540i Transmission INTO E39 M5? - BMW M5 Forum and M6 Forums
Like Tree22Likes
Old 24th April 2012, 16:36   #1
E39_GixxerThou
Garage: 00 E39 M5
I have a problem with my transmission in my 2000 M5, I came across a thread where a transmission from a 540i will work. According to realoem and few places its the same part number, same transmission with few different internal parts. Is the transmission ratio the same? Has anybody bolted one up to an M5 and have it work fine? What is needed to be modified before it working flawlessly? What is the SHIFTER POSITION SWITCH?
E39_GixxerThou is offline   Reply With Quote
Old 24th April 2012, 17:15   #2
Strike
Strike's Avatar
Garage: 2002 Jet Black
I could be wrong but I believe I read once that the ratios are in fact different. I would assume the shifter position switch is the gear indicator switch on the side of the transmission near the reverse switch. One of the electrical connections that has to be removed before pulling the tranny.
2002 Jet Black/Imola Red Sport
Dinan Stage I Software
K&N Filters - Brake Ducts
K40 Undetectable
AXXIS ULT pads
Black/White CF Roundels
Body Color Grills
Greyscale ///M Logos
Smoked Tails
30% Tint
Intravee II
Strike is offline   Reply With Quote
Old 24th April 2012, 17:17   #3
E39_GixxerThou
Garage: 00 E39 M5
Thats what I figured and i read from a member that tapped into the 540i tranny said he would just skip it if he was to do it again!
Old 24th April 2012, 17:23   #4
Strike
Strike's Avatar
Yes, I think TIS refers to it as a gear detection switch. I don't know too much about it personally but I would assume it probably doesn't sense if the transmission is in each particular gear but maybe more which gate the shifter is in. Or just that it's in a gate vs. being in neutral. I'm not sure of the function of the switch but my best educated guess would be that it works alongside the clutch safety switch to make sure the starter won't engage while the car is in gear with the clutch let out.
Old 24th April 2012, 17:25   #5
meepmeep
Garage: 2002 M5, LeMans Blue
Pretty sure the ratios are the same. The 540 has a different final drive. Why do I suspect a run on 540 transmissions...time to stock up.
meepmeep is offline   Reply With Quote
Old 24th April 2012, 17:25   #6
E39_GixxerThou
Garage: 00 E39 M5
Right. Obviously we dont have gear indicators on the cluster like automatic cars do, but he said he would have done it without tapping into the transmission. I think itll work without the switch but not 100% sure!
Old 24th April 2012, 17:25   #7
rao
Garage: Silver 540i
No info about the switch, but this is interesting:
Gear ratios on Getrag
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is online now   Reply With Quote
The Following User Says Thank You to rao For This Useful Post:
bibledriver (1st May 2012)
Old 24th April 2012, 17:28   #8
E39_GixxerThou
Garage: 00 E39 M5
Ive read in a few different places the ratios are the same, they just carry a few different internal parts, and the M5 is more "beefier"
Old 24th April 2012, 17:30   #9
meepmeep
"Beefier" until it gets stuck in 2nd.
Old 24th April 2012, 17:31   #10
Strike
Strike's Avatar
Looks like my guess on the switch is right. Read this thread:
fault code 80 "Switch Chain, Frictional Connection
I'm assuming the person in that thread you were reading said they wouldn't bother going back because it was going in a race car. According to this you would most certainly get a fault code and possibly even idle issues according to Raikku without tapping and adding that switch.
E39 Want to buy: Automatic transmission DINAN chip e39 540i blacktop540i Parts / Other For Sale or Wanted 0 30th May 2011 20:28
E39 540i or M5 vatechguy3 E39 M5 and E52 Z8 Discussion 34 1st August 2008 04:00
WTB - Transmission from a '94-95 540i Sport gra8fuldd ed Parts / Other For Sale or Wanted 2 27th December 2005 21:49
Been offered a 540i with "blown transmission" IvanDias GTBoard.com: General Sportscars 4 28th May 2002 10:52
