Quixx Scratch Remover Problem - BMW M5 Forum and M6 Forums
Old 29th September 2011, 02:21   #1
dkbeast
Garage: 2001 M5 Titanium Silver
Somebody keyed up my trunk lid pretty bad yesterday so I decided to try out the Quixx scratch remover kit as it got pretty good reviews almost everywhere I checked. It worked fine for the light scratches but after putting some elbow grease into a deeper scratch I ran into a problem. The area I was buffing began to become discolored (I have a titanium silver M5 and it started turning the paint greyish). Anyways, I kept going and finally it began clearing up as well as fixed the scratch. The problem now is that there is a ring of discoloration around the area as the paint only clears up after vigorous buffing. Is there anyway to remove this discoloration without have to basically buff the entire trunk lid until my arms fall off?
Here's a pic of the affected area https://lh5.googleusercontent.com/-d...928_164810.jpg
dkbeast is offline   Reply With Quote
Old 29th September 2011, 02:25   #2
Jfreak
Garage: Orient blue E39
Looks like you went through the clearcoat to me... I'm no expert tho.
Jfreak is online now   Reply With Quote
Old 29th September 2011, 03:59   #3
meepmeep
Garage: 2002 M5, LeMans Blue
What he said.
meepmeep is offline   Reply With Quote
Old 29th September 2011, 04:01   #4
gixxeridaz
gixxeridaz's Avatar
Garage: e39 M5 black
cant see the pic
gixxeridaz is offline   Reply With Quote
Old 29th September 2011, 04:03   #5
gixxeridaz
gixxeridaz's Avatar
meguiars 105 n 205 will help if thats just wet sanding scratch marks cant really see to well based on the image
Old 29th September 2011, 04:04   #6
dkbeast
****, anyway to fix it without repainting?
image rehosted herehttp://i.imgur.com/mPUvH.jpg
Old 29th September 2011, 04:06   #7
gixxeridaz
gixxeridaz's Avatar
if its just wet sanding scratches and not thru the paint the 105 n 205 w a porter cable will remove this
Old 29th September 2011, 04:14   #8
DubSport
Garage: E39 M5 Alpine White, E36 M3 Fern Green
Looks like it's through the clear coat. Get a touch up kit from BMW and get the whole area if u want to do it on the cheap. U can wet sand your touch up after to get rid of the brush strokes, then use the clear to go over top, then we sand once more, then polish.
Sucks man
DubSport is offline   Reply With Quote
Old 29th September 2011, 04:19   #9
dkbeast
pretty sure it's not wet sanding scratches because of the discoloration around the area but i'll give it a try
Old 29th September 2011, 04:27   #10
dkbeast
yea, I'm most likely going to have the entire trunk lid repainted then; there are still a bunch of deep scratches from being keyed. Does anyone have an idea of how much it's going to cost.
Best scratch remover??? "S62" E39 M5 and E52 Z8 Discussion 11 28th January 2011 04:29
Heads up: QUIXX scratch remover is GREAT! NJ.M5 E39 M5 and E52 Z8 Discussion 6 1st September 2009 06:14
Should I use a swirl remover? benfmd E60 M5 and E61 M5 Touring Discussion 1 31st May 2008 09:32
Best deep scratch remover? psalm23and24 E60 M5 and E61 M5 Touring Discussion 11 3rd July 2006 20:56
Dust remover timhur E39 M5 and E52 Z8 Discussion 4 26th February 2006 04:29
