Engine gremlins after thermostat - Page 3 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 24th April 2012, 19:58   #21
gherardini
gherardini's Avatar
Garage: 2002 M5 Titanium Silver; '03 540iT ///M Sport
Sales Feedback: (5)
Originally Posted by Sailor24 View Post
You need to have that # for the CPS code because the description is likely wrong. The scanner was using this list
Attachment 155317
It should have been using this list but you can use it now
Attachment 155319
I would suggest you look at the plug for the vanos board bank two, guessing it is unplugged or maybe the wires to it have been pinched, then again if the car was sitting, mice love the taste of M5 wires.
no mice. i'm certain of that. but the VANOS mention makes me think that maybe i dorked something up when i put the VANOS crossover back together when i replaced the thermostat. i remember that i forgot to torque the bolts back on and covered the engine compartment and a bit of the garage floor with oil that spurted out of the two bolted cables. cleaned all that off the engine for about an hour.... possibility i messed up there? but it still brings back the question that it worked fine when i ran it in the driveway to burp the coolant system and then shut it down to pull the bumper off.
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- CNS Racing clutch
- PowerChips
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Predator ICE v2.1
- Xenon fog lights
- Steath Auto Turn Signal Bulbs
- TC Designs Sway Bar Brackets
'03 540iT ///M Sport Edition
'87 K75S - "Maybellene"
Sierra Vista, AZ
gherardini is offline   Reply With Quote
Old 24th April 2012, 20:07   #22
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Cold idle has a different setting in the Vanos, the vanos on shut down puts the vanos in start up position. Depending on which noids are firing it may not have been able to go back to start up position.
Sailor24 is offline   Reply With Quote
Old 25th April 2012, 06:18   #23
gherardini
gherardini's Avatar
Sales Feedback: (5)
Well.... mischief managed.
As I said initially, it's a rule that the first place you look is the last place you screwed with. It's also a rule that the simplest solution is the one to look at first [OK, I stole that from Occam's Razor]
With josiah's input from all the codes the vehicle was throwing, it made me think that there was simply too much going wrong with the car at once after running perfectly and sitting for 4 weeks. Therefore, it *had* to be something stupid. Some loose cable or something.
So I put the car up and got underneath with a flashlight and looked at all the connectors surrounding the coolant drain plugs and the CPS sensors. Everything looked good and I resnapped the CPS sensors just for good measure. Then I took a look at other places I screwed with when I changed the T-stat and there was a connector directly beneath the elbow of the driver's side MAF intake. I lifted the intake, touched the connector and found it loose. I resnapped it together, with a click this time, started the ///M and she purred instantly!
Damn, I hate it when it's the little things.... But thank you everyone for all of your input. I greatly appreciate the time you took to help me solve this little gremlin. I need to go for a drive....
The Following User Says Thank You to gherardini For This Useful Post:
Calluhan (25th April 2012)
Old 26th April 2012, 06:53   #24
jimmythefish
jimmythefish's Avatar
Garage: 2001 BMW M5 LeMans Blue/Caramel
Sales Feedback: (11)
Glad you got your car back Robert!
2009 M6
2001 M5: Dinan: Front & Rear BBK, Stage 3 JRZ suspension,Front/Rear strut braces, Headers, Throttle bodies, Vertical stacks, CAI, MAF housings, Stage 5 software, Rims, Floor mats. CNS Racing clutch, Autoillumination interior LEDs, MKIV, Bluetooth retrofit, Intravee
2001 750il Intravee, MKIV, Bluetooth retrofit
jimmythefish is offline   Reply With Quote
Old 26th April 2012, 16:45   #25
VacMan
VacMan's Avatar
Garage: Jet Black '00 ///M5, E30 cabrio, Land Cruiser
Good news!
Sent from my DROID BIONIC using Tapatalk 2
2000 E39 M5 | Stoptech brakes | Refinished OEM wheels w/10mm spacers | Powerchips Gold 91 | Timmay Tips/muffler delete
DICE MB1500 | Slimm's rear diffuser | Cubic black trim w/ Slimm's alcantara boots | 545 shifter | BC Coilovers 8k/6k
VacMan is offline   Reply With Quote
Old 26th April 2012, 17:23   #26
Ponyboy
Garage: 2000 BMW M5 Avus Blue
That's awesome. Congrats and kudos to figuring it out. Not many would be that determined.
Ponyboy is offline   Reply With Quote
The Following User Says Thank You to Ponyboy For This Useful Post:
gherardini (26th April 2012)
Old 26th April 2012, 18:49   #27
gherardini
gherardini's Avatar
Sales Feedback: (5)
Hi, Jim! Looks like you've been keeping the Mod bug busy. Nice job!!
Question regarding thermostat and check engine light going on/off Jdog_M5 E39 M5 and E52 Z8 Discussion 18 22nd December 2011 01:48
Electrical Gremlins... HELP!?! thebeef74 E39 M5 and E52 Z8 Discussion 17 13th May 2010 08:18
Where is the thermostat for the engine oil? ilundber E34 M5 Discussion 11 22nd February 2005 20:36
Gremlins! tripleD E39 M5 and E52 Z8 Discussion 8 29th January 2005 00:50
Gremlins ! mjlandy E39 M5 and E52 Z8 Discussion 2 20th October 2002 17:58
