DIY Cleaning VANOS - BMW M5 Forum and M6 Forums
Like Tree7Likes
Old 7th November 2011, 14:14   #1
wilhit10
Garage: 2002 Carrera C2, 1988 E30 M3(s50B32)
Sales Feedback: (3)
DIY Cleaning VANOS
This is a little bit about how to disassemble your vanos and clean it. Do this at your own risk. My vanos was disgusting, these pictures were after it was cleaned.
Here is the labeling I have of things..I am bad at terms, so correct me.
Step one remove the Pistons by pushing them out from this side:
Next remove the Circ Clip, the sealing ring, and then the pump. This picture is a clean one..
This picture has the pistons still in the vanos because I was reassembling it...It doesn't matter the order.
wilhit10 is offline   Reply With Quote
The Following User Says Thank You to wilhit10 For This Useful Post:
Nvable (21st April 2013)
Old 7th November 2011, 14:28   #2
wilhit10
Sales Feedback: (3)
Next clean out all the little holes. Inside the pistons there are holes in there too. These red markings are just an estimate. I use brake cleaner and compressed air.
Flip it and clean the other side. Make sure you clean the bearings, cylinders, etc. When you clean these holes, flip the other side and cleanup what mess it made on the other side. Repeat these process's until your vanos is clean.
Oil everything well. Especially the bearings. Be careful putting the pump back on. The ring is held on by pressure of the 4 pistons that come out of the center piece. If the outer circle comes off, these pistons will shoot across the room. Ask me how I know. If this happens, I have a method to put it back together.
Good luck
-Adam
The Following 19 Users Say Thank You to wilhit10 For This Useful Post:
chowdah (7th November 2011), Chris_M5 (8th November 2011), cura (20th April 2013), djazz (9th November 2011), feeblebob (18th November 2011), herrubermensch (24th November 2011), JDMM5 (8th November 2011), JimBeemer (21st April 2013), M5 London (9th November 2011), MATT0404 (13th November 2011), meepmeep (7th November 2011), Mike S. (9th November 2011), nerio02 (7th November 2011), Nvable (21st April 2013), Sailor24 (7th November 2011), sor118 (19th November 2011), Strike (7th November 2011), Tiauguinho (9th November 2011), vantaam5 (7th November 2011)
Old 7th November 2011, 16:44   #3
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
You do an excellent job at these DIY posts. Thanks much for passing on the info, greatly appreciated.
Sailor24 is offline   Reply With Quote
Old 7th November 2011, 16:48   #4
wilhit10
Sales Feedback: (3)
Thanks sailor, you guys guide me to my knowledge of these cars and I pass it on in return!
Old 7th November 2011, 16:54   #5
Strike
Strike's Avatar
Garage: 2002 Jet Black
I can't wait to see a startup vid after all this work is done!
2002 Jet Black/Imola Red Sport
Dinan Stage I Software
K&N Filters - Brake Ducts
K40 Undetectable
AXXIS ULT pads
Black/White CF Roundels
Body Color Grills
Greyscale ///M Logos
Smoked Tails
30% Tint
Intravee II
Strike is offline   Reply With Quote
Old 7th November 2011, 17:00   #6
wilhit10
Sales Feedback: (3)
I am fixing a head of a e36 m3 to help pay for this work...so it'll be delayed a bit. Making progress though, got the top covers on. Apparently I didn't get a gasket ring for the support valve(only got one). It's ordered and then the vanos's will go on. The thing is, I will probably only do this once, but I could do it again in about 1/4 the time .
Old 7th November 2011, 17:05   #7
Strike
Strike's Avatar
Don't you hate that? lol. Comfort will come from your S62 purring like a kitten.
Old 7th November 2011, 17:21   #8
mailman
mailman's Avatar
Garage: E39 M5 '00 Carbon Black
Nice topic
You should also add part numbers what to order before starting this project
Hmm, or was it that there is none of the parts available in BMW? I have my Vanos units rebuilt by Raikku, and I cannot remember now was all the parts new ones or what...
E39 M5 Carbon Black
My mods;
+ Supersprint Race Mufflers + Supersprint X-Pipe + iBright V2 Angel Eyes + K&N Panel Filters +
+ Hella OEM Facelift Headlights and Tail Lights +
Custom Clutch Stop + HEL Brake Lines +
+ 16:9 Navigation Screen + MKIV + LED Interior Lights + Carbon Black Kidneys +
+ E60 Short Shifter Kit + ZHP Short Shifter Knob + Wiechers Aluminum Strut Bar +
+ Alpha-N, Powermapping & IATS Relocation Kit by Evolve + EBC Yellow (F) & Red Stuff (R) Brake Pads +
+ Intravee II & Alpine 420i with iPod Classic + OEM Subwoofer with Focal Solid 2 amp +
+ AP Coilovers +
mailman is offline   Reply With Quote
Old 7th November 2011, 17:23   #9
wilhit10
Sales Feedback: (3)
I don't think any of these parts are available to be replaced......well I take that back, the seals that go around the vanos are...
Old 7th November 2011, 17:25   #10
wilhit10
Sales Feedback: (3)
I don't think any of these parts are available at this level of vanos cleaning......well I take that back, the seals that go around the vanos are...
RealOEM.com * BMW E39 M5 Cylinder Head Vanos
11361406868 *2
11311317732 *2
warning light,vanos oil pressure/vanos sensor dejanstepan E60 M5 and E61 M5 Touring Discussion 62 26th April 2013 02:12
Vanos solenoid seals Dr. Vanos vs OEM replacement? blackwagon E39 M5 and E52 Z8 Discussion 18 24th January 2011 19:31
HELP! Vanos replacement advice needed, is my vanos capoot?! M5aud E60 M5 and E61 M5 Touring Discussion 100 13th July 2010 12:18
DIY: Engine Cleaning and Vanos Solenoid take out and install [PICS] drdre0728 E39 M5 and E52 Z8 Discussion 15 17th June 2010 07:47
Help with VANOS issue- mechanic convinced me to replace vanos and now code is back MPOWDER E39 M5 and E52 Z8 Discussion 10 27th January 2010 21:23
