Auxiliary fan fuse location? - BMW M5 Forum and M6 Forums
Old 10th July 2002, 10:42   #1
Brent
Brent's Avatar
Garage: M5 Titanium/Silverstone
Does anyone know where the aux fan fuse is?
Brent
01 M5 Titanium Silver/Silverstone/Aluminum
Brent is offline   Reply With Quote
Old 10th July 2002, 13:39   #2
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
There is one set of fuses in the glove compartment, and another set in the trunk, behind the right side plastic/cardboard/mat with a handle.
David
DavidS is offline   Reply With Quote
Old 10th July 2002, 20:34   #3
Brent
Brent's Avatar
DavedS, Thank you for the input. Aux. Fan fuse #75 isn't in either of thoughs locations. I'm going to the Dealership tomorrow "maybe" they will know where it is.
Old 28th May 2011, 13:17   #4
SA-M5
SA-M5's Avatar
Garage: check sign.
Brent, after almost 9 years! any update on the location of this Fu$$$ fuse?
SA-M5 is offline   Reply With Quote
Old 28th May 2011, 17:05   #5
nerio02
nerio02's Avatar
Garage: m5 e39 ROYAL RED/fully loaded e36 M3 3.0 track weapon
50 amp fuse sits above the glovebox/fuse panel.. you need too take out the clovebox completely and then you lay on your back looking upward. its a big orange fuse sticking behind the fusebox.
its a real pain in the ***** work and hard too acces iff you got big hands.
best thing too do is first check iff you get current at the aux fan connection where the kidney's.frontbumper are..before tackeling the fuse part. most off the time its the aux fan motor thats broken..not the fuses.
with kind regardes
nerio02/dominique
nerio02 is offline   Reply With Quote
Old 28th May 2011, 17:45   #6
Dntlvet
Dntlvet's Avatar
Garage: 2010 M3 AW
I found it in back of the glove box in my 2001 530i.
My bet it is there. If you have FSU issues, the carpeting can easily be lifted up for better access.
You can then access the fuse you are in search of.
Dntlvet is offline   Reply With Quote
Old 29th May 2011, 10:29   #7
SA-M5
SA-M5's Avatar
Garage: check sign.
GOT IT! , why the hell they hide there!. I think there is no place in the whole car to put it but there!....
Any way thanks guys for your help. I appreciate it. It turns that my fuses are all ok. I need to see why the fan is not working.
Old 29th May 2011, 10:35   #8
feeblebob
feeblebob's Avatar
Garage: BMW E39 M5 in Silverstone Blue and a 2006 Lexus GS300 Limited Edition
Try : Auxiliary Fan write up - Bimmerforums - The Ultimate BMW Forum for size
2001 E39 M5 : Silverstone Blue, 19" Breyton Spirits (horribly rashed...), black kidney grilles (one broken...), black and white badging (fading fast...), Philips Silverline Indicator Bulbs, Alpine KCA-420i (in a box in the house) and Xmas-pressie iPod Classic (just need Intravee II now...), otherwise standard (but who knows...)
"I look at it like this. Owning an M5 is kind of like dating a slamming hot big-t...ed blonde, who is a pain in the *****, drains your cash, but screws like there's no tomorrow. Owning a Honda Civic or the like, is akin to dating a girl who is fat, ugly, smells a bit where she shouldn't, is a cheap date and doesn't screw at all (you don't mind). So yeah, I'll take the blonde." (Courtsey of Jetpilot718)
The thread of my car and it's progression to mechanical perfection... : http://www.m5board.com/vbulletin/e39...ry-thread.html if I ever get around to anything...
Cabin Filters 6/3/11, Bosch wipers 21/5/11, OEM air filters 24/5/11 (110,920), Oil Change, Oil Seperators and Thermostat 07/08/11 (112,699), Final Stage Resistor, Coolant Temp Sensor, Silvered Indicator Bulbs 21/08/11 (114,110), Private Plate 23/10/11, Came home from storage 13/02/13
feeblebob is offline   Reply With Quote
Old 14th September 2011, 05:21   #9
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (4)
I need to replace this fuse this weekend. Is it a standard size or something unique? I know it's a 50 amp. Can anyone post a pic of the location (the Bimmerfest pic does me no good!)? Do I really have to remove the glovebox? Mine is suffused with wiring and removing it is a HUGE PITA! Thanks.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
herrubermensch is online now   Reply With Quote
Old 14th September 2011, 05:39   #10
josiahg52
josiahg52's Avatar
Garage: 2001 Jet Black/All Exclusive Black/Black Cubic M5, Supercharged 2001 Tahoe LT 4x4
Sales Feedback: (6)
A fuse rated at 50A likely would mean a MAXI-fuse. The description of "big-orange fuse" completely convinces me that it is definitely not an ATC/ATO or Euro-blade fuse. I don't know for sure but I am just saying that ATC, ATO and Euro-blade fuses are limited to 30A.
I don't think you could get a camera in there, Peter. As I understand it, the fuse is above the glovebox and above and behind the fuse block further up in the dash in a vertical position. You are going to have to remove the glove box. That is to say, I think the wires in the foreground of the picture on Bimmerforums are the wires coming out of the back of the fuse block.
I get my fuses at West Marine but there are numerous on-line and retail sources. A boat supply store will definitely have it (if it is in stock is another matter) and an auto parts store should.
MAXI on the left, ATC/ATO (similar to Euro-blade) on the right:
josiahg52 is online now   Reply With Quote
The Following User Says Thank You to josiahg52 For This Useful Post:
herrubermensch (14th September 2011)
fan sound when ignition on, any ides? plisken E34 M5 Discussion 4 12th December 2003 12:27
E 46 fan problem Jonas400 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 10th October 2002 13:14
Rulers please! Euro M5 badge location GDA E34 M5 Discussion 4 31st August 2002 11:39
Blow fan runs after key off momo5 E34 M5 Discussion 3 28th August 2001 11:53
Beware of Car Dealers!!!!!! Derrick E E34 M5 Discussion 3 28th June 2000 21:50
