Oil separator question. - Page 3 - BMW M5 Forum and M6 Forums
Old 15th June 2012, 00:54   #21
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
No mine are different at times, like when I am stopped but are mostly the same when moving. This is going to kill you we don't really know what the Atemp is exactly but it seems to be the temp sensor in the DME and some other unknown inputs. First simple and free thing to do would be switch MAFS side for side. The air temp is taken from only the one on the left side. When the MAF is on the right it is not hooked up.
Do you have a dme fan error? Ebox fan error?
Sailor24 is online now   Reply With Quote
Old 15th June 2012, 00:55   #22
M5 Sydney
Garage: '99 M5 Carbon Black / Black & Red, 2000 540i Biarritz Blue Metallic, BMW K1200GT Orient Blue, BMW K1 Red / Yellow
If your top seperator hoses are squishy, chances are so are the bottom ones. But ideally it's a thermostat out job to replace them. And it's important they are in good order.
I don't think the seperators themselves are baffeled, so you can clean them out with brake cleaner & compressed air. No need to replace as they are just hollow cones.
Part numbers are below:
VENT HOSE - ZYL. 1-411151406952
VENT HOSE - ZYL. 5-811151406953
RETURN HOSE - ZYL. 1-411151407344
RETURN HOSE - ZYL. 5-811151406902
RETURN HOSE11151406900
M5 Sydney is offline   Reply With Quote
Old 15th June 2012, 18:36   #23
M.A.D.MikE
M.A.D.MikE's Avatar
Garage: '00 M5 E39 Dark Blue
I just bought thermostat temp. sensor (13621703993), will install it tomorrow, and if doesn't work, will switch MAFs. No errors except for AA.
Thanks, i think i'll just change all those hoses to be sure )
M.A.D.MikE is offline   Reply With Quote
Old 16th June 2012, 01:28   #24
Sailor24
Sailor24's Avatar
Sorry man I must have mislead you. I was trying to say check the flow of the air in the ebox fan setup. If you do not see codes there it is possible the boot fell off the fan and the fan is not blowing on the right spot or some other reason.
Old 16th June 2012, 10:59   #25
M.A.D.MikE
M.A.D.MikE's Avatar
Thanks for the info, will check it!
Old 19th June 2012, 23:01   #26
M.A.D.MikE
M.A.D.MikE's Avatar
Quick update. Just changed my temp sensor (13 62 1 703 993) and attempted to change after-cat O2 sensors. While trying to remove them, they broke, as apparently, they were never changed in all of 82k of my car's life And when we tried to install the new ones, they didn't fit So we installed plugs instead, since the old ones were broken. And what do you know? It now feels like my beast is 100hp more powerful! I don't know which of the two things i did exactly caused it, but i feel like it's temp sensor's fault, making the car think the engine is hotter then it really is. So i'd suggest to anybody to change it if you feel your beast is becoming kind of sluggish It's only $25 btw.
Oil Separator Hoses...now I'm a believer! doc$holliday E39 M5 and E52 Z8 Discussion 30 4th May 2012 12:20
Conceptual Polymer Oil Separator josiahg52 E39 M5 and E52 Z8 Discussion 0 24th May 2010 23:39
oil separator and nonreturn valve question Ruppy E34 M5 Discussion 3 21st October 2009 23:42
New Oil Separator Hoses rock! JesperT E39 M5 and E52 Z8 Discussion 21 22nd April 2009 20:14
POLL: Oil Consumption Status after Oil Separator Replacement RUFM5 E39 M5 and E52 Z8 Discussion 1 2nd March 2008 11:18
