• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 24th July 2002, 14:30   #1 (permalink)
          Adam
          Adam's Avatar
          Send a message via ICQ to Adam
          Vanos problem...an obvious problem which dealer says aint there..help needed
          I need to draw from the whole board on this one.... We have the Vanos problem..the rattle diesel sound from a cold start up. The car is not right anyone can tell that. Our dealership after having the car for the day phones to say that there is no problem. I ahve done many searches on the board re: Vanos but i needed to know how if you had the problem your dealer fixed it. So basically I (a 16 year old) can spell it out to them. There is no doubt in my mind it is the Vanos problem even though the car is a 01..
          Any help/advice would be greatly recieved
          all the best
          adam
          1995 Alpina B8 4.6 #10-(engine blew up. sold)
          2001 BMW ///M5(sold)
          2003 RUF R turbo
          1990 RUF CTR
          2006 VW Golf R32 DSG
          2005 e60 M5 (sold)
          2007 997 GT3 RS Carrara White
          2008 Renault Clio 197
          "You know it is kinda ironic, these old people are being kept alive by the organs of the young people they ran over" - Chief Clancy Wiggum
          Adam is offline
          Old 24th July 2002, 15:28   #2 (permalink)
          Vince5
          Vince5's Avatar
          Adam,
          I have had the Vanos job done early this year. My car is a late 2000 model, I have 40k kms. They did it under warranty, no arguing.....
          How come BMW accepts this in Sweden and not in the UK
          I can fax you the papers if you want to (it's in Swedish but the part codes are there and the price is ZERO)
          Good luck, I heard recently from another board member that BMW has decided to be tougher on Vanos changes
          Cheers
          Vince
          Porsche 911 Turbo 964
          BMW 525i
          Ex M5 kelleners upgrade owner ....
          Vince5 is offline
          Old 24th July 2002, 15:33   #3 (permalink)
          DavidS
          DavidS's Avatar
          I think BMW addedthe oil drain valve to the Vanos in october 2000. Whatīs the build date of your car?
          Also even with the oil drain valve there, something else could be wrong with the Vanos. Those are sensitive things, it seems.
          Did the noise start recently? Do you get it only at startup? Everytime? Sometimes? On cold mornings only?
          Do you have full engine torque?
          David
          DavidS is offline
          Old 24th July 2002, 15:41   #4 (permalink)
          Adam
          Adam's Avatar
          Vince,David
          Your replies are great thank you very very much!
          Vince if you could fax me those papers i would be terribly grateful my fax number is.. 01428727469
          David we get the problem everytime we start the car, it goes away after about 25mins of driving... there is a definite drop in power..noticeable IMHO
          Our car was deliverd to us in april 01 soo id say build date was jan/feb 01 so they should ahve sorted the problems RE: vanos?
          Again thank you very much
          all the best
          adam
          2003 RUF R turbo
          1990 RUF CTR
          2005 e60 M5 (sold)
          Adam is offline
          Old 24th July 2002, 15:53   #5 (permalink)
          Vince5
          Vince5's Avatar
          I'll look for them this evening. If they are at home no prob, if they are in the car I'll try to get them tomorrow. Just so you know I took the car to the dealer because of the "diesel noise". I didn't have any failure or anything and they just changed it without arguing
          Vince
          BMW 525i
          Vince5 is offline
          Old 24th July 2002, 16:04   #6 (permalink)
          Adam
          Adam's Avatar
          Thank you ever so much Vince
          all the best
          adam
          2003 RUF R turbo
          1990 RUF CTR
          2005 e60 M5 (sold)
          Adam is offline
          Old 24th July 2002, 18:14   #7 (permalink)
          DavidS
          DavidS's Avatar
          Adam,
          It might be that you donīt have the usual Vanos noise at startup problem (which is solved by the oil valve), but something different.
          Did this problem occur recently? Abrubtly or gradually?
          How did you demonstrate the problem to the service people?
          Were you there yourself? Was the noise the same as usual?
          Whenever you have a problem which only manifests itself when the car is cold, drive the car to the dealerīs parking lot the day before you have an appointment, leave the car overnight to cool.
          There is a huge thermal mass in these engines, so it takes a long time to really cool it. Switch the engine off, but leave the key on and set the heating to max, fan to max, open all air outlets, and let it blow until the air feels cold. Then switch on the "use residual heater" button. (which takes heat from the liquid salt thermal reservoir in the cooling system and transfers it to the passenger compartment) and let it blow until the air is cold again. Let the car stand overnight. Then get both the service advisor and the technician to come listen when you start the engine and point out the problem.
          It is important to cool the residual heater, otherwise it will warm up the engine quite fast on startup the day after.
          David
          http://www.m5board.com/vbulletin/showthread.php?t=54788
          http://www.m5board.com/vbulletin/showthread.php?t=88323
          DavidS is offline
          Old 24th July 2002, 18:54   #8 (permalink)
          MAVERICK
          MAVERICK's Avatar
          Excellent suggestion to make sure the engine is as cold as can be the next morning!
          "Friends don't let friends drive automatics!" -- Alpinadvl
          MAVERICK is offline
          Old 24th July 2002, 20:29   #9 (permalink)
          DavidS
          DavidS's Avatar
          Maverick,
          Thanks!
          David
          DavidS is offline
          Old 24th July 2002, 21:00   #10 (permalink)
          DavidS
          DavidS's Avatar
          Adam,
          When you did your searches, you probably realized there are several things that can be wrong when you get the "diesel sound".
          Also in my experience, denial is the common tactics among many a car dealer. There is always a fine line between what should be fixed under the warranty, what might be fixed under warranty, and what should not be fixed under warranty. I think the dealers are monitored by BMW and if they do too much warranty work, itīs not appreciated by BMW. So if they can convince the customer all is well, the noise is normal, donīt worry etc perhaps nothing will break until after the warranty has expired.
          (...being paranoid is such fun, you know...)
          On the other hand, it is normal for cars to get noisier as time goes by.
          Something just occured to me: have you noticed incresed noise from the road, especially when it is raining, too?
          If so it might just be the rubber door-seals which have gone a bit dry, thus letting more noise into the passenger compartment. In that case the fix is to rub a moderate amount of BMW "Gummipflege" into the door-seals once a month or so. That stuff would cost you some five quid for a tube that will last you a year or so. Gives an amazing reduction in passenger compartment acoustic noise level.
          How to do it:
          1. Clean the rubber seals carefully
          2. Dry well
          3. Rub Gummipflege onto/into the rubber seals carefully, both on the visible sides as well as the part normally not seen of each rubber seal. You need to rub it in a bit (gently), not just smear it on. Donīt forget the trunk and bonnet seals.
          4. Let it sit a while with doors open
          5. Let it sit overnight with doors closed
          6. Wipe off excess from seals and where the seals meet the body when the doors are closed
          7. Repeat steps 5-6 for a day or two
          Another thing which might help reduce noise is to have the door locking mechanisms (striker plates) adjusted.
          When they get everything just right the 5-series are quite quiet cars on the inside.
          Anyway, as a general rule, with any car problem: if you arnīt pleased with one dealerīs service department, get a second opinion somewhere else. Just donīt mention youīve already been at the first dealer.
          Best Regs,
          David
          DavidS is offline
          Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
