Noisy fuel pump - BMW M5 Forum and M6 Forums
post #1 of 15 Old 31st January 2012, 01:58 PM Thread Starter
BriC
BriC's Avatar
Noisy fuel pump
Hi guys,
I've done a search, and couldn't really find anything. My fuel pump seems quite noisy. The noise is coming from underneath the car around the rear drivers side door (UK car, so it's RHD). The car drives well, and makes good power, but I'm a bit concerned it may leave me stranded one day. Is it a common problem and is there anything else it could be? I can get a video of the car running so it can be heard if that makes it easier to diagnose.
Cheers,
Oli.
BriC is offline
post #2 of 15 Old 31st January 2012, 04:04 PM
Quicksilv3r
Quicksilv3r's Avatar
Is it a high pitched whine? You shouldn't be able to hear it unless the rear seat cushion is out of the car, and even then it should be only a moderately apparent whine that rises and falls with acceleration/throttle response.
2008 BMW E90 M3 6MT - Silverstone II/Fox Red
01/2008 build date
Options:
Premium Package w/ Extended Novillo Leather & CF Trim
Convenience Package
NAVI w/ HiFi Logic7 Surround Sound
Sunroof
Mods:
Linea Corse LC888 Wheels 19"x9" (F) 19"x10.5" (R) [255/295]
Swift Race Springs
aFe ProDry Drop-in Engine Air Filter
ECS Tuning H8 LED Angel Eye Upgrade
E92-Lighting's CREE LED Front Indicators
Morimoto 6000K HID Bulb Swap
iND Painted Bumper Reflectors
Need an honest BMW service center to wrench on YOUR M5?
Stupid to buy an ///M and not drive it, it's like paying a hooker for a hug.
Quicksilv3r is offline
post #3 of 15 Old 31st January 2012, 04:12 PM Thread Starter
BriC
BriC's Avatar
BriC is offline
post #4 of 15 Old 31st January 2012, 04:22 PM
Quicksilv3r
Originally Posted by BriC View Post
Yeh it is fairly high pitched
Unless you've drained the tank and are running on fumes, it's likely working harder than normal & burning itself up in the process. I'd suggest replacing it. Just be sure to do the replacement on an empty tank...
I just had mine done a couple weeks ago and I could barely hear it with the rear seat cushion out; with the cushion back in I can't hear it at all, even on a low tank.
01/2008 build date
Options:
Convenience Package
Sunroof
Mods:
Swift Race Springs
post #5 of 15 Old 31st January 2012, 08:04 PM
gsfent
gsfent's Avatar
You don't indicate mileage or last fuel filter change. I would change the fuel filter; if the old one is bad, the pump has to work harder to push the fuel against the clogged or dirty filter.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is offline
The Following User Says Thank You to gsfent For This Useful Post:
Sailor24 (31st January 2012)
post #6 of 15 Old 1st February 2012, 04:21 AM
Quicksilv3r
This too. If it's been several thousand miles since a filter change and you like to run the tank dry on a regular basis...then the pump will go sooner than later. Of course it's all dependant on mileage.
01/2008 build date
Options:
Convenience Package
Sunroof
Mods:
Swift Race Springs
post #7 of 15 Old 1st February 2012, 09:25 AM Thread Starter
BriC
BriC's Avatar
I've no idea when the filter was last changed to be honest. I'll change the filter and see how I get on.
BriC is offline
post #8 of 15 Old 26th June 2012, 03:33 AM
Gouki
I just noticed that mine is making a lot of noise, searched, found two threads. So, what happened when you changed the filter?
Gouki is offline
post #9 of 15 Old 4th February 2015, 04:15 PM
Grinder
Grinder's Avatar
What I assume is my fuel pump (high pitched whine, changes frequency with RPM) is EASILY audible inside the car. Even at highway speeds I can hear it well. The fuel filter has been changed within the last 20k miles by the PO (my father). The car has 94k on it.
Is a loud fuel pump always a sign of a failing pump? Any "tests" that can be done to determine pump health?
Grinder is offline
post #10 of 15 Old 4th February 2015, 04:18 PM
rao
It isn't the sign of a healthy fuel pump
If it is noticeable enough that you notice it while driving it is time for a new one.
If you find this post unsatisfactory, please add me to your Ignore List so you will not be disappointed again in the future.
---> http://www.m5board.com/vbulletin/pro...?do=ignorelist
Rob
Prior - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Older - 92 325i with Chevy 6.6 LS2/T-56 Power
Oldest BMW - 95 M3 with Chevy 6.6 LS2/T-56 Power
rao is offline
The Following User Says Thank You to rao For This Useful Post:
Sailor24 (22nd February 2015)
Kenne-Bell Boost-A-Pump Install (AKA Dinan Fuel Pump Booster #D862-7320 havasusteve03Beast E39 M5 and E52 Z8 Discussion 7 6th April 2015 11:37 PM
New pre cat 02 sensors, secondary air pump, mafs, fuel pump and filter = 1 happy S2!! madyspop E39 M5 and E52 Z8 Discussion 0 12th February 2011 04:37 AM
hmmm... noisy suspension air pump? AJ BMW 1 Series M Coupé, X5M and X6M Forum 1 25th May 2005 01:09 PM
How noisy is your air pump ? Husaborg E34 M5 Discussion 17 12th June 2003 06:41 PM
Noisy fuel pump? JEM E39 M5 and E52 Z8 Discussion 1 2nd October 2000 06:39 AM
