Driver's Outside Door Handle Removal - BMW M5 Forum and M6 Forums
post #1 of 7 Old 5th October 2011, 07:38 PM Thread Starter
gzig5
My outside door handle has gone wonky. It acts like the hinge pin has slipped out of one side. When you pull on the handle it rotates at an angle instead of parallel to the door. I found the TIS section and think I have deciphered how to engage the retaining tab, and hopefully pull it out of the door. Does anyone have a picture of the two tools referenced, 51 3 201 and 51 3 201? 201 looks like it has a little hook on the end, and 203 looks like it might be a bent screwdriver/pry-bar maybe 4mm diameter?
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is offline
post #2 of 7 Old 6th October 2011, 04:06 PM
chowdah
Super Moderator
chowdah is offline
post #4 of 7 Old 6th October 2011, 07:55 PM Thread Starter
gzig5
Handle is out, did it after dinner last night. I don't see how this could be done through that tiny access hole in the end of the door. I ended up pulling the door panel off in order to access the retaining tab with my hooked pick and used a screw driver through the portal to engage the tab. Once that was done, the handle came out quite easily. Bad news is that the handle part you lift is completely broken. Good news is that I was able to piece it back together with epoxy and sheet metal. Hopefully it will hold long enough to get a replacement, if I can get it back in. So, a few more questions....
1. Was Carbon Black color only available on the M5? I'd like to find a used handle if possible.
2. When I took the door card off and the airbag, I did not disconnect the battery. Probably not a good idea, but I didn't consider it at the time. Is it really a concern? Do I need to disconnect the battery while messing with this thing?
While it is all apart I will see about fixing my rattling window mechanism, as well.
_____________
Evolve Tune
Dinan Rear Sway Bar
E60 545 SSK
gzig5 is offline
post #5 of 7 Old 6th October 2011, 08:58 PM
nerio02
nerio02's Avatar
i wouldnt mess with that airbag when the power is on though, iff it goes off your in for a special surprise. (not that it would go off like that but better safe then sorry)
take off the powerlead from the battery next time mate, its 2min work.
you dont want too have this happen too your face. this vid is so epic
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
anyway hope you got the doorhandle fixed for a while,
with kind regardes
nerio02/dominique
nerio02 is offline
post #6 of 7 Old 6th October 2011, 09:13 PM
CarbonCopy
CarbonCopy's Avatar
...yes, I did a search recently and could not find carbonblack as a color for the 540i as example (that model had an orient blue which looked similar but "bluer") so I think it is a M5 or M3 color only.
CarbonCopy is offline
post #7 of 7 Old 6th October 2011, 09:51 PM Thread Starter
gzig5
Yeah..... I think I'll take the golf clubs out of the trunk so I can get to the battery.
Man, that had to hurt.
The repair looks like it is going to be pretty strong. Have to wait for silicone holding the wind barrier in place to dry and then to put it back in.
Edit..
One more question...Does anyone know if the handle part you pull on is the same for the front and rear door on each side? So I might be able to use the handle from a driver side rear door?
_____________
Evolve Tune
Dinan Rear Sway Bar
E60 545 SSK
gzig5 is offline
Hand brake handle removal kbone24 E39 M5 and E52 Z8 Discussion 21 14th May 2014 07:29 PM
Help! Door Leaks from Window and Door Handle MMT51 E39 M5 and E52 Z8 Discussion 1 24th November 2010 10:39 PM
Ebrake handle removal m5moving E39 M5 and E52 Z8 Discussion 23 27th July 2010 04:06 AM
Anyone done a driver's exterior door handle? Need help today (Sunday) Resinears E39 M5 and E52 Z8 Discussion 7 27th June 2010 09:48 PM
Parking Brake Handle Removal? XrayMD E39 M5 and E52 Z8 Discussion 18 31st December 2002 05:43 AM
