PA Soft BMW Scanner 1.4.0 Review - Page 4 - BMW M5 Forum and M6 Forums
 24Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
post #31 of 349 Old 21st March 2012, 11:13 PM
jfoj
2 words for you rao, and they are not nice!!
One thing I need to put out here that I forgot to mention, there is a more expensive PA Soft type cable from xcar360 called the BMW Dash Scanner 3 in 1 or something like that. Search their site, you will find it. It is the PA Soft BMW Scanner 1.4.0 and 2 other software programs and the same cable for around $185 or something like that. It is supposed to support some of the newer E9x platforms and others.
This is actually what I purchased and I am using now as I anticipate I will run into the newer platforms from time to time.
Here is a link for the BMW Dash Scanner - BMW Dash Scanner 3 in 1-bmw scanner-Online Shopping
jfoj is offline
post #32 of 349 Old 22nd March 2012, 12:31 AM
timmay77
timmay77's Avatar
That's super cheap for what it does! The dealership wants $50 per use to change options......
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap.
The Family Wagon:
2008 Deep Blue Sea Pearl/Caramel Sport 535xiT (FMLYWAG)
~JB4~DCI~Burger Tuning OCC~RB PCV Valve~RB intake pipes~VRSF 7" FMIC and DP's~DIY CP with TiAL BOV~New stock turbos at 99k, DIY'd~M5 front bumper~ISC Coilovers
SOLD, but not forgotten.....
2001 Jet Black/Executive Black///M5 ("M CINCO"):
~RMS Stage 2 SC Kit with a Fabtech-Performance Heat Exchanger~Tuned by Tuning Tech FS-596hp 520lbstq at the rear wheels~AEM methanol injection system~Complete aftermarket stereo system w/Alpine INA-W910/PXA-H800, Rear Camera, Hybrid Audio Technologies L831 speakers~UUC V12 clutch kit with segmented kevlar clutch disc~Custom crank case ventilation system~Cutsom dual electric radiator fan set up~BIP headers~Muffler delete with ///M5 - MCINCO etched "Timmay Tips" LOL~Dinan 3.45 rear differential~Remote oil thermostat/Setrab oil cooler~(4) Dinan 18x9.5" wheels~Brembo BBK 355F/345R~BC Racing coil overs (10k/8k)~Powerflex thrust arm & inner track arm bushings~Dinan RSB ~ Beastpower RSB brackets~Slimmbones finned rear diffuser, XL fog light covers, trunk spoiler, and front lip spoiler.
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
post #33 of 349 Old 22nd March 2012, 12:38 AM Thread Starter
rao
For $49 a click, I will gladly reprogram your whole car
If you find this post unsatisfactory, please add me to your Ignore List so you will not be disappointed again in the future.
---> http://www.m5board.com/vbulletin/pro...?do=ignorelist
Rob
Prior - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Older - 92 325i with Chevy 6.6 LS2/T-56 Power
Oldest BMW - 95 M3 with Chevy 6.6 LS2/T-56 Power
rao is offline
post #34 of 349 Old 22nd March 2012, 04:03 AM
trentmw
trentmw's Avatar
To answer the 64bit Win 7 question, I was not able to get the drivers to load so loaded a XP VM and worked great
trentmw is offline
The Following User Says Thank You to trentmw For This Useful Post:
68FB (22nd March 2012)
post #35 of 349 Old 22nd March 2012, 06:36 AM
xr4tic
xr4tic's Avatar
Can this software diagnose the parking sensors? My PDC errors out, but I don't know which sensor is bad.
