Car cranks but won't start - BMW M5 Forum and M6 Forums
Old 24th March 2012, 19:10   #1
Mattkins99
Mattkins99's Avatar
Garage: '01 Lemans Blue M5
Went to Starbucks in the morning, came out and the car wouldn't start. It cranks over fine, so I know it's not the battery. I unplugged the MAFs thinking that might be the issue but it still didn't start. I eventually had the car towed home thinking it's fuel related.
125k on the car.
Fuel filter was replaced within the last 15k
Fuel pump is probably original
Not sure which relay is the fuel pump relay... I need to dig out my Bentley manuals (I'm assuming it's the same as any other E39...)
Any thoughts? I pulled the codes and saw nothing fuel related (Secondary air injection code... and a CPS code that I haven't gotten to yet.)
-Matt
Matt Atkins
'01 Lemans Blue M5 :-)
-Dinan CAI
-Dinan Stage 2 software
'01 Titanium Silver X5 4.4
Mattkins99 is offline   Reply With Quote
Old 24th March 2012, 19:14   #2
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
Fuel Pump is done...
2013 Subaru wrx Cobb tuned Daily beater
2009 135 "Worlds First Frozen 1ER" ESS Tuned stage 2
RIP MFIZZLENYCMOBILE - 12/5/2012 2000 Silverstone M5 extended Leather
213,500 miles !!!!!
Evolve Stage 3 Tune
BBS LMs 19s
Michelin Pilot Super Sports ,StopTech BBK,Dinan Headers, CF Plenum cover with clear windows, Dinan CF -CAI,Dinan Air Mass Meters ,Dinan light weight flywheel,Dinan stage 3 suspension ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
mfizzlenyc is offline   Reply With Quote
Old 24th March 2012, 19:16   #3
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
+1. Try kicking the right quarter panel, if the car starts again for a couple times, that's your writing on the wall.
Old 24th March 2012, 19:21   #4
Mattkins99
Mattkins99's Avatar
All of a sudden like that? I figured I'd see other signs first or at least codes indicating lean conditions or something. Any way to test it?
I was thinking with the fact I had no related codes, maybe there were other ideas... on the plus side, the fuel pump is relatively easy and cheap so at least you're not thinking something worse :-)
Old 24th March 2012, 19:23   #5
Mattkins99
Mattkins99's Avatar
Anything less likely to scratch or dent the car :-) No way I'm going to go out and kick my car... my truck sure, I've done that many times, but not the M5 :-P
Old 24th March 2012, 19:26   #6
mfizzlenyc
mfizzlenyc's Avatar
when Mine went it was out of the blue I just installed headers and the matching tune drove the car for a day came home from work changed got back into the car it cranked and cranked and nothing to get it going... don't keep cranking it or you will have to clean the fuel lines and tank for metal shavings from the pump it could be a relay but its most likely the pump...
Old 24th March 2012, 19:38   #7
bimmerule
bimmerule's Avatar
Sales Feedback: (8)
Yes, try tapping hard with your hand. Sorry don't know why my first reaction was kick
Old 24th March 2012, 20:24   #8
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Access your fuel filter and on the regulator house is a valve similar to your tire push that in and see if you have fuel pressure. Ideally you would hook up a fuel pressure gauge but... if you hold it until you have no pressure then try and start the car again if the fuel pump is working it will re-pressurize.
Sailor24 is online now   Reply With Quote
Old 24th March 2012, 21:26   #9
Silent
Silent's Avatar
Garage: E39 M5 WBM
Sales Feedback: (9)
Sounds like a fuel pump
DA Machine /// 2002 Blue WM Sport Package
Drive-Train
RK Stage II S/C, FMIC
| RK Oil Cooler |CA Automotive CNC Plenum Plates | Supersprint Headers| Custom X-Pipe | DINAN Front & Rear Strut Bar | DINAN Front & Rear Sway Bar | DINAN 3.45 Limited Slip Differential | Beastpower Brackets | Spal Custom Electric Fan | Kelleners Race Exhaust 83MM| KW Variant 3 | UUC Trans Mounts | BBS CH-R Front 245/35/20 /Rear 275/30/20 | Wrapped with Michelin Super Sport |Front: Brembo 8 piston 380x34mm | Rear: Brembo 4 Piston 345x28mm |
Exterior
ACS Splitters | ACS Diffuser | ACS Mid Spoiler | Hamann Fog Light Inserts | 6000K Xenon Headlights/Fog Lights | Euro Hella Headlights | Umnitza Ice |
Interior
B&M Short Shifter | ACS Pedals |MKIV Nav | Valentine1 1.8 w/Euro Pop Hardwired | Custom 3-pod Ashtray Gauges |
Not to far in the distant future Forged S62 **Looking for Le Mans Blue E39 M5**
Stable
2009 R1 (rebuild in process)
2004 Imola X5 4.8is
2003 Cl500 AMG
- Daily Driver
Sold
2009 550i Alpine White Sport M-Package
2008 550i Alpine White "Lemon"
///M1 Autowerks
"From Vision to Reality"
Silent is online now   Reply With Quote
Old 24th March 2012, 22:04   #10
jfoj
Garage: 2003 M5 Sterling Gray & 2006 330cic (Vert) Silver Gray
Welcome to the club.
The pumps usually leave you stranded without warning.
Suggest you try Direct BMW and Mercedes Parts and Accessories, good pricing and usually they can ship overnight for about $15 if you need it quickly?
Suggest a fuel filer and fuel pump relay while you are at it. Fuel pump relay is not interchangeable with other relay in the car like the E46, so you might consider a replacement? If you get a replacement relay, put the original in a plastic bag and wedge it in between the wiring and relays so you have a future on board spare on for a fellow board member in the future!
jfoj is online now   Reply With Quote
Car cranks but wont start randomly. elcabron E39 M5 and E52 Z8 Discussion 44 17th November 2011 03:50
E34 M5 Cranks but Won't Start-Help! hemi4me E34 M5 Discussion 5 17th June 2011 21:21
Car won't start! steveM5 E39 M5 and E52 Z8 Discussion 11 21st June 2010 15:19
Help - Car won't start 2002silverbeast E39 M5 and E52 Z8 Discussion 14 8th January 2010 18:35
2001 M5 Cranks but won't starts!!!! HELP!!! rrdaniel E39 M5 and E52 Z8 Discussion 3 9th August 2009 01:55
