Fuel Tank Breather Valve additional parts? - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 8th March 2012, 05:01   #1
Georgia M5
Georgia M5's Avatar
Garage: 2003 Jet Black M5, 1997 Black 540 Sport, 1997 Black M3 4 door
I'm ordering parts to replace the Fuel Tank Breather Valve (#14). Getting the Peake error code. Car has 110k miles.
I've read the DIYs and will replace the plastic L-bow as well, since that's prone to cracks (#17).
What else should I replace? I was not going to replace all the hoses/rubber, unless there are particular ones that are prone to wear.
Also, is it necessary to remove and clean the Idle Regulating Valve (#1)? That valve needed cleaning on my 540. It was a little gunked up at 130k, but it's a different set-up.
RealOEM.com * BMW E39 M5 Idle regul.valve/fuel tank vent valve
Georgia M5 is offline   Reply With Quote
Old 8th March 2012, 13:18   #2
RideM5
Garage: 2003 CB M5 / Tahoe LTZ
I would clean the idle reg valve, and also replace the fuel vac hose. It goes from the drivers side cabin filter to the bank 2 throttle bodies. There's a diy with pictures somewhere, only takes a couple minutes to replace.
RideM5 is offline   Reply With Quote
Old 8th March 2012, 14:35   #3
Georgia M5
Georgia M5's Avatar
Are you talking about 10 & 11 in this picture? That's $130 worth of hose. Those hoses are plastic lined, and a royal pain to get off. I know because I changed the sister hoses on my 540 when I did my CCV valve. They were in good shape until I started to destroy them to get them off. In retrospec, they did not need to be changed. The hoses have a very hard plastic lining, which is what makes them so expensive.
Is there something about the M5 that makes them go bad?
Old 8th March 2012, 14:48   #4
RideM5
I think it costs about 10 bucks.
Fuel pressure regulator vacuum line replacement
Old 8th March 2012, 15:23   #5
Georgia M5
Georgia M5's Avatar
Got it. I had the wrong hose. I will order this one. Thx.
Old 8th March 2012, 19:36   #6
Mike S.
Mike S.'s Avatar
Garage: "Bugslayer" 2003 M5 TiAg
One thing that really helped me doing this job is a set of LONG-nose needle nose pliers. Like maybe 8". It really helps reaching around down there.
Overall, not a bad job. I did not clean the ICV, but probably should have. I did replace the fuel pressure regulator hose, but didn't really need to once I got in there.
Here's my DIY in case you need it: Fuel pressure regulator vacuum line replacement
El Insecto Asesino - 2003 M5 TiAg / Tuning by Evolve / Exhaust by Timmay77 / ECM by Valentine / Fast by Nature - "She's fast enough for you old man."
What I do in my spare time: Aura Caelestis, Metal Band From Texas. Check us out! Comments welcomed!
Mike S. is offline   Reply With Quote
The Following User Says Thank You to Mike S. For This Useful Post:
Georgia M5 (8th March 2012)
Old 8th March 2012, 20:08   #7
RideM5
For me, trying to pull the hose off with long pliers turned it in to a chinese finger trap, and the harder I pulled the tighter the hose got. Instead, I pushed the hose off with a flathead screwdriver, came off in a few seconds. I think I lubed it up with a little vaseline to get the new one back on.
The Following User Says Thank You to RideM5 For This Useful Post:
Old 8th March 2012, 22:59   #8
Georgia M5
Georgia M5's Avatar
Thanks. I'll check out the DIY. I printed several. And thanks for reminding me about the long needle nose pliers. I had forgotten about them. Fortunately, I've got a good assortment of those long pliers that I never seem to use. Maybe this will justify the money I spent on them way back when.
Old 9th March 2012, 01:06   #9
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
A box of bandages comes in handy with this job, the bigger your hands are the more you need.
Sailor24 is offline   Reply With Quote
Old 9th March 2012, 01:28   #10
Georgia M5
Georgia M5's Avatar
Oh, man, is that what I get to look forward to after removing all those plenum bolts? Not fun.
Help! Stuck Replacing Fuel Tank Breather Valve ArgM8y E39 M5 and E52 Z8 Discussion 6 27th October 2012 20:59
Replaced my fuel tank breather valve, pictures of the job.. rdm190 E39 M5 and E52 Z8 Discussion 16 7th August 2012 03:51
Fuel tank breather valve rog2961 E39 M5 and E52 Z8 Discussion 25 15th June 2012 02:21
Replaced my fuel tank breather valve today Mike S. E39 M5 and E52 Z8 Discussion 11 9th March 2010 01:01
Urgent: Technical help needed on fuel tank breather valve R/I rdm190 E39 M5 and E52 Z8 Discussion 8 25th April 2007 14:31
