Old 3rd August 2002, 20:36   #1
chunpng
chunpng's Avatar
Garage: M5, silver/black
Clutch Uptake Speed
I ran a search and did not see a thread on this question.
I taught myself how to drive to stick in 1977, and have always put priority on smooth shifts, i.e. no jerky motion, i.e. slower clutch uptake, in all gears.
Since I had the M5, I've ridden more as a passenger in manual cars. I realized that others basically popped the clutch form second gear on (Tako does it in his brand new Merc.). Starting in first, you'd naturally feather the cluth a little more. However, I habitually do slow clutch uptakes through at least third gear, probably fourth also.
Questions:
Am I hurting the clutch by not having rapid full-engagements in higher gears?
Should I pop my clutch now and sacrafice the smoothness?
Is there a way to have a smooth shift AND rapid clutch uptake?
What do you guys do, pop the clutch from second gear on?
Thanks for the education.
CP
CP
00 Titanium Silver: 6/00-1/05 RIP
95 Black Metallic RUF BTR-2
07 Meteor Grey Cayman
chunpng is offline
Old 3rd August 2002, 21:24   #2
petesamprs
petesamprs's Avatar
Garage: e90 330i
good questions...i'm wondering about this well. my car (not an M5) still jerks if i pop* the clutch pedal after shifting for both 1st and 2nd and 3rd gear shifts - so i feather them.
* fyi, pop = rapid full engagement, like you mentioned in your post
petesamprs is offline
Old 4th August 2002, 00:59   #3
bernhtp
Garage: M6 Convertible - Saphire Black, Portland Brown full merino, CF
The best way to achieve smoothness is not by feathering the clutch, but rather by matching the speeds on both sides of the transmission as the clutch is released. Generally, you shift more slowly as your gear change is made at higher engine speeds because of the greater difference in engine/transmission speed and consequently the amount of time it takes for the engine to slow down and match speeds. Lower gears also generally have larger differences in ratios with adjacent gears than bigger gears, so these also take more time clutched in.
It takes a little practice to get the timing right. It's also a bit better to shift a bit too early than too late, as this yields less of a bumpy ride, and hitting it too fast at least has the benefit of putting engine momentum to the rear wheels.
Tom
bernhtp is offline
Old 4th August 2002, 03:46   #4
chunpng
chunpng's Avatar
should clarify that my questions pertain ONLY to upshifts furing accelerations, not downshifts when decellerating. For down shifts I rev match as bets I can.
The difference is on upshifts, once the clutch goes in and the upshift is made, the tire speed is usually higher than the engine speed. Engine slows down during shifts as my foot is off the gas. Thus, there is little jerky motion even on fast clutch releases, at least theoretically.
CP
CP
chunpng is offline
Old 4th August 2002, 03:53   #5
bernhtp
Quick shifting on upshifts, at all except for really low RPM shifts, will result in a forward lurch as the engine speed drop in that short time will be less than the drop due to gear ratio change. Thus, it is almost always possible to time it so you get the desired speed match.
If you shift early and don't want to shift relatively fast, you will have to feather it and/or give gas while clutched in to speed match.
bernhtp is offline
Old 4th August 2002, 05:09   #6
EBMCS03
EBMCS03's Avatar
Garage: E60 & IS 350, miss my MINI
Send a message via ICQ to EBMCS03 Send a message via AIM to EBMCS03 Send a message via MSN to EBMCS03 Send a message via Yahoo to EBMCS03
Which is better? feather the clutch or not let off the gas all the way? Like let off the gas a little while still applying gas and then dropping the clutch.
2008 ///M5 SMG | Alpine White | Black Full Merino Leather w/Aluminum Trim | Logic 7 | iPod Adapter | HUD | Heated / Ventilated & Adaptive Comfort Seats | Comfort Access | Rear Side Airbags | Rear Side Sunshades | Folding Rear Seats | 35% Sides 15% Rear Windshield Tint
EBMCS03 is offline
Old 4th August 2002, 05:16   #7
1C00lVC
1C00lVC's Avatar
Garage: '01 Ti/silver E39 M5
Send a message via AIM to 1C00lVC Send a message via Yahoo to 1C00lVC Send a message via Skype™ to 1C00lVC
you should search some old threads where Greg was talking about this. The answer to your question is "it depends"... you can make shooth shifts, and still be gentle on your clutch. It all has to do with how much torque you are transferring.. If you pop the clutch, and accelerate hard, the extra torque from the enging has to give somewhere, and if the wheel do not lose tracktion, the clutch is the "weekest link" and will ware out faster.
You can shift gentlly and smooth by matching the revs on shifts.
I got to the point that I can make the car "feel" smooth like an automatic tranny...
Arie
Remember, with an automatic transmission, Shift Happens....
'01 M5 - Titanium Silver/Siilverstone/Aluminum trim
- PDC
- Split seats
- deleted spoiler
- M Audio
- 8000 phone
- Voice Reco
- TV tuner
My Website
1C00lVC is offline
Old 4th August 2002, 05:18   #8
bernhtp
I would slip the clutch up from a fully depressed (nearly) position so as to not wear out the synchros given that you are not speed matching.
bernhtp is offline
Old 4th August 2002, 05:59   #9
Des
Des's Avatar
Garage: 03 CB
Send a message via AIM to Des
Greg gives some great advice at this site
http://playground.sun.com/greg/
and the officer said keep it under a hundred
Des is offline
Old 4th August 2002, 15:23   #10
D/FW M5
D/FW M5's Avatar
Garage: 2000 Jet Black M5
At the M5 driving expereince they made a point of saying do not let out your clutch too slowly when accelerating hard as thats the fastest way to burn it out. On the other hand I do not recommend popping the clutch either, I would just suggest letting it out smoothly and quickly.
Doug
D/FW M5 is offline
Im back! -- with a clutch story.... 1C00lVC E39 M5 and E52 Z8 Discussion 5 9th June 2003 23:33
TECH: those w/ non-original clutch --> light clutch pedal? Teutonaddict E39 M5 and E52 Z8 Discussion 0 31st July 2002 20:44
Front Brake inner Cooling Ducts & TRACK CAM. Installed M5@ksa E39 M5 and E52 Z8 Discussion 7 10th April 2002 05:34
definition of a speed trap... Jacob Lee E39 M5 and E52 Z8 Discussion 1 7th February 2002 02:59
A Clutch Tutorial greg E39 M5 and E52 Z8 Discussion 10 31st October 2000 18:48
Page generated in 0.16357 seconds with 11 queries
