Strange Clutch issue - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 13th June 2012, 20:15   #1
Elvirb87
Elvirb87's Avatar
Garage: 2001 Carbon Black M5
I have just noticed a new issue in my car. When I press the clutch everything is fine, but as soon as I let go of the clutch I feel a slight sticking feeling like it’s getting stuck somewhere on release (but it does release all the way, it never gets fully stuck) . I would say it does it every 1 out of 5 engagements.
Current miles on the car is 107k, clutch was replaced at 65k. using OEM clutch and FW.
Any suggestion on what the issue might be?
Elvirb87 is offline   Reply With Quote
Old 13th June 2012, 20:21   #2
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
how long has it been doing this?
First guesses are the mechanics of the pedal itself, master cylinder mounting, or clevis attachment to the pedal.
mattmartindrift is offline   Reply With Quote
Old 13th June 2012, 20:24   #3
M5thoughts
Garage: '02 M5 / Carbon black / Black Luxury
+1
My clutch does the same thing, it randomly seems to stick on the way up a few times/day. The only "pattern" I've noticed is that it seems to happen more during the first 5-10minutes of driving but not so much after everything is warmed up. My clutch is original w/36k on it and does need replacing as I can make it slip if I "want to" but can very easily drive without slippage.
M5thoughts is offline   Reply With Quote
Old 13th June 2012, 20:47   #4
Elvirb87
Elvirb87's Avatar
It has been doing it for about 2 weeks now. I did check the mechanics of the clutch and i could not find anything. If i keep engaging the clutch in the driveway i can hear a noise from the clutch like something is springing out. My first initial thought process was "its the throwout barring".
The clutch is not slipping as of right now.
Old 13th June 2012, 20:50   #5
fmcfad01
fmcfad01's Avatar
Garage: Anthracite e39 M5; Estoril S54 e36/8
Mine was doing that for a time this winter, but hasn't in a long while. My clutch has since started to slip very badly. New clutch is going in soon.
Maintenance Record
fmcfad01 is offline   Reply With Quote
Old 13th June 2012, 20:55   #6
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
When was the last time you bled the clutch?
bimmerule is offline   Reply With Quote
Old 13th June 2012, 20:57   #7
fmcfad01
fmcfad01's Avatar
Never in my ownership of the car (7-8 months).
Old 13th June 2012, 20:58   #8
Elvirb87
Elvirb87's Avatar
I am not sure if it has been bled since replacing the clutch. I have ordered some new fluid and try that first before moving foreword with replacing stuff.
Old 13th June 2012, 21:39   #9
HeyHouse
HeyHouse's Avatar
Garage: 2001 Imola Red BMW M5
Same issue
Hi,
I am havingt he same issue. It popped up a couple weeks back. I recently recently had my fluid replace before an HPDE at Autoclub Speedway. I was thinking it was the slave cylinder but have not had a chance to get it into the shop.
Will keep you posted,
_____________________
HEYHOUSE
2001 Imola Red M5
INTERIOR
Black/Imola Red Interior
Mark IV Navi Upgrade
Dice IPOD Integration
ENGINE
Evolve Alpha N Tune
IATS Relocation
AFE Dry Element Drop Ins
DRIVETRAIN
Dinan Rear Swaybar
Dinan Springs & Koni Sports
Rogue SSK & Trans Mounts
HeyHouse is offline   Reply With Quote
Old 13th June 2012, 21:42   #10
Elvirb87
Elvirb87's Avatar
Originally Posted by HeyHouse View Post
Hi,
Let me know what you find out. I will change my fluid in the next couple of days in hopes of fixing the issue.
Strange power issue mcvaughan E60 M5 and E61 M5 Touring Discussion 1 21st October 2011 21:54
Strange Oil Temp Issue NachtBlau E39 M5 and E52 Z8 Discussion 7 18th May 2011 16:45
Strange clutch pedal issue PittsFlyer E39 M5 and E52 Z8 Discussion 21 24th December 2010 01:02
Strange bluetooth issue spinny E60 M5 and E61 M5 Touring Discussion 3 4th December 2009 22:52
strange navigation issue e39bliss E39 M5 and E52 Z8 Discussion 8 31st March 2009 17:19
