Powerflex Thrust Arm rubbing issues - BMW M5 Forum and M6 Forums
Old 29th September 2011, 02:24   #1
NousDefions
Garage: 2003 M5 Sterling Gray
So, a few months ago I installed both lower and upper control arm Powerflex bushings and have been pretty happy with them, except for one huge issue. The thrust arm bushing is rubbing the sway bar mount, specifically the washer for the bushing. It's pretty much in constant contact and during hard stopping and turning it makes a nasty noise, like a big clunk.
I haven't heard of anybody else having this problem. What am I doing wrong? I posted some pictures for reference so you can see the contact I'm talking about.
NousDefions is offline   Reply With Quote
Old 29th September 2011, 03:07   #2
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
I'd love to help you, but I was unable to get both metal washers in place. I'm not 100% sure, but I'd bet that's the side I left mine off of hence no rubbing. You could probably (pretty safely) grind down some of the washer and outer rubber edge there to make a little gap. I only have one washer per side so you'd still be way ahead of me. 20k miles on these without issues too.
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is online now   Reply With Quote
Old 29th September 2011, 03:52   #3
NousDefions
I think that's what I'll do. Grind down all the way around at an angle, perhaps a 1/2" of material. It's just strange that nobody else seems to have the same issues, and I installed it properly. My mechanic bad-mouthed the product when he saw them (I had him do the rear ball joints, because it was cheaper to pay him than buy the darned tool).
Old 29th September 2011, 03:57   #4
gixxeridaz
gixxeridaz's Avatar
Garage: e39 M5 black
no issues with myn?
gixxeridaz is offline   Reply With Quote
Old 4th October 2011, 02:32   #5
NousDefions
Update:
I got the local machine shop to take the washers down by about 3/8's of an inch, and bevel the swaybar side of the bushing to meet the washer.
Success! No more clunking under braking or turning. Rides a lot smoother than before, too. Not sure why they don't just make them this way in the first place.
Old 4th October 2011, 06:35   #6
TMcNasty
TMcNasty's Avatar
Im not 100% sure but I think these fit perfectly in a non-M E39. Thinner swaybar? But I agree...they should tweak it for the M so we don't have to tinker with them.
Old 4th October 2011, 07:02   #7
NousDefions
I don't know if the welded on swaybar mount is thicker in the M cars or not.
Unlike some others here (including you), I have no issues getting the washers in. I'm very happy they work now, though. The car drives the way it was supposed to. I was going to be angry if I had to go back to OEM bushings because I couldn't get the Powerflex to work.
Powerflex Thrust Arm Bushings ablake211 E39 M5 and E52 Z8 Discussion 11 21st December 2009 20:12
For Sale Powerflex Control Arm & Thrust Arm Bushings E39 M5 Racerxjling Parts / Other For Sale or Wanted 2 20th May 2009 21:17
powerflex thrust bushings review lsuslu E39 M5 and E52 Z8 Discussion 2 21st March 2009 21:46
Thrust Arm Bearings--X5 or Powerflex drabe E39 M5 and E52 Z8 Discussion 5 28th March 2006 19:22
PowerFlex Thrust Arm bushes for E34 vchachanidze E34 M5 Discussion 6 19th August 2005 13:16
