3rd April 2012, 23:51
#1
2000 m5 silverstone
Couple codes - 26 and 28 on Peake reader
Scanned the car no SES light but got 26 and 28 cyl 5-8 oxygen sensor - heater control ????? Never had this one before any one know exactly what that is ??
2013 Subaru wrx Cobb tuned Daily beater
2009 135 "Worlds First Frozen 1ER" ESS Tuned stage 2
RIP MFIZZLENYCMOBILE - 12/5/2012 2000 Silverstone M5 extended Leather
213,500 miles !!!!!
Evolve Stage 3 Tune
BBS LMs 19s Michelin Pilot Super Sports ,StopTech BBK,Dinan Headers, CF Plenum cover with clear windows, Dinan CF -CAI,Dinan Air Mass Meters ,Dinan light weight flywheel,Dinan stage 3 suspension ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
4th April 2012, 00:06
#2
2000 Anthracite,
Have you been under the car doing any work?
4th April 2012, 00:22
#3
2000 m5 silverstone
Yes just had the rear subframe bushings done
4th April 2012, 00:29
#4
2000 Anthracite,
If the O2 were unplugged my bet is the drivers side got plugged back in incorrectly. It is not to hard to do the two feeds plug together nicely and the two senors do the same. With all the direction changes it looks perfect then all of a sudden O2 heater codes. A lot of us have done it. Check that first, it is logical. The heaters (4) all run from the same fuse so that is not it and to lose both pre and post sensor heater circuits at the same time is against the odds also. Possibly they just got knocked free during the work.
The Following 3 Users Say Thank You to Sailor24 For This Useful Post:
4th April 2012, 01:05
#5
Super Moderator
When I saw this I though 'yes, O2s not connected- you get a heater error immediately and the DME never checks past this point'...
but why no SES light??!?!?!
The Following User Says Thank You to ard For This Useful Post:
4th April 2012, 01:59
#6
2000 m5 silverstone
Thanks sailor !!! I'll bring the car to the shop in the am and put it on the lift
I'll get back to the thread once I find the issue
Ard I'll Pm you later about why no SES
4th April 2012, 03:02
#7
Super Moderator
Originally Posted by mfizzlenyc
T
No need. Assume: With stock programming you will have SES light set. If programmed to ignore O2 sensors you will not get a light.
4th April 2012, 03:06
#8
2000 Anthracite,
Even with stock no light or other O2 codes???? Maybe because we check so fast after working on our cars and O2 code would be slow response and that takes several attempts and different tests for DME to diagnose.
4th April 2012, 16:46
#9
2000 m5 silverstone
Gotta hand it to you you were almost spot on!!! what happened is I plugged the drivers bank O2s together instead of to the car  uich:
Thanks Sailor for the help the car is running super strong again sometimes I have to question myself why I want to supercharge her
4th April 2012, 17:13
#10
M5 E39 Supercharged
He was SPOT ON, rather than almost....!
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