John Baas
2001 Anthracite Metallic M5
2003 Silverado SS
Interior
Euro Dash, Slimmbones Euro Armrest, Slimmbones Shifter/Ebrake Boots, F10 M5 Illuminated Shift Knob, UUC EVO3 Shifter, UUC DSSR, UUC Clutch Stop, Autolumination Interior LEDS, JBL MS-8, Alpine MRX-V70, Kicker Subwoofers, Polk/Boston Acoustic Speakers
Exterior
Vorsteiner Power Dome CF Hood, Euro Clear Corner Headlights w/Lamin-X, Umnitza Predator Ice V3, Umnitza 6K Headlight + Fog Light Upgrade, Umnitza V4 Side/Turn/License LEDs, CF Roundels, Black Kidney Grills, Slimmbones BigMouth Lower Grill
Drivetrain
Evolve Alpha-N Tuning, Supersprint Headers/Cats/X-pipe + Eisenmann Race Mufflers, VSL Aluminum Radiator, UUC Twin Disk Clutch, Rogue Engineering Trans Mounts
Suspension
Ground Control Coilovers, Dinan Monoballs, Dinan Rear Sway Bar w/Beastpower Brackets, Dinan Front and Rear Strut Bars, BMW Performance Front Brake Kit, StopTech SS Brake Lines, Black Stock Rims Square Setup
Coming Soon
Custom Oil Catch Cans, Zionsville Radiator Shroud, Supercharger!
xr4tic is offline
post #36 of 349 Old 22nd March 2012, 07:36 PM
trentmw
trentmw's Avatar
I can't say for sure as I don't have PDC, but as a diagnosis tool it only has two options: really simple... gives you the error code; or really advanced... allows you to read the module memory (in Hex of course)
trentmw is offline
post #37 of 349 Old 22nd March 2012, 08:48 PM
jfoj
I will elaborate bit more on the PA Soft tool.
I hope I have most of this correct?
I will see if I can find the cross reference, however, there have been a few claim with manual driver download from the chip manufacturer web site of the 32 bit driver and using it for the installation they have been able to get it to work on 64 bit platforms. I believe the chipset is the same flexible FTDI chipset as in the VAGCom cable? FTDI drivers are readily available on their website.
As for the tool being a scan tool and reading errors. It not only reads and displays DME engine codes, both current and pending, but it also displays all readable modules in the car, provides current and pending codes for the specific modules, allows you to access most, if not all modules installed to program and code them. On some modules if gives you some service type features, such as real time date or auxiliary control.
So for example with regard to the DME the tool will not provide real time engine control data or control. This tool is probably only as good as BMW specific scan tool that also provides shadow codes. Shadow codes are nothing more than clues, as are normal trouble codes. Everyone needs to realize that knee jerking on trouble codes is a bad thing. Many current and shadow trouble codes need nothing more than to be noted, cleared and watched!
As for other modules, like SRS/Airbag module. This tool can read and clear airbag codes. Program or code the airbag module, turn off or on airbags, read real time data like seat belt switches, seat switches and some other parameters. You may be even able to clear SRS module crash data?? This is not something I have tired, but it appears there may be some hooks in the software to to this??
You can perform an instrument cluster LED test, like the Hidden OBC menu, nothing big, but you can to it.
You can alter the Service Interval info so you can change the mileage. fuel used and length of time you oil change reminder follows. I believe??? but I have not tried this yet, is you may be able to fine adjust your speedometer so it reads accurately. As we all know most German cars odometers read accurately with the original wheels, tires and gearing, but the speedometers usually read 10-15% to fast. I think if you get a GPS than can display MPH you can tweak the speedo reading so it is accurate?? But again, I have not fully confirmed this yet.
I cannot recall, but I think you may be able to read in real time steering wheel button activations??
You can read real time date and code/program steering angle sensors.
You can ignore the clutch safety switch.
Enable DRL, but so far have not been able to figure out how to enable only Angle Eyes for DRL? The European DRL is Low Beams, which does turn on the Angle Eyes. Maybe a hex savvy person could figure out how to hack the code to turn off the headlights and leave the Angle Eyes on??
You can turn off and on key features, disable any of the 10 ignition keys, do things with the EWS, tweak alarm settings, turn off passenger side mirror tilt, close windows, sunroof, convertible tops with the keyfob, tweak bulb monitoring, see real time bulb monitoring as I recall??
