Old 12th January 2001, 10:21   #1
Serge
Serge's Avatar
Garage: Porsche 911 Carrera
Have anyone tried installing the city lights in the hight beams?
I am considering putting those city lights in the high beams if it isn't too troublesome. Have anyone tried doing it? Or is everybody just going to buy the 2001 lights instead? I would imagine only US or Canadian M5's that would not have the city lights. Any input would be great.
Serge
00 Titanium M5
Serge is offline
Old 12th January 2001, 15:09   #2
DrKevM5
DrKevM5's Avatar
Garage: 2006 M5 Alpine White
Post
Serge, I had installed the city lights in my '98 5406sp. I checked the highbeams in the 2000s and they are the same. If you look closely, you will see a indentation in the reflector housing that is a simple drill through for the bulb. I ordered mine from http://www.motorworks.com. Click on the 1979-1979 VW catalog, then search citylights. I removed the rings and inserted the bulbs into the hole that I drilled. Simple wiring to the parking light circuit.
DrKevM5 is offline
Old 12th January 2001, 15:33   #3
Kevin Smith
Garage: 2002 Black Turbo
Post
What do the City Lights do? Would someone think your high beams are on when the City Lights are on?
Kevin
00 Imola Red M5
Kevin Smith is offline
Old 12th January 2001, 16:21   #4
SVTWEB
Garage: 2000 528iA, Euro-Spec, M-Sport, TiSilver
Send a message via AIM to SVTWEB
Post
I installed them in my car a few days ago. Very easy installation. Total parts cost was about $50. You tie them into the parking light circuit. They look great, but not a bright as your high beams, so no flashes yet.
SVTWEB is offline
Old 12th January 2001, 17:32   #5
DrKevM5
DrKevM5's Avatar
Post
City lights are basically only accent lighting. They are very low voltage. You may have seen them on some Jags, where it appears that all four headlights are on, but two are very dim. If you've seen some early pix of Euro M5's they can be seen if headlights are on.
[This message has been edited by DrKevM5 (edited 12 January 2001).]
DrKevM5 is offline
Old 12th January 2001, 17:35   #6
1C00lVC
1C00lVC's Avatar
Garage: '01 Ti/silver E39 M5
Send a message via AIM to 1C00lVC Send a message via Yahoo to 1C00lVC Send a message via Skype™ to 1C00lVC
Post
Would it be the same as the "rings" in the 2001 lights? Those lights light up with the parking lights, and look similar to "city lights"..
Arie
1C00lVC is offline
Old 12th January 2001, 21:16   #7
Serge
Serge's Avatar
Post
Thanks DrkevM5. Do you know if there's any place that have instructions as far as wiring goes? I am not too good with those electrical wiring stuff and I don't want to screw it up.
Serge
00 Titanium M5
[This message has been edited by Serge (edited 12 January 2001).]
Serge is offline
Old 12th January 2001, 22:19   #8
DrKevM5
DrKevM5's Avatar
Post
Just locate the wiring for the parking lights and splice the wires for the city lights into them.
DrKevM5 is offline
Old 12th January 2001, 22:22   #9
DrKevM5
DrKevM5's Avatar
Post
1coolvc, the rings serve the same purpose as the city lights. I have a dental colleague in Germany who says they often leave them on while parked for better visibility on narrow streets.
DrKevM5 is offline
What are the tach lights good for? Naka E39 M5 and E52 Z8 Discussion 13 9th September 2002 22:55
City driving lights CM5GO E39 M5 and E52 Z8 Discussion 6 31st March 2002 20:31
"ORDER / PRODUCTION SUMMARY" ( Note : See First Post For Instructions ) Alan A E39 M5 and E52 Z8 Discussion 82 17th March 2002 07:50
Please Help! New Celis head lights will not...... POWER5 E39 M5 and E52 Z8 Discussion 1 20th May 2001 16:28
LED based tail lights - Obsrvations.. 1C00lVC E39 M5 and E52 Z8 Discussion 13 9th January 2001 05:21
Page generated in 0.13094 seconds with 11 queries
