DIY: RHD Car- Power Steering Pipe Replacement Steering Box To Pump - BMW M5 Forum and M6 Forums
Old 13th June 2012, 14:59   #1
StreetDragster
StreetDragster's Avatar
Garage: 2001 E39 M5 LeMans Blue
Hi All,
My car is a RHD version, and has a seeping pipe between the power steering box, and the pump. On the RHD car this is a long pipe which goes all the way round the front of the engine and then up to the steering box, behind a thin heatshield.
The banjo bolt on the steering box looks pretty inaccessible, and i wondered if anyone had done this before, and if so, did you manage it with normal spanners? I can't see the mountings for the little heat shield, if this was removed i imagine the job would be much easier.
Matt
StreetDragster is offline   Reply With Quote
Old 14th October 2012, 00:01   #2
tripevans
Garage: 2000 M5 Black
Just replaced my return pipe
I just replaced my return pipe going from the cooling outlet to the steering box.
The bolt holding in the steering box end is a 22mm Hex bolt.
See the 2 images below for how I released it......kind of a pain in the *** to get to.
Remember there are 2 crush washers on either side of the hose end going into the steering box.....I had to use one hand to place the hex bolt and first washer into the hose and then place the 2nd washer on the underside of the hose......dropped it 2x.....was a lot of fun
tripevans is offline   Reply With Quote
Steering box replacement... e34M52b E34 M5 Discussion 65 1st February 2012 14:43
Power steering pipe replacement captain_anonymous_2003 E39 M5 and E52 Z8 Discussion 16 11th June 2010 12:47
E39 M5- Steering Box replacement solutionbuilt E39 M5 and E52 Z8 Discussion 2 3rd November 2009 17:45
Power steering box London Mike E34 M5 Discussion 20 26th July 2005 11:25
Steering box help RHD jimmy01 E34 M5 Discussion 12 23rd April 2002 11:14
