puzzled on "E-box-fan" & "Function check TEV" - BMW M5 Forum and M6 Forums
Old 30th October 2011, 05:03   #1
primeral
Garage: 02 M5, Alpine White
Hello all,
With the weather so nice, I decided to do something about an SES that's been bugging me for months. I was getting three codes consistently: E-box fan, Function check TEV, and Engine temp plausibility. After some searching, I read that one of us thought they had fixed the fan problem by cleaning the electrical contacts until they got the SES light again. I decided not to take the chance and bought a new fan from the local dealership.
Regarding the Function check TEV and Engine Temperature Plausibility error, this post outlines a Service Information bulletin that addresses those two codes. Problem is, my car is a MY2002 with build date of 12/01. My Base Control and Programmed Control Unit numbers are also higher than the 7 831 762 and 7 831 872 numbers mentioned in SI
B 12 24 99, so it doesn't really pertain to my car. My search comes up with no real clues as to what needs to be fixed.
I went and bought a new E-box fan from the dealership and changed it out today. Thanks to this thread, I was able to do this fairly quickly. Here are the original codes I that would light up my SES ... it would be on for weeks and magically disappear only to return again after a few days:
143 E-box-fan
Error frequency : ___ (some high number)
Logistic counter: 40
Engine speed 720.00 rpm
relative filling 18.40 %
Cooling water temp. 61.00 degrees C
Supplier voltage HR 11.40 V
aufgetreten vor (rel. B2) 30.00 km
0100 - Broken wire / Value missing
Error not present
Sporadic error
Errorcode: blahblah (is this important?)
232 Function check TEV
Total air mass 20.00 kg/h
Environmental temperature CAN 15.00 degrees C
Tank air evacuation adaption 1
Tank air evacuation adaption 2
OBD exhaust relevant error
Error present
Static error
105 Plausibility Engine Temperature
blahblah
1000 - Condition / value implausible / over temperature
Well, I put her back together, cleared the errors with INPA, and took my wife out on a hot date. Upon reaching the driveway on our return home, the SES light came back on again. What's disappointing is the E-box-fan code is back. This really sucks because I just spent $120 on a stupid fan. I'm going to try cleaning the fan plug's contacts and inspecting the wire for damage. About the Function Check TEV, does anyone have any hints? I've been watching my engine temp gauge and it's been normal. I'd also like to add that I was getting this error in 100 degree F heat and even now that it's 60 degrees F.
One more thing, I have to thank you guys for another previous thread ... I touched my crank case vent hoses and they felt gross. The passenger side hose even has a few small holes in it. It's good to know I'm not alone with these problems Any possibility it's related to the Function Check TEV code?
(\__/) (\ /)
(")_(") c('')('')
Save the Manuals!
primeral is online now   Reply With Quote
Old 30th October 2011, 06:01   #2
68FB
Garage: 2001 M5 Ti Silver
The 105 coolant temp plausibility code (aka 69 code in hex on a Peake reader) is usually the thermostat or the temp sensor mounted in top of the t/s housing. I had this code and changed the t/s first, which is a tricky little job (see link) but I still got the code. Changing the sensor fixed it. This is a much easier job that the t/s so I suggest trying that first. Siphoning the coolant out of the expansion tank gets the level low enough to replace the sensor without spilling coolant.
Did a thermostat replacement today (a lot of pics)
68FB is offline   Reply With Quote
Old 30th October 2011, 18:50   #3
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
232 is the evap valve under the plenum. Very common for them to fail. The odd time the valve is not at fault sometimes the Charcoal canister is plugged, usually when the owner has to top up when filling up. So if you don't squeeze every drop of fuel you can when filling up it is likely the valve. You want to have the valve on hand when you go in to check it because it is under the plenum. If your valve functions, send the new back unopened.
The other 2 codes together are interesting. Don't use the gauge for diagnostics use OBC test 7 Ktemp. I would also be interested in seeing your Atmp which is the same test number you push the left button twice more. Watch those and post back what you see. I am sure you know what tests I speak of but a newbie searching may not so read this both pages
Gadget Freaks II: Fun you never knew you could have [secret menu]
Ya I know newbies never search, I can dream.
Have you seen your ebox fan spinning? have you checked for power at the fan and have you checked the fuse?
Sailor24 is offline   Reply With Quote
Tags
105, 143, 232, e-box, tev
"Check" & "BC" buttons rattle?? M5 Roggan E60 M5 and E61 M5 Touring Discussion 29 29th June 2010 08:26
what is the peake fault code "E-Box Fan" jkarp E39 M5 and E52 Z8 Discussion 25 5th August 2009 16:42
"Engine Malfunction: reduced power!" & "Increased Emissions" OTDoc E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 2nd November 2008 00:15
"Engine Malfunction; Reduced power!" & "Increased Emissions" OTDoc E60 M5 and E61 M5 Touring Discussion 16 9th August 2008 03:25
"Check engine oil level" and how the freak do you use the STOPWATCH function? Redshift E39 M5 and E52 Z8 Discussion 5 12th March 2004 02:23
