June 2012, 21:24   #3
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
Ive been having the same issue during shifts when the car is warmed up their is a loud pop as you shift...
2013 Subaru wrx Cobb tuned Daily beater
2009 135 "Worlds First Frozen 1ER" ESS Tuned stage 2
RIP MFIZZLENYCMOBILE - 12/5/2012 2000 Silverstone M5 extended Leather
213,500 miles !!!!!
Evolve Stage 3 Tune
BBS LMs 19s
Michelin Pilot Super Sports ,StopTech BBK,Dinan Headers, CF Plenum cover with clear windows, Dinan CF -CAI,Dinan Air Mass Meters ,Dinan light weight flywheel,Dinan stage 3 suspension ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
mfizzlenyc is offline   Reply With Quote
Old 15th June 2012, 02:03   #4
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
I don't know the design used, but i agree here.
The front of my car squeaks like mad only when hot, humidity also makes it worse, but I'm fairly positive it's the steering components with 200k.
Before Rob gets snarky: mine had been squeaking since before my monoball install.
mattmartindrift is online now   Reply With Quote
Old 15th June 2012, 02:18   #5
rao
Garage: Silver 540i
Why so hurtful?
Old 15th June 2012, 02:22   #6
jproy
Garage: 2000 M5 Anthracite
I'll take CV joints/axles for $1000? Your symptoms sound just like it and you already know you have a leaky CV boot. I have little experience with this car but a ton on others and your symptoms all point to it IMHO. You have nothing to lose. You need to rebuild the joints anyway since your boot is torn. Once dirt is introduced you must rebuild or replace IMO.
jproy is offline   Reply With Quote
Old 15th June 2012, 02:23   #7
rao
Garage: Silver 540i
I missed the leaky boot, that gets my vote as well, but I always remain suspicious of the monoballs.
Old 15th June 2012, 03:09   #8
lugnuts
lugnuts's Avatar
Garage: 2002 LeMans Blue M5 _______1979 Trans Am_____
my vote goes to drive train and sense you have a torn boot I would start there.
I get no noise at all from my fronts.
lugnuts is online now   Reply With Quote
Old 15th June 2012, 05:40   #9
mattmartindrift
Garage: 540i
lol, they're brand new. I believe the rear monoballs are a proprietary design that does not use an off-the-shelf/tried-and-true bearing.
Old 15th June 2012, 15:29   #10
REKIII
REKIII's Avatar
Sales Feedback: (6)
Here are the monoballs I installed:
Rear monoball mounts
I am doubtfull I could have done them wrong, however they are delrin, so maybe as they heat up they get soft and allow moevement?
I will change the axles and see if that helps. Anyone have a good recomendation on where to buy new ones? I would rebuild, but 1, I hate rebuilding CV joints and 2, they have 134K on them, so replacement isn't a bad thing.
Thanks for all the input and suggestion guys, much appreciated.
Crunchy clunk from stop or start motion! doc$holliday E39 M5 and E52 Z8 Discussion 6 25th May 2012 16:57
Help: Clunking noise from the R Rear suspension.... spinexoxo E39 M5 and E52 Z8 Discussion 1 4th April 2007 18:45
Noise from rear suspension? shanks E39 M5 and E52 Z8 Discussion 5 17th August 2004 16:46
Rear suspension noise jamilor E34 M5 Discussion 1 28th November 2003 21:40
suspension noise...steering wheel noise lrattner E39 M5 and E52 Z8 Discussion 1 20th October 2001 03:16
