DIY: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire - BMW M5 Forum and M6 Forums
Like Tree10Likes
Old 4th June 2012, 05:13   #1
JoeFromPA
Garage: 2001 Carbon Black/Caramel M5
Sales Feedback: (3)
Hi all,
So tonight my car suddenly no longer started up. It had literally been driven within 5 minutes and suddenly no longer started, yet it cranked healthy. No problems, no lights, etc.
Thus, I suspected fuel system related since our lovely beasts seem to have several known failure points - that the fuel tanks are no longer being balanced somehow and the tank your fuel pump is in empties; that the fuel pump has died; or that the fuel pump relay has gone bad suddenly.
To figure out what the problem is in 10 minutes with your bare hands and a piece of copper wire, here's my guide to what I did (Big hat tip to Rao):
1. Step one: Put key in position 2 so that everything is powered up, put your seatbelt on, and then open up your secret menu on your gauge-cluster and go to test: 05 or 06 (forget which) and look at your tank levels to confirm they are at least close to each other:
2. If your levels look equal and sufficient in quantity, next up is testing your fuel pump and fuel pump relay together. For this, you'll need a ~6" piece of copper wire or similar.
3. Open up your trunk and pull open the right-hand access panel behind the right taillight. You'll see a row of box-relays as such - the TALL BLACK ONE is the fuel pump relay. See below:
Now, if you have someone with you, put your hand on the fuel pump relay while they turn the key to position 2. If the fuel pump relay is working, it will notably click under your hand - you won't miss it. If the fuel pump relay is dead, a lack of a click is a clear indicator. However, most people don't have individuals with them, soo....
4. Here is the fuel pump relay pulled out (just tug and wiggle a bit and it'll pull out with some force)
5. Now you want to access what the relay plugs into - that grid underneath it and the wires that feed that grid. Pull the grid straight out and it'll unlock from it's slot and give you a few inches of room to manuever it around.
6. Going into this relay is ~4 wires. 2 thick wires and 2 thin. The 2 thick wires are red & violet stripes and red & white striped. AFAIK, these represent power supply to the relay and then a power wire that runs to power the fuel pump - they become connected when the relay is signal'd to connect them.
To test the fuel pump and relay, you want to stick the wire in the grid-slot that connects to the thick wires (one red-white striped, one red-violet striped). You'll need to really jam it in there to make contact. Even with no key in the car, this has power with the trunk open. When your make-shift wire makes contact on both ends and connects these power supplies, you may see a spark and, if the fuel pump is working, you will hear it begin whining/pumping as long as you maintain contact - it won't cycle on/off, because it not has a steady supply of power.
If the fuel pump does not turn on now and cannot be heard, it is dead. If it does turn on and you can hear it, keep the wires in contact and either start the car yourself or have someone else start the car. If it fires up, your fuel pump relay is dead.
Hope this helps others. Ironically, I've been eyeing up the fuel pump/filter/relay kit for a solid month and just putting it off since the car was running fine. And then tonight, my fuel pump relay dies. Time to pony up.
Thanks to this wonderful community and Rao in particular for making it possible for a basic DIYer like me to narrow this down to a specific relay at night, with a flashlight, and pretty much no tools.
2001 Carbon Black on Caramel - 121k miles (4/2/2013)
JoeFromPA is online now   Reply With Quote
The Following 15 Users Say Thank You to JoeFromPA For This Useful Post:
bcampbe7 (4th June 2012), bibledriver (5th June 2012), BrendanSC (4th June 2012), chowdah (4th June 2012), CSBM5 (4th June 2012), Inverno (4th June 2012), Jetpilot718 (4th June 2012), jmslew (4th June 2012), manualshifter (4th June 2012), rroberrto (5th June 2012), Scott the Pict (4th June 2012), sor118 (5th June 2012), StreetKa (20th September 2012), TMcNasty (5th June 2012), yellowgixxer (5th June 2012)
Old 4th June 2012, 12:16   #2
rao
Garage: Silver 540i
Glad you were able to get your problem sorted out quickly.
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is online now   Reply With Quote
The Following 2 Users Say Thank You to rao For This Useful Post:
CSBM5 (4th June 2012), jamiepeers (4th June 2012)
Old 4th June 2012, 12:34   #3
josiahg52
josiahg52's Avatar
Garage: 2001 Jet Black/All Exclusive Black/Black Cubic M5, Supercharged 2001 Tahoe LT 4x4
Sales Feedback: (6)
Glad you got your problem sorted. That Rob guy seems like a pretty good guy.
