Dice MediaBridge Not Working Correctly - BMW M5 Forum and M6 Forums
Old 11th January 2012, 20:42   #1
Super90
Super90's Avatar
Garage: 2000 Jet Black M5 / 1959 Porsche 356A
So I took my car in to be serviced and now my Dice isn't working correctly. I can still play my iPhone through the USB connection, but bluetooth is no longer discoverable and the voice prompts ("USB" "Bluetooth" "Song Mode" etc) no longer work. The shop changed out my thrust arm bushings and cleaned the mechanism that raises and lowers the steering wheel upon entry/exit, so I'm not sure what they could have changed. Any ideas or thoughts on how to fix this? Appreciate any help!
Super90 is offline   Reply With Quote
Old 11th January 2012, 21:06   #2
dan.
dan.'s Avatar
Garage: m5 e39 le mans blue 2001
I had to disconnect mine from the power source when it glitched,never done it since.
dan. is offline   Reply With Quote
Old 12th January 2012, 03:18   #3
Super90
Super90's Avatar
This worked, along with a firmware update. Problem solved!
Old 13th January 2012, 04:44   #4
Super90
Super90's Avatar
Happening again! Everytime the car goes off the thing freezes. I can fix it by disconnection the power, but this solution doesn't work for me long term. Any suggestions are appreciated.
Old 17th January 2012, 08:51   #5
manualshifter
manualshifter's Avatar
Garage: M5 e39
Any resolution with this one?? I got the same problem..
Allan
manualshifter is offline   Reply With Quote
Old 17th January 2012, 15:11   #6
Super90
Super90's Avatar
I've spent some time on the phone with Dice Technical Support and they have sent me a return authorization. I think the timing with the service work was purely coincidental and that the unit just died.
Old 18th January 2012, 00:44   #7
manualshifter
Garage: M5 e39
Oh thanks- I got mine second hand- looks like Im in trouble.
Old 18th January 2012, 13:08   #8
manualshifter
Garage: M5 e39
Mediabridge MB1500
Yes...After 2 days of dis/reconnect everything to no avail... I fixed it!
What I did: Updated the firmware again..
and then reinstalled everything one more time.
Either the update I did before first install didnt work correctly or got corrupted.
Old 18th January 2012, 15:31   #9
E39Sambo
E39Sambo's Avatar
Garage: BMW M5 Carbon Black
Mine did something similar when I first got it. I fitted the wiring into the car and tested everything worked, then went indoors to do a firmware upgrade. After that it just didn't work properly - similar to what you're describing. Announcements were inconsistent, and bluetooth just would not connect to my phone. Tried the firmware upgrade again, and obviously powered it on and off a couple of times, and she's been good as gold ever since.
Quite pleased with the Dice now it's working though, especially the fact I can have it connected to both my personal and work mobiles at the same time, so if either rings it comes through to the car. Genius.
E39Sambo is offline   Reply With Quote
Old 19th January 2012, 04:42   #10
manualshifter
Garage: M5 e39
Really? 2 mobiles connected to BT at once?
DICE Mediabridge Installed Toddzilla E39 M5 and E52 Z8 Discussion 50 14th February 2013 17:02
DICE MediaBridge question twalker294 E39 M5 and E52 Z8 Discussion 22 12th October 2012 21:09
Dice MediaBridge 4:3 Blue5 E39 M5 and E52 Z8 Discussion 3 1st September 2011 09:44
For those who have the Dice Mediabridge... LoCalM5 E39 M5 and E52 Z8 Discussion 9 3rd May 2011 17:22
Dice MediaBridge GatorMan E39 M5 and E52 Z8 Discussion 11 25th December 2010 02:23
