M5 real world 0-60 Time - BMW M5 Forum and M6 Forums
 7Likes
post #1 of 27 Old 27th May 2012, 07:59 AM Thread Starter
pnirenstein
There has been much debate over the M5's "real" 0-60 time. Not so much on this forum, but over the broader internet. I took a video of my stock 2001 to see what the beast could do. Recorded 4.89 seconds to 60 on the first run. Tires are fairly bald, so when new treads show up I'd expect a minor improvement. Enjoy!
2001 E39 BMW M5 0-60 mph - YouTube
pnirenstein is offline
The Following User Says Thank You to pnirenstein For This Useful Post:
chowdah (27th May 2012)
post #2 of 27 Old 27th May 2012, 09:40 AM
m000240
m000240's Avatar
Wouldn't bald tires improve the time as they are closer to slicks? (i.e. more rubber in contact with the road) I was under the impression the "tread" was for cornering and weather traction.
Nonetheless, very impressive. Any modifications?
m000240 is offline
post #3 of 27 Old 27th May 2012, 10:00 AM
dimi_108
dimi_108's Avatar
What he said. Definitely not stock?
Current ///M
2003 Le Mans Edition M3 SMG (Pics)
Previous ///M's
2000 Carbon Black M5
2002 Carbon Black M3 SMG
dimi_108 is offline
post #4 of 27 Old 27th May 2012, 10:09 AM Thread Starter
pnirenstein
ah I guess I was wrong about the tread. Just came back from Thunderhill, and bald tires sure didn't help around corners, so I falsely assumed the same would apply to the straights. Maybe that's why I don't chirp as much during hard pulls as I did a few months ago. The car is 100% stock.
post #5 of 27 Old 27th May 2012, 10:15 AM
dimi_108
dimi_108's Avatar
Serious? I thought exhaust note sounded very loud for stock
Current ///M
Previous ///M's
dimi_108 is offline
post #6 of 27 Old 27th May 2012, 10:17 AM
bimmerule
bimmerule's Avatar
The video doe not show if it's uphill or downhill, nor do we know the accuracy of timing equipment. It's best to get a 1/4 mile time slip, that'll show both the car's power (trap speed) and driver skill (ET).
Maint: Liqui Moly 10W60 Race Tech GT1 Engine Oil, Pentosin MTF2, Mobil1 Full Synthetic ATF Steering Fluid, ATE Super Gold Brake Fluid
Wheels: Style 65 18x9.5" Squared 275/35/18 Dunlop Direzza Z1 Sport Star Spec, 3mm Front Spacers, Turner Motorsports Extended Bolts
Braking: Genuine BMW Rotors, Pagid Yellow RS 19 Endurance Racing Compound, Titanium Backing Plates, Open Brake Ducts, FTE Lines
Handling: Intrax Racing Springs, Bilstein B8 Monotube Dampers, Ground Control Camber Plates, Dinan Strut Tower Brace, Dinan Rear Sway Bar, X5 Thrust Arm Bushing
Power: Is Nothing Without Control, Stock Motor Dyno'd @ 341WHP, 319LB-FT Dynojet.
Aero: None Yet
Race: 13.37@103.38mph Englishtown, Lime Rock Park 1'09.9", New Jersey Motorsport Park Lightning Circuit 1'23.420", Thunderbolt Circuit 1'44.2", Watkins Glen International *tbd, Monticello Motor Club *tbd.
Gear: Bell SA2010 Sport Helmet, Sparco Tornado Racing Gloves, Sparco Speed+ Racing Shoes, OMP Balaclava
Winter: Style 66 17x8, 17x9 Staggered 235/45/17-245/45/17 Bridgestone Blizzak WS70 Studless Snows
Interior: E60 SSK, ZHP Shift Knob, MK4 Navigation, Umnitza VXX Angle Eyes, Brushed Aluminum Trim Swap
bimmerule is offline
post #7 of 27 Old 27th May 2012, 10:43 AM
josiahg52
josiahg52's Avatar
Bald tires do not mean they are more "like" slicks except maybe in appearance.
Bald tires mean worn tires that have a lot of heat cycles on them or are old. Used, bald tires that presumably have multiple heat cycles on them and are old (age) result in a tire that is harder than the new tire was therefore making it incapable of providing the same traction than the new tire did despite their drag slick-like appearance. Further, the lack of tread creates a dangerous tire that will not be suited for inclement weather or, especially, wet roads.
This hardening is also why some tires get noiser as they wear; because they are getting harder. There are also recommendations for replacing tires after they attain a certain age, regardless if they have ever been installed/used or not and despite remaining tread level, in order to minimize the adverse affect this phenomena has on the overall traction of a vehicle. How rapidly this change occurs is dependent on the type of rubber that is used in the manufacturing process and will therefore vary from tire to tire (manufacturer/type).
If they aren't R compound tires, slicks, etc., tires with the tread worn off are simply giving traction up, not helping it at all.
josiahg52 is offline
The Following 4 Users Say Thank You to josiahg52 For This Useful Post:
chowdah (27th May 2012), gsfent (27th May 2012), jamiepeers (27th May 2012), Sailor24 (27th May 2012)
post #8 of 27 Old 27th May 2012, 12:12 PM
jumbo
jumbo's Avatar
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
1999 Interlagos Blue / Black
AlphaN + Evolve powermap + D2 coilovers + 19" Ac Schnitzer typ III + Muffler delete + Stop Tech brakepads + e60 Short Shifter + Hella Facelift front & tail lights + iBright + Interior / exterior LED´s + iPod +
jumbo is offline
post #9 of 27 Old 27th May 2012, 05:47 PM
m000240
m000240's Avatar
Learn something new everyday.
Can you explain why Tirerack offers to trim tread from some tires? Following your discussion above wouldn't that simply reduce the usable life of the tire?
m000240 is offline
post #10 of 27 Old 27th May 2012, 05:49 PM
AGM5
AGM5's Avatar
Race slicks (F1 (when they were pure slick tyres), NHRA, CART) have tread in the contact surfaces of the tyre, this is why they have to replace the tyre as they wear. The tread on our street tyres is the same. As the tyres wear they loose friction at the contact patch. Less friction between the tyre and the road means less tractive effort which, results in slower straight line and cornering speeds and increased stopping distances.
AGM5 is online now
Tags
0-60 0-100 mph kph
Real world MPGs bimmerule E39 M5 and E52 Z8 Discussion 59 24th January 2012 04:54 AM
Launch Control in the Real World PPG4 E60 M5 and E61 M5 Touring Discussion 9 23rd December 2005 04:11 PM
Real World drivability? M5inPA E60 M5 and E61 M5 Touring Discussion 18 24th November 2005 12:13 AM
Real world hp results Carrera2RS E39 M5 and E52 Z8 Discussion 1 1st August 2004 11:42 PM
Real world MPG Bryn E34 M5 Discussion 21 10th August 2002 05:38 AM
