"Tire Defect" sensor - BMW M5 Forum and M6 Forums
post #1 of 17 Old 14th January 2012, 02:16 PM Thread Starter
JimBeemer
JimBeemer's Avatar
My "tire defect" light comes on every time I drive. I checked my tires and they all have 38 psi. They are the same PS2s I've had on the last 8000 miles. This just started a week ago. Is there anyway to tell which sensor is bad (Peake Reader? or is that engine only) or perhaps look for a loose wire going into it? Are the sensors easy to get to?
Jim
JimBeemer is offline
post #2 of 17 Old 14th January 2012, 02:28 PM
jamiepeers
jamiepeers's Avatar
jamiepeers is offline
post #3 of 17 Old 14th January 2012, 03:27 PM Thread Starter
JimBeemer
JimBeemer's Avatar
Yes, I've reset it twice using the instructions in the owners manual to no avail.
Jim
post #4 of 17 Old 14th January 2012, 05:53 PM
D-RodM5
D-RodM5's Avatar
Maybe check the torque on the wheel bolts?
/// M5
Umnitza VXX
BeastPower Brackets
Schmiedmann Blck Chrm Grills
AFE Power Air Filters
XPEL Protection Film
StopTech ST-40
TimmayTips
Bilstein PSS
Evolve Alpha-N
D-RodM5 is offline
post #5 of 17 Old 14th January 2012, 11:51 PM
josiahg52
josiahg52's Avatar
Just as a reminder, Jim, and to everyone reading, the TPMS on our cars uses wheel speed sensors (also used by the ABS and DSC system) to detect a low tire not actual wheel mounted pressure sensors. There is a way to view the wheel speed sensor data . . .
-J
josiahg52 is offline
post #6 of 17 Old 15th January 2012, 02:20 PM Thread Starter
JimBeemer
JimBeemer's Avatar
Took my M5 to a local Dobbs Tire Center (against my better judgment) and they found a half golf ball sized bulge on the inside sidewall facing the undercarriage of the right rear tire. They contacted Michelin and they wanted the tire to analyze it. It had 8356 miles on it with no track use, but may have been the victim of a pothole, however the wheel itself was straight and true with no damage. They tracked down two PS2s for me and I got two new rears for $310 installed with Michelin covering the rest. Michelin has made me a customer for life with their goodwill! That "tire defect" light really does work as it's supposed to. The mechanic felt I should get an ABS or traction control (DSC) light if one of the sensors failed. He also thought that with the use of what he called BMWs "rolling sensors" the bulge could have distorted the tire at speed and slightly changed the circumference of the tire under different speed and road conditions.
Jim
The Following User Says Thank You to JimBeemer For This Useful Post:
chowdah (29th December 2012)
post #7 of 17 Old 15th January 2012, 02:45 PM
twastheglow
twastheglow's Avatar
Great to hear you got it sorted! Also good to hear you got some good customer service.
twastheglow is offline
post #8 of 17 Old 15th January 2012, 08:47 PM
Sailor24
Sailor24's Avatar
The tire defect system works well. I think Mine is stuck in learn all of the time but that does not make a difference. I had a broken belt that I never even felt it was so insignificant. The system kept telling me I had a fault. I just happened to notice the small wear spot when I switched to winters. No fault since the winters went on. New summers for next year were on the list anyway. I thought it was the unit acting up.
Sailor24 is offline
post #9 of 17 Old 16th January 2012, 03:26 PM
sproule905
Exact same fault I was receiving with the summers. I have dunlops on the front and michelins on the rear or vice versa. With the winter tires on there are zero codes for the tires"
sproule905 is offline
post #10 of 17 Old 28th December 2012, 09:34 PM
Cortinas78
Cortinas78's Avatar
A lot of threads on this subject. I chose the most recent post to bring this up. Does a 10lb swing flip the "tire defect" light? I keep my tires inflated at 42lb (f) and 46lb (r). Tire defect lit up after a 3 mile drive. My car has sat for the last 5 days. Weather temps dropped by 40 degrees down here while the car sat. 32/32 (f) and 33/31 (r). I checked for screws and nails and found nothing.
Cortinas78 is offline
Continual "Tire Defect" false alarm? ECB E39 M5 and E52 Z8 Discussion 7 4th August 2007 02:42 AM
dash warning message "Tire Defect" - what the f? 3rd_world E39 M5 and E52 Z8 Discussion 20 25th May 2007 08:54 AM
"Tire Defect" warning in Dash Display? BeastPower E39 M5 and E52 Z8 Discussion 9 10th October 2002 05:10 PM
"Tire Defect" warning - False Alarm? RGCohen E39 M5 and E52 Z8 Discussion 3 26th April 2002 01:58 AM
"Tire Defect", now "Reifenpanne" RogerA E39 M5 and E52 Z8 Discussion 4 15th January 2002 01:57 PM
