Oh my thermostat woes.. - Page 2 - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 12th March 2012, 14:30   #11
russap5
russap5's Avatar
Garage: 2001 M5 Jet Black
They have been Behr thermostats like OEM bought from AutohausAZ.com.
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan
CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan
Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler,
Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
DIY Accelerator Pedal Removal
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
russap5 is offline   Reply With Quote
Old 12th March 2012, 15:36   #12
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Did you change the sensor on top of the tstat housing?
When I had a bad tstat, I would get the 69 Peake code. Any codes?
gsfent is online now   Reply With Quote
Old 12th March 2012, 15:45   #13
technician117
technician117's Avatar
Garage: 2000 M5 Anthracite
Sales Feedback: (5)
If the OP can't physically get heat from the vents than his problem is NOT related to any sensors.
The "gasket" is more accurately described as an "inner seal". It seals the open loop from closed loop operation. If the seal is "leaking" it just means that more coolant is passing through the area than it should, which might keep the operating temps too low. 70C seems to be too low for just a leaky seal, that was just replaced too...
Not a quick fix on this one!
Maybe check fan operation? - staying on too much causing excessive air movement?
Does the car seem like it is running rich? Lots of tailpipe carbon?
Tim
UUC ssk
Tubi Catback
technician117 is offline   Reply With Quote
The Following User Says Thank You to technician117 For This Useful Post:
gsfent (12th March 2012)
Old 12th March 2012, 18:21   #14
cab
cab's Avatar
Garage: 2002 LMB/Caramel (sold)
I'm really beginning to wonder if the Behr thermostats aren't having issues. I know Behr is the OEM supplier, but might not necessarily mean they are identical or have identical QA (hard to believe though even as I type it).
cab is offline   Reply With Quote
Old 12th March 2012, 18:50   #15
Jetpilot718
Jetpilot718's Avatar
Garage: M5 / 350Z / 325iC
Mine always warms up to around 82-84*, but it takes a good solid 10 minutes of driving to get there. Is this the same issue, or normal? I'm talking about OIL temp, not WATER temp (which works as most other cars do, and is warm in 2-4 minutes).
My M5 DIY Videos Here: http://www.youtube.com/user/Jetpilot718?feature=mhum
Jetpilot718 is offline   Reply With Quote
Old 12th March 2012, 21:05   #16
jselig
Garage: S/C 2001 M5
Sales Feedback: (4)
Going through this too again. Replaced in November 2010. Failed again in October 2011 and just failed again yesterday. All Behr units from Pelican. Think Im gonna try a BMW oem one this time.
jselig is offline   Reply With Quote
Old 12th March 2012, 22:55   #17
shaunmal
Garage: m5 avus blue
hi i have had the same problem changed the t/stat gave the garage inner seal etc,but i dont think they changed seal and my obc reading does not get above 68, i have changed both sensors i also get the temp gauge shoot up to red as soon as switch of the ignition off and back on it goes back to normal do yo thinks it's a t/stat problem?
shaunmal is offline   Reply With Quote
Old 12th March 2012, 23:30   #18
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
Im assuming you bled the system properly, running the heater at full blast to make sure there arent air pockets in the system. This can manifest as the symptoms you describe when it's cold out.
E55AMG2 is offline   Reply With Quote
Old 12th March 2012, 23:38   #19
shaunmal
hi yes the system was bled, using car yesterday nice sunny day 18 deg c still running cool im wondering if the rubber seal was not fitted?
Old 12th March 2012, 23:40   #20
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
Could be a bad temp sensor
A/C Woes... Mtechnik540i E34 M5 Discussion 4 5th August 2008 02:37
more woes markf E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 14th January 2006 13:06
M3 woes m3man M3 E36 3 9th July 2002 17:59
more woes!!! Andy G M3 E36 25 31st October 2001 11:50
A/C Woes SteveC E34 M5 Discussion 6 5th August 2000 16:17
