Software Update - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 7th March 2012, 00:19   #1
louiscipher1965
louiscipher1965's Avatar
Garage: Lemans Blue 2003 BMW M5
Software Update
Ok,
I have not had my car that long, and I came across a post on here about a Recall for cars that need to have the emissions done.
So I called a reputible BMW dealer here in Atlanta to schedule an appointment.
The Sales Rep first asked for the 7 digits of the VIN to look up the history.
He came back to the phone and stated to me that I don't have the recall for that but I do have a recall for something else.
He also stated that the last time this car had an update was back in 2004, he stated that my version is I believe, but not sure because I did not hear him clearly, stated that I am at 21-2... something to that nature.
So we scheduled an appointment for next Monday and he stated that they may need the car for the entire day, saying that it can take up to 2 to 8 hours for this update to complete.
My question is will I loose power, gain something better? What will happen pretty much.
Any thoughts would be great to hear from.
louiscipher1965 is offline   Reply With Quote
Old 7th March 2012, 00:57   #2
Georgia M5
Georgia M5's Avatar
Garage: 2003 Jet Black M5, 1997 Black 540 Sport, 1997 Black M3 4 door
Can you be more specific? What software needs updating? Mk IV, engine management, some other control module, etc.? I think I might have had one update on my car years ago, but I can't remember what it was.
Hard to know your case without the specifics. I suggest you call them back.
It almost certainly doesn't takes 8 hours to update the software, but it takes 8 hours at an Atlanta dealer because they want to work on your car at their convenience in their queue. Global, United, Nalley, BMW of South Atlanta are servicing 50-100 cars a day each, so it's hard for them to precisely schedule a time. They would rather you drop your car off so that you're not tapping your foot waiting on it.
For what it's worth, I've had a good, albeit expensive experience, with Atlanta dealers. That's probably true of most BMW dealers. I don't really take my cars there anymore, except for alignments, because I enjoy fixing them myself.
Georgia M5 is offline   Reply With Quote
Old 7th March 2012, 01:16   #3
louiscipher1965
Thanks for the update Georgia,
I will call them tomorrow to inquire a bit more on the speciffics on what needs to be updated.
I definitely would not like to leave my car there all day, and have them to fit me in when they can.
Old 7th March 2012, 01:53   #4
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
DME can in fact take 8 hours it has to server issues to keep it simple. If you do a search on the board you will get some opinions. I have the original software in my car and have been humming and hawwing about getting an update. I am sort of stuck at it ain't broke so why should I try and break it. Before you do, you should read as many old posts as you can. The issues vary depending on year.,
Sailor24 is online now   Reply With Quote
Old 7th March 2012, 02:13   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Originally Posted by louiscipher1965 View Post
Ok,
There was a software update for the DME to improve communications with the computer readouts. As I recall, it had mostly to do with the computers having trouble reading emissions information. Important in a state that does emissions testing, not important if your state doesn't.
If you have performance software, you will have to have that reloaded after the BMW update. It will reinstall the original performance software. Most companies (like Dinan) usually do it free or perhaps a nominal charge.
If you a search on here and go back in time, I am sure it has been discussed. Or try a google search, sometimes you get a more precise response.
gsfent is online now   Reply With Quote
Old 7th March 2012, 04:33   #6
Georgia M5
Georgia M5's Avatar
And we do have emissions checks yearly in Georgia. But, no state inspection. So, as long as your car is not polluting, we are more than happy to let you drive your car around with no brakes, bald tires, and no brake lights or head lights. It's stupid and bass ackwards. Go figure.
Old 7th March 2012, 07:42   #7
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Software update is only for the ECU.
On these cars,the process does NOT imply any other module software updates as it does on more modern BMWs...
On modern cars,due to the update of all modules,the process takes up to 8 hours.
With Progman(what they will use,maybe SSS),it does not take more than 1 hour.
And there is one important thing:
They have to disconnect the ABS/DSC module before starting the update.
Otherwise canbus interference between DME and ABS/DSC can put the DME in sort of a "sleep mode".
They will NOT be able to recover the ECU then(because they lack the correct software to do so) and will sell you a new ECU...
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 7th March 2012, 13:22   #8
louiscipher1965
Thanks for the update Jerry, and yes as for our State the guy did state that for these cars it is hard for the emissions stations to read the software and that is why we have to get an update so they can get a better reading.
My Cars production is 3/03 with out any mods.
Old 7th March 2012, 13:30   #9
louiscipher1965
Thanks Vantaam5,
I hope at the dealer they would know to do this. and I am going to research more as what to expect.
Old 7th March 2012, 14:43   #10
Georgia M5
Georgia M5's Avatar
If Vataam's risks are correct, then maybe you don't do it. Have you had trouble passing emissions so far? I haven't. If you've been passing emissions, then why do it?
Software Update francom82 E60 M5 and E61 M5 Touring Discussion 27 27th September 2011 21:21
Update software or not LJ Martin E60 M5 and E61 M5 Touring Discussion 11 3rd June 2010 16:27
Software Update Stormster E60 M5 and E61 M5 Touring Discussion 2 30th December 2008 22:18
Trackside Software Update - Dinan Software T Bone E60 M5 and E61 M5 Touring Discussion 0 16th August 2007 01:35
Software Update 21 tonach E60 M5 and E61 M5 Touring Discussion 0 7th April 2006 23:51
