7th June 2012, 06:07
#21
Carbon Black E39 M5
It is lifetime of the car, regardless of owner, so yes it is transferable. They will tow you to the nearest BMW dealer, no matter where you are. This doesn't cut into BMW's bottom line too much b/c 1) the dealer will charge you an arm and a leg and 2) there aren't that many ///M cars in remote parts of the country. It's a good marketing tool.
