500 miles, a new clutch and a ride in the Clemstermobile all in 16 hrs - BMW M5 Forum and M6 Forums
Like Tree16Likes
Old 3rd April 2012, 04:34   #1
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Two seasons and 23k miles later, I can honestly say my Beast is faster, stronger and healthier than ever. Before unleashing it on the track, there's just one more order of business, a new clutch. I came across member InfamousQ's thread about a RMS fix and got in touch with Clemster himself. Although it was 250 miles away, after chatting with Adam a few times, I was confident he was da man for the job.
The day finally came, and by 10am, I was already past the Delaware Memorial Bridge, after another hour, I found myself traveling the rolling country sides of beautiful Maryland. Adam was kind enough to leave a pair of cone markers knowing that I'd overshoot the driveway amist the zealous drive, so without further adue, I present you The Clemster Garage.
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
The garage is so huge, it can literally squeeze 6 E39s under its roof and hold a party with a fully stocked fridge and a big screen TV. After shooting the breeze for about 30 minutes, we put the car on the lift (a 9000 lb capacity, even beefier than some I've seen at Indys) and proceeded to pull the one piece factory exhaust, fortunately none of the studs broke, but I can't say the same about my back muscles.
The exhaust must've weighed more than 150 lbs, notice the red tapes Adam tagged to mark the pre vs post cat O2s, yes they do plug into each other's harnesses.
We unbolted the giubo side of the driveshaft, what a crack, I actually felt a vibration under the center console on the way there, good thing I had a new giubo and tranny mounts.
By then it was high noon, Adam jumped out of his overall and we hopped into the famous Clemstermobile to head to lunch. For those unfamiliar, this Beast holds the world record for 1/4 mile ET of all non-built (sleeved engine, etc.) E39 M5s, a blistering 11.72 @ 121mph. The car is immaculate inside and out. When we finally reached an isolated stretch of road, Adam dropped it in 2nd gear and gave it the beans, the PS2s immediately lit up for a good few seconds. Pop it into 3rd, stump on the gas, and the animal took off with ferocity only known to American muscle, upshift to 4th and the urge to lunge forward continued, stronger than my car in 3rd. I couldn't pay attention to the boost gauge, but this was without a doubt the most powerful E39 I've riden in. The Dinan differential and meth injection sure all helped, but I'm convinced this car can use some wider tires than stock.
By the time we got back, the transmission had cooled off to the touch. BMW engineers must have wanted to test people's will when they designed the location for some of the transmission bolts. Aside from the obvious ones on the bottom, starter bolts (marked in blue) and a couple with backing nuts that only a contortionist could reach, the two top bolts required a myriad of different extensions and swivel joints. Adam did all that in a breeze, after all this is his 5th or 6th time dropping an E39 M5 tranny.
The old pressure plate, clutch, flywheel and rear main seal all came off, pretty standard stuff. I took a moment to take a peek in the engine upper oil pan, saw a few mains and a couple rods staring in my face. Adam then pulled the pilot bearing and we noticed it was completely shot, rotating with a course audible noise. We proceeded to replace the parts in the front of the transmission, in addition to the clutch fork, ball pin, spring clip, and throw out bearing, I also opted to replace the guide bush which the TOB rides on. Adam applied a thin film of teflon for extra smoothness, I know BMW does not recommend applying grease, but this was not grease, and let me tell you, after 500 miles with the new clutch, it rides buttery smooth.
I took this chance to refresh an assortment of shifter bushings, many of which are only accessible with the tranny out of the way. I noticed the padding in the bushing kit on the front end of the selector rod had disintegrated, this definitely contributed to shifter slop. The new one did not require the yellow washers, much like the E60 SSK. I also replaced the selector rod rear end bushing which cost something ridiculous like $70. That old rubber insert had gone soft, so in the new one went. I attempted to replace a pair of dimpled bushings on the folk end, but that sucker was so tough even my swiss army knife could not cut it through. So far, I've noticed the shifts are more immediate, and precise, side to side slop has been eliminated by 75%, I think it may be the best it's been since new.
Adam scuffed up a lightly used OE flywheel which I acquired from a fellow member, and bolted it down plus the new clutch. Adam had all the critical torque values on a sheet and went over each bolt twice. Of course during all this, I probably asked a hundred questions, but Adam was very patient. We then bolted the transmission back on, and swapped in a new slave cylinder and did a power bleed. Lastly, we hauled the exhaust above shoulders with what little energy we had and bolted it back on. The thought of holding the muffler end of the exhaust for more than 20 seconds overhead still has my deltoids and oblique muscles cringe.
In all, we did a whole lot in a span of less than 8hrs. Finally, we knocked back a few cold ones, it was getting dark, and I had to be on my way. The new clutch felt so smooth, it starts engaging as soon as you lift the pedal, and the effort is so much softer than before. I stayed between 2500 to 3500 rpm throughout the trip, giving a few cars the misinformed impression that they can hang with an E39 M5. Soon enough, I hit the New York City traffic on a Saturday night, perfect time to break in the new clutch.
Overall, I had a great time working and learning alongside Adam. For anyone who has a big job for their M5, I highly recommend giving Clemster a call, can't beat top notch service and fair rates. Adam, it was truly a pleasure and I look forward to Clemsterfest this fall!