For radio, NAV and Bluetooth, there are a lot of programmable options, such as NAV language, FM radio behavior, for Bluetooth you can turn the Bluetooth on and off, pair phones, clear phones, change the BT passcode, change the BT discoverable name.
You can also put modules in normal, service and shipping mode. So for people that store their cars over the Winter they may want to configure some modules to shipping mode?? Or if you have a problem you can change the mode.
I know there are many other things I either have not had time to play with or do not have the option on this particular car. Many of the features are car and option specific, so you may not be able to do everything on all BMW platforms.
A useful feature for most modules is the software allows you to pull a data read from a module that you may need to replace, so you copy the configuration of your current GM3 module if you can talk to it, store the file, the dump the original file back into the module so you do not have to fully code it for every option.
There is a hex editor for the brave souls that think they can decipher the program and tweak hex registers. Yes it can be done, but not for the novice or faint of heart!
I believe, you can possibly soft out mileage info to clear a tamper dot?? I have not tried this, but there appears mileage read from the cluster and the DME or where ever the 2 values are stored and you may be able to reconcile or modify these parameters. I have no need to or want to experiment with this feature as if it goes wrong, I would then have issues.
The tool is fairly intuitive, it takes a bit getting used to, but the more you use it, the more you will learn about what it can do.
I have used this tool for maybe a total of 2 hours on multiple cars and this is what I have been able to decipher from its capabilities.
I am no expert in this tool or any of the BMW specific tools, but I thought I would put out there what the capabilities are for this tool.
I find that between this and INPA they are probably the most useful.
Again, INPA can probably be found online for a no cost download, does not have the complexity of the DIS/SSS install and only required a $15 cable.
I hope this info is reasonable accurate and helps out the community here. If I am off base or have something incorrect, please feel free to make comments.
I am doing the best I can to describe what this tool has allowed me to see and in the short time I have had it.
jfoj is offline
post #38 of 349 Old 22nd March 2012, 10:36 PM
BrendanSC
BrendanSC's Avatar
That would be AWESOME. Just yesterday I decided I had enough of my clutch stop and was about to go cutting wires to hack the switch. I will try this out asap
BrendanSC is online now
post #39 of 349 Old 23rd March 2012, 01:07 AM
jfoj
Someone owes me a few beers!!!
If the view count is low, I WILL BE DISAPPOINTED!!
Who said I did not take care of my fellow board members!
This is a sample, not everything, but as they say a picture is worth a few.
BTW, I do not have Windows 7, so no snipping tool, do not ask what I had to go through to get these!
jfoj is offline
The Following 8 Users Say Thank You to jfoj For This Useful Post:
68FB (23rd March 2012), AGM5 (18th January 2013), Bearstone (27th March 2012), bibledriver (23rd March 2012), cura (11th December 2013), jlusby (5th October 2012), S62M5 (6th July 2012), SleeperE39 (31st March 2012)
post #40 of 349 Old 23rd March 2012, 01:10 AM
jfoj
jfoj is offline
The Following User Says Thank You to jfoj For This Useful Post:
BrendanSC (23rd March 2012)
BMW SCANNER CODES MATTYP E39 M5 and E52 Z8 Discussion 5 9th December 2011 11:14 PM
Short review of Carsoft 6.5 OBDII compatible scanner Eric Giles E39 M5 and E52 Z8 Discussion 12 16th November 2011 07:59 PM
E39 M5 Missfire, BMW Scanner v1.3 codes? davidfo E39 M5 and E52 Z8 Discussion 1 11th June 2010 08:47 PM
Graphs: BMW M3 Convertible E93 Launch Control EDC Hard / EDC Soft / Top Down EDC Soft Gustav E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 6th September 2008 09:08 AM
Diagnostics Scanner PA-Soft? grp E39 M5 and E52 Z8 Discussion 2 30th March 2007 07:45 PM
