Fun with broken connecting rods! - Page 8 - BMW M5 Forum and M6 Forums
Like Tree36Likes
Old 10th May 2012, 13:40   #71
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Originally Posted by AlBundy View Post
Yes. But that would not take RPMs too far past fuel shut off.
Think just the momentum of moving parts at somewhat higher RPM could pull engine apart like that?
Flywheel bolts snapped when engine seized suddenly.
EDIT: What's top speed in 5th at redline?
About 150 mph... I definitely wouldn't be wanting to shift to 4th instead of 6th.
There is a member Leezamonkey with an in-car track video showing a mis shift which threw him completely sideways, and that was without him even releasing the clutch as he realised the mis shift immediately...and under some duress I must add !
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 10th May 2012, 13:48   #72
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
so, i checked out this motor.
My guess is that the motor had a bad bearing, threw a rod and siezed the motor while driving. That shock through the drive train sheered off the >100k mi flywheel.
Also, the flywheel had been ridiculously overheated in the past based on the coloration all the way through the back side of the flywheel's friction surface.
mattmartindrift is online now   Reply With Quote
Old 10th May 2012, 14:18   #73
intrepid one
intrepid one's Avatar
Garage: '01 M5 Carbon Black
Sound like a car that was just abused and not taken care of at all..a good lesson here..Cosmetics are all well and good, but if you want the car to live long, you must pay attention to the mechanical maintenance as well..Great CSI work guys.
intrepid one is offline   Reply With Quote
Old 10th May 2012, 15:21   #74
Clemster
Garage: 2010 E90 M3 Alpine White/Fox Red
Sales Feedback: (26)
Agreed on the signs of abuse, Matt. When your pressure plate looks like this, you've been rode hard and put away wet.
Former Owner of this Beast!
2003 M5 Silver on Black/Silverstone Sport
ESS S/C w/ 92mm pulley
Methanol Injection via Howerton Engineering and Aquamist HFS-3
Brembo 355 Front/345 Rear/Drilled Rotors
3.45 Dinan Differential
Brecus Stage 4 Feramic Clutch
Ground Control Coilovers
Fikse Profil 5s/PS2's
Dinan RSB w/ Beastpower Brackets
Muffler Delete with TimmayTips
UUC SSK w/ DSSR and ZHP Shift Knob
0-1320' in 11.72 @ 121.04
Clemster is online now   Reply With Quote
Old 10th May 2012, 15:48   #75
AlBundy
AlBundy's Avatar
Garage: 2003 M5
Sales Feedback: (3)
Computer still broke. I can't multi quote.
I understand what you are telling me. I can imagine rods flying everywhere in extreme conditions.
If the owner just bought the car, cruising at 55-60mph (5th gear ~ 2,500rpm/6th gear ~2,000rpm) shifted in to 2nd gear by mistake, I don't think this would happen.
I feel terrible for the owner since I don't think he or she was the cause.
AlBundy is offline   Reply With Quote
Old 10th May 2012, 16:43   #76
JoeFromPA
Garage: 2001 Carbon Black/Caramel M5
Sales Feedback: (3)
Wow, that flywheel coloration is surreal. That should be in a motorsports museum on a pedestal
2001 Carbon Black on Caramel - 121k miles (4/2/2013)
JoeFromPA is offline   Reply With Quote
Old 10th May 2012, 16:51   #77
rao
Garage: Silver 540i
You guys need to get out more
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is online now   Reply With Quote
Old 10th May 2012, 17:16   #78
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Should be easy to check, and get Adam's hands dirty with a rod bearing DIY, you know there's demand for that in the NorthEast.
Hey, it's fun playing keyboard detective.
Old 10th May 2012, 18:53   #79
mattmartindrift
Garage: 540i
Now that you say that, I think I'll run to the local home-improvement store for some rock salt and floor tiles.
Old 10th May 2012, 18:57   #80
rao
Garage: Silver 540i
Don't use rock salt, it is the wrong gauge at least then you would be accomplishing something
The Following User Says Thank You to rao For This Useful Post:
02tiag (14th May 2012)
S85 connecting rods bemone E60 M5 and E61 M5 Touring Discussion 4 12th January 2011 14:05
E39 For Sale: Used S62 Factory Connecting Rods BayE36Area Parts / Other For Sale or Wanted 2 10th February 2010 22:42
Used S62 Factory Connecting Rods BayE36Area E39 M5 and E52 Z8 Discussion 0 24th January 2010 20:12
Wanted S38 3.8 Connecting Rods (not stock) jibbajabba E34 M5 Discussion 3 30th October 2009 12:14
connecting rods from ebay dalius Parts / Other For Sale or Wanted 5 10th August 2006 12:12