The Following 11 Users Say Thank You to bimmerule For This Useful Post:
chowdah (3rd April 2012), Clemster (3rd April 2012), El Diablo (30th April 2012), herrubermensch (3rd April 2012), intrepid one (3rd April 2012), josiahg52 (30th April 2012), Kelster (18th April 2013), M5 London (3rd April 2012), mister2d (29th April 2012), pjfox23 (3rd April 2012), sor118 (29th April 2012)
Old 3rd April 2012, 10:05   #2
Kevin The Clean 1
Kevin The Clean 1's Avatar
Garage: 2002 BMW M5 (Sterling Gray)
Sales Feedback: (10)
bimmerule,
I love the fact that he put two cones out for you... haha
Kevin The Clean 1 is offline   Reply With Quote
Old 3rd April 2012, 10:31   #3
jamiepeers
jamiepeers's Avatar
Garage: E39 M5 Carbon Black
Nice.
I especially like attention to detail about shifter bushings etc whilst you have access.
Any chance of a brief rundown of those parts?
I haven't replaced my clutch yet but i'm sure the time will eventually come. It'd be nice to be forearmed with that info
jamiepeers is offline   Reply With Quote
Old 3rd April 2012, 14:22   #4
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Originally Posted by jamiepeers View Post
Nice.
From this photo :
The parts are most likely Sub Group 7 and also 10:
From this photo :
The parts are 12, 13 and 14 (separated out) AND also a new Sub Group 7 seen in the extreme top of the photo
All well worth changing, and I am thinking about changing them all the 2nd time around now, approaching 30K / 40K Miles now on the replaced bits !
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
The Following 2 Users Say Thank You to M5 London For This Useful Post:
bimmerule (3rd April 2012), jamiepeers (3rd April 2012)
Old 3rd April 2012, 14:47   #5
intrepid one
intrepid one's Avatar
Garage: '01 M5 Carbon Black
A great write-up. I had the opportunity to visit Adam's garage in January and you are correct, he is better equipped than a lot of Indys..I am at the point where I am going to freshen up my car, with what sounds like an almost identical routine to yours. I have been in touch with Adam, and we have put together a parts list..The timing is yet to be decided, but I am really looking forward to the trip. We are so fortunate to have members like Adam to assist in making our cars live longer and maintain their performance..I hadn't thought of the shift linkage refresh, and will fire off a note to Adam…S
intrepid one is offline   Reply With Quote
The Following User Says Thank You to intrepid one For This Useful Post:
Clemster (4th April 2012)
Old 3rd April 2012, 14:56   #6
rao
Garage: Silver 540i
Looks like fun
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is online now   Reply With Quote
Old 3rd April 2012, 15:02   #7
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
Originally Posted by Kevin The Clean 1 View Post
bimmerule,
you'd understand if you saw how hidden the driveway is. it's at the top of a crest, just after a slight kink in the road and the driveway immediately drops away from the main road making it almost 100% hidden. I've been there countless times and still almost miss it.
mattmartindrift is online now   Reply With Quote
Old 3rd April 2012, 15:53   #8
Quicksilv3r
Garage: 2005 Mercedes-Benz E55 AMG Kompressor Black/Black
Sales Feedback: (6)
I'll be honest, I missed his drive even with the cones/flags/signs at clemsterfest. I was a bit over zealous comming arond that last bend.
2005 Mercedes E55 ///AMG Kompressor - Black/Black
Black Birdseye Maple Trim
Bi-Xenon Active Headlamps
DVD Navigation w/ iPod Integration
Harmon-Kardon Premium Sound
OEM 19" CLS AMG Wheels
OEM E63 AMG Front-End Conversion (bumper/grille/fog lamps)
OEM E63 AMG Rear Boot Spoiler
OEM AMG 'Afalterbach' Flush-Mount Hood Emblem
Brembo GT BBK 380mm (Front) 345mm (Rear)
Renntech Ride Control Module
MP Design DTM-Style Steering Wheel
Oversized Heat Exchanger
Michelin Pilot Super Sport Tyres
Huper Optik Window Tint 50% (full windshield/sunroof/sides/rear)
Can-Bus Xenon White LEDs (city lights/interior/trunk/license plate)
Can-Bus 6000K 35W HID Fog Lamps
Need an honest BMW service center to wrench on YOUR M5?
Stupid to buy an AMG and not drive it, it's like paying a hooker for a hug.
Quicksilv3r is offline   Reply With Quote
Old 3rd April 2012, 16:20   #9
AlBundy
AlBundy's Avatar
Garage: 2003 M5
Sales Feedback: (3)
Awesome write up .
Sooo... What's the minimum number of posts before one can contact Clemster?
AlBundy is offline   Reply With Quote
Old 3rd April 2012, 16:28   #10
al-x
al-x's Avatar
Garage: No replacement yet
Adams garage is as close to heaven many of us will come! Awesome guy overall
al-x is offline   Reply With Quote
E39 For Sale: 2000 M5 CARBON BLACK/BLACK $17,500 -- 86,500 Miles Medero5 Cars For Sale or Wanted 8 23rd October 2010 00:14
M5 Touring bought "BMW Approved Used" @ 2,500 miles, car now 5,100 miles showing brake fluid needed willbrocklebank E60 M5 and E61 M5 Touring Discussion 13 23rd April 2009 23:22
Black M6 delivery, 54 hrs and 1,218 miles! MaxTimeOff E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 25 29th June 2006 20:42
Black M6 delivery, 54 hrs and 1,218 miles! MaxTimeOff Owners Gallery 11 26th June 2006 11:26
48,500 miles and need a new clutch - Options? INVICTO E39 M5 and E52 Z8 Discussion 1 25th January 2003 03:26
