P0340 - Powertrain Error ... but engine runs fine? - BMW M5 Forum and M6 Forums
Old 8th June 2012, 08:05   #1
rrdawho?
rrdawho?'s Avatar
Garage: 97M3/4T, 98 M3/4, 01 M5
I've been getting a SES Light and when I read the code it gives me the following:
P0340 - Powertrain
Camshaft Positions Sensor "A" Circuit (Bank 1 or Single Sensor).
Car was running fine when the SES came on, so I reset it.
1 Week goes by, no SES light.
SES came back on again today, same code, but the the engine still runs and idles fine, very smooth. WOT good power, no hiccups/hesistation, fast throttle response.
Any ideas whats going on? Maybe loose connection or wiring going bad?
rrdawho? is offline   Reply With Quote
Old 8th June 2012, 17:00   #2
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
A vague I suppose so but not really. It means that the PCM is not receiving the pulse signal from the CPS so you have a dead CPS. Possibly a broken wire but I doubt it. In all my time this could has been 99% of the time CPS the few times it was not it came with many other codes. If you only have the one code replace the CPS.
Do you know which one? Did you know that a large number of us will tell you replace them in pairs or just replace all 4? If the CPS are the original ones for the car it certainly seems they get sluggish after so many years and cycles.
Sailor24 is online now   Reply With Quote
Old 8th June 2012, 18:07   #3
technician117
technician117's Avatar
Garage: 2000 M5 Anthracite
Sales Feedback: (5)
ditto what he said, and do all 4 unless you've replaced some recently.
Tim
UUC ssk
Tubi Catback
technician117 is offline   Reply With Quote
Old 18th June 2012, 02:16   #4
rrdawho?
rrdawho?'s Avatar
Thanks for the info.
Could you provide the part numbers for all 4 along w/ which ones belong on which side?
I checked Pelican but its not very clear which is which to me...
TIA!
running rough on start , runs fine if I restart kevin711 E39 M5 and E52 Z8 Discussion 17 14th June 2011 04:01
SES Light (But Runs Fine) captain_anonymous_2003 E39 M5 and E52 Z8 Discussion 26 15th December 2009 22:38
fine FINE! I'll post pics of my M5! w00t!! *formal introduction* btmlinedan E39 M5 and E52 Z8 Discussion 26 28th August 2009 17:22
SES light but car runs fine?? jordantii E39 M5 and E52 Z8 Discussion 7 2nd August 2005 22:24
Car and engine runs shakily blitzkrieg E39 M5 and E52 Z8 Discussion 4 10th June 2005 00:15
