• Latest threads
    • Custom feed
      • Updates
        Old 1st July 2002, 09:10   #1 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        Some new moving shots!
        To start things off....
        A shot of my CLEAN wheels with something red sticking out!
        And the prerequiste moving shot!
        A nice vantage shot of my at speed!
        I was going a little too fast. I overshot the picture!
        Jason
        '05 Range Rover w/mods
        '05 K1200S w/mods
        '07 997TT w/mods
        atomic80 is offline
        Old 1st July 2002, 09:18   #2 (permalink)
        GreekM5
        GreekM5's Avatar
        Send a message via AIM to GreekM5
        Look great Jason!
        2002 M5 Titanium silver/Luxury black/Burr walnut
        GreekM5 is offline
        Old 1st July 2002, 09:18   #3 (permalink)
        EBMCS03
        EBMCS03's Avatar
        Send a message via ICQ to EBMCS03 Send a message via AIM to EBMCS03 Send a message via MSN to EBMCS03 Send a message via Yahoo to EBMCS03
        Hey check your eyes.. teh fist pic isnt moving... man... I think you're not suited to drive... I think you should donate your car to me.
        Next: Interlagoes Blue E60 M5
        EBMCS03 is offline
        Old 1st July 2002, 09:24   #4 (permalink)
        livenupe
        livenupe's Avatar
        Man, those fog lights look pretty white. Those aren't stock are they?
        reggie c.
        Los Angeles, CA
        Current = 2004 40th Anniversary Porsche 911
        Past = 2000 M5
        livenupe is offline
        Old 1st July 2002, 09:34   #5 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        Nope..they're HID foglights.
        UCSDxB0i: no comment.
        Jason
        '05 K1200S w/mods
        '07 997TT w/mods
        atomic80 is offline
        Old 1st July 2002, 10:32   #6 (permalink)
        livenupe
        livenupe's Avatar
        If you don't mind me asking, how much did it cost to install them? I know there's been a lot posted on this topic. But for some reason, I haven't really been that interested until now.
        reggie c.
        Los Angeles, CA
        Past = 2000 M5
        livenupe is offline
        Old 1st July 2002, 10:45   #7 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        They didn't cost anything to install. I installed them myself with information that I'd gained from this very board.
        Parts however were the expensive part. I paid about $600 for the parts. I've heard that parts could be had for considerably cheaper nowadays. I can give you more information if you'd like.
        Jason
        '05 K1200S w/mods
        '07 997TT w/mods
        atomic80 is offline
        Old 1st July 2002, 10:54   #8 (permalink)
        livenupe
        livenupe's Avatar
        Please share
        reggie c.
        Los Angeles, CA
        Past = 2000 M5
        livenupe is offline
        Old 1st July 2002, 17:20   #9 (permalink)
        farcknorf
        Do you have a higher-res version of the 2nd picture ?
        farcknorf is offline
        Old 1st July 2002, 17:51   #10 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        It's an easy upgrade. You'd need to get HID D2S 9006 type bulbs along with the ballast/ignitor units (try to get the ones made by either osram or phillips for the bulbs and phillips for the ballast). It's all plug and play. The hardest part is removing the black plastic housing. There are also a number of ways that you could attach the ballast to the car. I used double sided tape to securely attach the ballast to the inside of my bumper. Works great this way. You'll take the stock plug that comes off the halogen bulbs and plug that in the ballast unit and from there you'd plug the connector to the HID bulb before carefully putting it back in the foglight housing. You'd probably want to use a plastic flat screwdriver type on the outer edge to undo the tab that locks the housing in place. Do NOT touch the screw that you see in the little hole on the black foglight housing. That's to adjust the alignment. Also, do NOT touch the glass part of the HID bulbs. The oil on your hand will burn at the high temperatures that the HID bulbs put out and weaken the glass.
        The light disperal pattern after the upgrade is not as defined as the lowbeams but it does put out a LOT more light filling in the area immediatley in front of your car as well as the far end just slightly above the lowbeam cutoff line. Really works well! I'd do the upgrade again if given the chance to.
        Some places that you can order the kit from are hids4less.com or autolamps-online.com. You can either choose to go with stage 1 or stage 2 bulbs. The difference between the two is the color temperature with the former being slightly brighter but noticably more greenish. The latter is a bit more purple/blue.
        Take a look at these pictures, especially at the lowbeams.
        Stage 1 OEM 4300K bulbs:
        Stage 2 6000K bulbs:
        Prices as I said earlier range from $500 - $650 for the kit depending on if you shop around. The most important part is that you make sure that the connections are secure.
        Let me know if you have any other questions.
        farcknorf: Yes, I do have higher-rez images. Email me. jgtang@mindspring.com to let me know what resolution you'd like them in.
        Jason
        '05 K1200S w/mods
        '07 997TT w/mods
        atomic80 is offline
        Old 1st July 2002, 18:40   #11 (permalink)
        Diamond Dave
        Diamond Dave's Avatar
        Jason,
        Looks like you have wheel locks. If I'm correct, where did you get them?
        Also, nice valve stem caps!!!
        Thanks,
        DWP
        Diamond Dave is offline
        Old 1st July 2002, 18:46   #12 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