NOTE: I NEED TO VERIFY THIS INFORMATION (see Post #5): Just so no one is confused, your jumper should be placed between Terminals 30 and Terminal 87 assuming that this relay and circutry follows convention. Terminal 87 is a shut contact when the relay coil is energized via Terminals 85 and 86.
Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire-relay-pin-out.bmp
-Josiah
2001 ///M5 Jet Black/All Exclusive Black/Black Cubic - 3/2001 production "UNTIER"
josiahg52 is online now   Reply With Quote
The Following User Says Thank You to josiahg52 For This Useful Post:
Old 4th June 2012, 15:01   #4
JoeFromPA
Sales Feedback: (3)
Josiah,
I'm very new to relays and electrical work in general and thus when I pulled the relay and examined your description above and what not, I became dis-oriented - I wasn't clear which ones were which since the box looks very similar on each side.
So I followed Rao's advice and jumped it based upon wiring going into the lead from below - the large wires represent power supply to and from the relay, they are red/violet and red/white striped, and thus I jumped those directly. Worked and the fuel pump immediately started running non-stop (I wouldn't leave it like that for long!)
I'm not disagreeing with you at all, just saying why and how I proceeded a little differently due to my inexperience.
Old 4th June 2012, 15:06   #5
rao
Garage: Silver 540i
I've read differently
The BMW relays don't always follow the Bosch convention so the pins can be in just about any location.
I walked Joe through the wiring diagram so that he would be able to find the right wires to work with.
Old 4th June 2012, 15:40   #6
JoeFromPA
Sales Feedback: (3)
Wanted to give a plug to Bimmerzone - Vince is getting me a fuel pump relay TODAY (note: first business day since this happened, but possible also cause I live 2 miles away). Being off the road for a single day to get a part is a livable situation and I'm saving in car rental costs enough to pay for the fuel pump relay itself, if I had been stranded for one more day.
Old 4th June 2012, 17:50   #7
josiahg52
josiahg52's Avatar
Sales Feedback: (6)
Originally Posted by JoeFromPA View Post
Josiah,
Nothing wrong with verifying the wiring! I was trying to preempt the question as to which ones to jump.
I will find out tonight, at least for the fuel pump relay! Using a wiring diagram is the proper way anyway.
Old 4th June 2012, 18:03   #8
JoeFromPA
Sales Feedback: (3)
Josiah, by your diagram I believe I jumped 85 and 87.
85 was my violet/red striped power supply wire, and 87 was my red/white striped power-to-fuel-pump wire, IIRC.
There are 9 pins available to plug into IIRC, and I jumped a center-left terminal and a center-top terminal (i.e. diagonally to each other). I did NOT jump anything from bottom to top.
Old 4th June 2012, 18:41   #9
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Thanks for the pics and write-up. I'm seeing a part # 61-35-7-892-976 for the relay. Does that appear to be correct? Thanks!
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 92mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, RK Autowerks/Evolve tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete, Dinan 17mm rear sway bar,
TCD sway bar brackets, Ultimate Pedals, Euro Armrest, Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,
Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
04 M3 Jet Black/Black Nappa/6 spd
Evolve Alpha-N tune, SGT Headers, Rogue SSK, Dinan Muffler
ECB is offline   Reply With Quote
Old 4th June 2012, 18:46   #10
rao
Garage: Silver 540i
You jumped 30 and 87. The numbers are hard to see at night with a flashlight or in the day if you are over 15 . Plus as mentioned BMW goes it's own way with relay pin orientation. That is why we went with the colors and gauge.
E39 Fuel Pump Relay Location tacoma330ci E39 M5 and E52 Z8 Discussion 16 11th July 2012 17:12
Fuel sender/fuel filter/fuel pump/ temperature gauge jack eiler E39 M5 and E52 Z8 Discussion 6 2nd May 2012 17:08
Fuel Pump Relay - 000 Code swartzzz E39 M5 and E52 Z8 Discussion 9 23rd March 2012 19:43
urgent help needed! fuel pump relay or pump itself?? jonnycowboy E39 M5 and E52 Z8 Discussion 14 1st October 2009 15:58
Location of fuel pump relay? M5Micke E34 M5 Discussion 4 2nd October 2006 21:01
