S62 Rod Bearing Failure Pictures - Page 5 - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 20th October 2011, 20:30   #41
mister2d
mister2d's Avatar
Garage: Silver E39 M5
Originally Posted by vantaam5 View Post
Yep,the first link...
For the statistics:
I did so far about 25-30 S62 rod bearings as PM,part of rebuild,....
On ALL engines some(usually all) upper bearing halves were worn.
Mileages between 100-170k miles.
Some of them only TWS,some of them other oils.
It is ALWAYS the same wear pattern.
This is why I am a strong believer in PM regarding these parts,as they are the only thing that takes out an S62 completely.
What about running prolonged periods of running in low oil level situations? Do you think that could have contributed to this instance? Or would you say, just poor oil circulation?
mister2d is offline   Reply With Quote
Old 20th October 2011, 20:30   #42
2010Rph
Garage: 530i
Originally Posted by JohnAnthony View Post
I wish someone could give a straight answer...
+1
while I know the S62 is more powerful, has higher compression, rev limiter etc as compared to the M62, it also comes from the factory with a "better" oiling system so those aspects of the S62 should not account for the higher bearing failure rate in S62s compared to the M62.
I still think getting to the bottom of the cause and finding a potential solution is better than pro-active bearing replacement.
2010Rph is online now   Reply With Quote
Old 20th October 2011, 20:45   #43
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Originally Posted by 2010Rph View Post
+1
I think I gave the answer why they wear the bearings....
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following User Says Thank You to vantaam5 For This Useful Post:
Mike S. (21st October 2011)
Old 20th October 2011, 20:47   #44
OVERKILL
OVERKILL's Avatar
Garage: 2001 E39 M5 LeMans Blue
You stated that under high lateral loads that oil pressure dropped very low. Obviously there must be a reason for that. So what is it?
01 LeMans Blue M5
02 Ford Expedition EB
OVERKILL is online now   Reply With Quote
Old 20th October 2011, 20:52   #45
vantaam5
vantaam5's Avatar
It is the design of the oil pans as well as the pick up of the pump.
The oil starts to foam under certain conditions.
So instead of installing an expensive dry-sump system on every S62,I rather change the bearings every 100k or so.
Old 20th October 2011, 20:55   #46
OVERKILL
OVERKILL's Avatar
Would be nice to see an in-pan video of this happening. So you are saying that the oil pressure reduction is a direct result of the oil foaming? Would an oil that is more resistant to foaming then help to prevent the issue from occurring?
And what is the difference here then with the S62 in the Z8 that doesn't have this problem?
I'd rather not have to change my bearings at all I guess is what I'm getting at. So I think finding a solution that makes that a reality would be to the benefit of everybody here.
Old 20th October 2011, 20:58   #47
vantaam5
vantaam5's Avatar
Oil type does not really make that much difference.
Z8 are barely driven to higher mileages,hence no real issues.
The only way is a dry-sump system.
Forget it and change the bearings.
Old 20th October 2011, 21:04   #48
OVERKILL
OVERKILL's Avatar
Doesn't the Z8 have a different pan setup?
Forgetting it and just swapping out the bearings is simply acknowledging the failure model and doing nothing to fix it IMHO. Like swapping out GM LIM gaskets for the same style that came in there rather than using the "updated" ones to fix the issue. Except in this case, nobody appears to have come up with a modification to the factory oil pan setup to fix the issue as of yet. I'm sure there is the ability to create a "fix" without having to do a dry-sump. Though obviously a dry-sump is a nice "upgrade" in of itself.
I'm sure I'm far from the only M5 owner on this site who has a problem with changing out rod bearings as a "preventative maintenance" item.
Old 20th October 2011, 21:13   #49
2010Rph
Garage: 530i
Hint the dry sump system comment was not a serious one hence the "stage 10" reference
That said replacing engine bearings every 100k miles, considering some engines have spun them well under 100K miles is not necessarily an easy and inexpensive of a task.
Old 20th October 2011, 21:14   #50
vantaam5
vantaam5's Avatar
The problem already starts in the upper oil pan,which is on both cars the same.
If you ever take apart an upper oil pan,you will see there is no way to modify it sufficient.
And I should know,as I do trouble shooting issues like that for my living in the automotive industry.
For all the guys that refuse to change them,it is your own decision.
But don't start whining when you have a hole in the block..
This is my opinion and my experience with the S62.
I highly doubt you find many guys in the world who repair,rebuild and modify more of these engines than I do.....
Rod Bearing Failure Preventative Maintenance Sailor24 E39 M5 and E52 Z8 Discussion 84 30th June 2012 08:40
Rod bearing clearance S62 anyone? vantaam5 E39 M5 and E52 Z8 Discussion 6 8th November 2009 12:29
S62 Rod bearing torque budge96 E39 M5 and E52 Z8 Discussion 6 1st September 2009 20:44
Rod bearing failure repair? Still buy car? timmay77 E39 M5 and E52 Z8 Discussion 15 23rd December 2008 04:48
Connecting rod bearing failure CTW E39 M5 and E52 Z8 Discussion 13 22nd January 2008 04:26
