Diagnose my beasts spark plugs! With fault codes - BMW M5 Forum and M6 Forums
Old 25th December 2011, 00:38   #1
Bisan
Garage: 2002 Unmolested M5, heavily molested M3!
Kind of weird. Basically the front four cylinders are running very lean. I started with 8 plugs and 1 MAF meter.
Car was throwing...
Bank B (passenger side) MAF meter
Misfire under 1500 RPMs
Multiple misfire without cutoff
Multiple misfire with cutoff
Misfires 1,2,3,4,5,7 with and without cutoff
Also found a torn ignition coil ground that I fixed as well. Let me know what you guys think.
I suspected bad coil packs here are packs 4,3,2,1 shown below.
Bisan is offline   Reply With Quote
Old 25th December 2011, 01:37   #2
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Can you post the numbers of the codes you had? I can't lookup descriptions. Front being lean and back being rich makes me think low fuel pressure, but I would expect different codes, so have you had other codes other than you mention? Have you any history on the fuel supply system? IE pump filter and pressure reg.
Sailor24 is offline   Reply With Quote
The Following User Says Thank You to Sailor24 For This Useful Post:
herrubermensch (25th December 2011)
Old 25th December 2011, 01:49   #3
Bisan
2002 BMW M5
Here are screenshots of codes.
The Following User Says Thank You to Bisan For This Useful Post:
Sailor24 (25th December 2011)
Old 25th December 2011, 01:55   #4
Sailor24
Sailor24's Avatar
Try unplugging the MAFs and driving it. Should run way better, if it does not put a fuel gauge on at the fuel filter and see what the readings are. Likely two new mafs are in your future. Still don't see a reason for 4 being so rich maybe a bad or dirty flow pattern.
Old 25th December 2011, 02:04   #5
Bisan
I tried that earlier today after I put 8 new plugs in it. But no it didn't clean up at all. My new MAF won't be here until Tuesday. I was thinking a fuel issue as well.
Any other ideas?
Old 25th December 2011, 02:17   #6
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Any other ideas?
I think you only unplugged the Bank 1 MAF. There is no code 39 for Bank 2 MAF power interrupt as it were.
Did you car suddenly start playing up, and you checked codes and you received all these misfire codes ?
What recent works have been carried out to the car in the last few months ?
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 25th December 2011, 02:23   #7
Bisan
No, there was nothing unplugged when we pulled the codes the other day. Today I unplugged both MAFs to see if it would clean up.
It wasn't all of a sudden, happened over 1500 miles and 6 months
Old 25th December 2011, 02:25   #8
M5 London
M5 London's Avatar
But GT1 is telling you that bank 2 was NOT unplugged.
Please swap MAFS bank to bank and re read codes.
Old 25th December 2011, 02:46   #9
68FB
Garage: 2001 M5 Ti Silver
Those plugs indicate the front two cylinders on both banks are OK (grey/white ground electrodes and clean white insulator) and the back two are sooty with burnt oil, especially #4. Any oil in the plug wells? Or in the plenum?
68FB is online now   Reply With Quote
Old 25th December 2011, 03:53   #10
Bisan
I don't have a GT1 at my house. So I won't be able to do that until next week. I do have a scanner for my iphone.
It did pull a Lexus VVT performance sensor code (Bank 2) which I believe is a Crank Position Sensor. It is a generic code reader so codes are interchangeable on it. A CPS can cause multiple misfires and rough idles.
Spark Plugs
Mass Air Flow Meter
and.... should I consider doing the Crank Position Sensor?
Please help diagnose fault codes sshu930 E39 M5 and E52 Z8 Discussion 15 18th July 2011 22:21
Spark plugs replaced (pics of old plugs included) D-RodM5 E39 M5 and E52 Z8 Discussion 4 15th November 2010 05:45
Spark Plugs kosmo E39 M5 and E52 Z8 Discussion 35 24th December 2007 18:11
How do you get to the spark plugs M5NJR E39 M5 and E52 Z8 Discussion 9 19th September 2006 14:07
Spark Plugs? V-10 4 Me E39 M5 and E52 Z8 Discussion 3 26th February 2003 03:09
