A few notes for chain guide repairs - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 20th October 2011, 20:41   #1
vantaam5
vantaam5's Avatar
Garage: A few toys...
As I know a few of you guys tackle changing your chain guides at the moment,here are some useful hints:
To make sure there is no oil leaks between upper chain covers(and lower chain cover) where they meet the block and head gaskets as well as upper oil pan gasket I apply a bit RTV(in my case Drei Bond) as shown on the picture.
Also a bit silicone on all steel gaskets for lower,upper chain covers,water pump,valve cover gaskets.
To prevent the main chain from slipping hang it up like this:
Secure the wiring loom with a zip tie on the oil return tube:
Clean the threads for the inhex bolts on the cams with brake cleaner and use Loctite 270(strong) for the bolts.
Clean the threads for the sprocket hex bolts and use on the new bolts(as they come as 10.9 instead of 8.8 original).
If you install the chain drive first and then the covers,use a zip tie as shown.Makes installing the lower chain cover easier.
Remember to remove it before installing upper chain cover.
When installing the upper chain covers,tighten the cylinder head side bolts only a bit.Then tighten the bolts lower chain case side most outwards first.After that the rest of the bolts.
This way the covers seat proper.
Wrong:
Right:
Pushing the chain tensioner rail with a screw driver makes installing the bank1 upper cover easier:
vantaam5 is online now   Reply With Quote
The Following 8 Users Say Thank You to vantaam5 For This Useful Post:
Chris_M5 (20th October 2011), feeblebob (21st October 2011), herrubermensch (21st October 2011), jamiepeers (20th October 2011), Kelster (20th October 2011), liquidsmoke (20th February 2013), OC e39r (21st October 2011), Sailor24 (20th October 2011)
Old 20th October 2011, 21:02   #2
vantaam5
vantaam5's Avatar
Do not forget to install new diaphragm springs.
Wear on the old one which causes Vanos noise:
Difference between old and new style diaphragm springs(notice the difference in orientation):
The Following 4 Users Say Thank You to vantaam5 For This Useful Post:
chowdah (25th October 2011), feeblebob (21st October 2011), herrubermensch (21st October 2011), Kelster (20th October 2011)
Old 20th October 2011, 21:04   #3
wilhit10
Garage: 2002 Carrera C2, 2002 M5
Sales Feedback: (3)
Use silicon and dreibon on the metal gaskets? Also, is their an easy way to get the lower shaft seal to go on while doing this?
I will be starting to reinstall this today or tomorrow.
Edit...dreibond is silicon. ooops!
wilhit10 is offline   Reply With Quote
Old 20th October 2011, 21:23   #4
vantaam5
vantaam5's Avatar
I always use on all of metal gaskets a slight film of Drei Bond.
NONE of my engines leaks even a bit,but I am anal...
I always change the main sealing when the cover is removed.
When you install the lower chain case,you just use your fingernail to make the lip of the seal slide over the crank..
Old 20th October 2011, 21:35   #5
Tj Hunter
Garage: S1kRR Daily
Sales Feedback: (3)
Thanks for this one! Greatly appreciated!
Tj Hunter is offline   Reply With Quote
The Following User Says Thank You to Tj Hunter For This Useful Post:
vantaam5 (20th October 2011)
Old 20th October 2011, 21:40   #6
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Those look like new chains? Any issues just changing chains or do all the sprockets have to be changed also?
Sailor24 is offline   Reply With Quote
Old 20th October 2011, 21:44   #7
vantaam5
vantaam5's Avatar
I always replace the chains.
Even a Duplex chain stretches over time and very rarely the chains between the cams break.
So I prefer playing safe for another 150k engine life..
The sprockets have usually no wear to speak of...
Old 20th October 2011, 21:48   #8
Sailor24
Sailor24's Avatar
Good to know I was thinking I wanted to change the chains just to be safe but was concerned at the $ of the sprockets.
Old 20th October 2011, 21:53   #9
jamiepeers
jamiepeers's Avatar
Garage: E39 M5 Carbon Black
Raikku. Can all of the above be done from topside or do you work underneath for any period at all?
This winter once the beast is asleep i was really considering the cam timing and changing of vanos diaphragm springs, but wondered how many hours extra it would set me back to check and replace the chain guides also?
Input appreciated as always
Jamie
jamiepeers is online now   Reply With Quote
Old 20th October 2011, 22:17   #10
vantaam5
vantaam5's Avatar
Jamie,
there is not so much work from underneath,only dropping the lower oil pan and draining the coolant.
You have to remove the upper chain covers anyway to change the diaphragm springs,then you see what conditions the chain guides are.
Is quite a bit work involved to change the chain guides...
Timing Chain Guide Removal mondeoman E39 M5 and E52 Z8 Discussion 121 31st August 2013 17:01
Pics of chain guide failure mamsterla E39 M5 and E52 Z8 Discussion 72 28th December 2011 07:52
Could this be the chain guide issue? desmotesta E39 M5 and E52 Z8 Discussion 0 29th September 2011 23:04
Broken timing chain guide... phillym5 E39 M5 and E52 Z8 Discussion 2 22nd November 2006 06:19
Introduction... And who's done guide rails for the timing chain? S38Junkie E28 M5 Discussion 0 23rd December 2003 21:31
