Tire Air Pump and Sealant Kit - $19.09 Solution - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 29th November 2011, 02:55   #1
roller1150
roller1150's Avatar
Garage: 2001 BMW M5 Titanium/Black
I'll just let the pictures do the talking on this one...
I just bought this from Target today for $19.09 not including tax. Hopefully this will work for me when I experience the dredded flat tire on the M5.
Photobucket
Photobucket
Photobucket
Nice rattle free fit. I got lucky!
Photobucket
Photobucket
2001 BMW M5 TiAg. Black Interior/Grey Inserts and Aluminum Trim 110,000+ mile club, F&R PDC, and rear folding seats
BBS LM Reps - 245/35/19 F 275 30 19 R Yokohama S-Drive Tires
H&R 5mm spacers on all corners with extended lugs
Air Filters - aFe
Stebel Air Horn
Aluminum Brake Ducts Inlets
Muffler DELETE
B&G S2 Sport Springs
Dinan Rear Sway Bar
Royal Purple Transmission & Differential Oil
Castrol TWS Motor Oil
MKIV Navigation
Passport 8500 X50 - Hardwired by Oval Mirror
Parrot Minikit Slim Bluetooth Speakerphone - Hardwired by Homelink
DDM Tuning HID 35W 5000K fog lamp kit and Error Eliminators
LED license plate lights, LED Angel Eyes, & Interior LEDs (all from BMWLED.net)
M5 side emblems - Grey/White (thanks to fellow member Strike)
Route 66 Extended Warranty - Main Street Deluxe Coverage ($2,060 3 yr/36K purchased on 09/13/2011 w/99,680 miles)
2005 Porsche Cayenne Turbo Black/Black w/20" Sport Techno Wheels - Daily Driver - Purchased on 04/04/2013 w/65,890 miles)
roller1150 is offline   Reply With Quote
Old 29th November 2011, 03:22   #2
Frye
Garage: 2000 & 2003 M5
I have that exact same thing, except I switched the slime out with a couple different pairs of pliers and a plug kit.
Frye is offline   Reply With Quote
Old 29th November 2011, 04:10   #3
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
There is nothing magic about the BMW tire sealant or compressor. And it does no good if you get a big hole (plug kit) or you get a bad tire valve. Nothing beats a spare (although it will not fit as neatly in the trunk NAV compartment!).
Old 29th November 2011, 04:41   #4
Cobra228
Cobra228's Avatar
Garage: 2001 M5 Anthracite/Caramel
I have the exact kit in my trunk. I hope I never need it!
93 Mustang Cobra 31k
Cobra228 is offline   Reply With Quote
Old 29th November 2011, 05:04   #5
E39M5inMD
E39M5inMD's Avatar
Garage: E39 M5 Carbon Black
Has anyone on the board ever used one of these kits? Does it garbage-up the inside of your tire or do anything to the sensor? I have a BMW fix-a-flat kit that I bought from the dealer after I got my beast, but it is now 4 years out of date. This is a lot more affordable, but does it have any bad side effects?
E39M5inMD is offline   Reply With Quote
Old 29th November 2011, 05:08   #6
E39M5inMD
E39M5inMD's Avatar
I should also note that gsfent is correct, nothing can beat a spare tire if you've had a sidewall blowout like I have. Had to get it transported on tilt-up the remaining 45 miles to my cousin's house and then two days wait until they could get a replacement PS.
Old 29th November 2011, 17:24   #7
Jdog_M5
Jdog_M5's Avatar
Garage: 2001 E39 M5 - Titanium Silver
I used one of these "slime" kits on a different car/tire issue I had a few years ago. It does garbage up the inside of the tire a bit but I think it can be washed off. My specific problem with the tire rendered it useless after a few miles of driving but the slime allowed me to get to where I needed to a few miles away.
The one thing I will mention is: If you do use this and bring your car to a shop to get the slimmed tire replaced, please let your tire guy know there is slime in it. I didn't tell mine and when I came to pick up the car, he has the most pissed off look on his face. When he unmounted the tire from the wheel, all the slime went all over him lol. SORRY!
Jdog_M5 is offline   Reply With Quote
The Following User Says Thank You to Jdog_M5 For This Useful Post:
E39M5inMD (30th November 2011)
Old 29th November 2011, 21:51   #8
alfie
Garage: e39 m5 velvet blue
Is the slime in an aerosal can. I had the holts tyre weld in the wheel well in the boot. Two days ago when i opened the car there was this strong smell of aerosol. Opened the boot and white foam creeping up around the floor covering. The can had exploded. It was like a foam party in there. I tried cleaning it up but it was slowly expanding so i just threw the floor covering on it and came back to it the next day. The foam had gone and left a nice sticky residue for me to clean up.
The package seems to fit like a glove where you got it but its not somewhere I would keep this type of product if its in a pressurized container after my experience.
alfie is offline   Reply With Quote
Old 29th November 2011, 23:30   #9
cab
cab's Avatar
Garage: 2002 LMB/Caramel (sold)
I don't think we have low pressure sensors inside the rim. I believe our cars use the ABS sensors to detect "low tire pressure". I'm not 100% on how it works (more rotations per mile as the tire size "shrinks" with loss of pressure I assume).
I have a similar pump - purchased when I bought my car for the 800 mile drive back home. One day, at home, I decided to use it instead of pumping up my 80 gallon compressor tank. It lasted 30 seconds before the inline fuse blew so you might keep spare fuse or two...
cab is offline   Reply With Quote
The Following 2 Users Say Thank You to cab For This Useful Post:
E39M5inMD (30th November 2011), Mike S. (30th November 2011)
Old 30th November 2011, 07:51   #10
gsfent
gsfent's Avatar
Sales Feedback: (3)
Yes, the car uses the ABS sensors to monitor tire rotation.
As to keeping spare fuses, good idea. You shouldn't blow a fuse after 30 seconds, most times you blow a fuse because of the surge at startup. YOu can try going up slightly on the fuse size, just make sure the fuse is below the rating on the power source. So if the cig lighter power source is say 10A, you don't want to go above that. Radio Shack is a pretty good source for odball rated fuses.
TIRE inflator/sealant - which kit is preferred... ? Kevin The Clean 1 E39 M5 and E52 Z8 Discussion 12 20th February 2011 07:39
New pre cat 02 sensors, secondary air pump, mafs, fuel pump and filter = 1 happy S2!! madyspop E39 M5 and E52 Z8 Discussion 0 12th February 2011 04:37
Should I use the tire sealant or not? dragoncoach E39 M5 and E52 Z8 Discussion 11 16th December 2009 17:35
Slime tire sealant...does it work? superfly1 E39 M5 and E52 Z8 Discussion 10 23rd November 2009 07:45
M-tire sealant........a sticky mess!! Texas E39 M5 and E52 Z8 Discussion 13 23rd February 2004 01:13
