Old 30th June 2002, 23:05   #1
Apples
Apples's Avatar
Garage: 2000 M5 Blue
Used the G-Tec today.... 1st 1/4 mile run got 13.7 @116mph...
Well after getting some new fuses, as the other one blew l thought l may as well give the G Tec a wirl.
Not a good day for testing, as it was bloody hot and humid don't ya love Florida, but it's my virgin test so who cares.
I first did the HP test and only managed to find about 350hp????,so l don't know whats up with that reading as l'm 100% sure it was set right or close enough.....4200lbs and G Tec set flat at 00 reading.
I only did a coulple of HP runs as l didn't want to fry the clutch.
I then did the 1/4 mile test and first up l got a 13.7 sec pass @ 116mph
good trap speed but l must have been a bit slow in the lower RPM's in first???
I tried a few more 1/4 mile times but l think it was getting a bit too hot for her and the extra ones were around 110mph and around 14.5 sec.
So is that trap speed 116 mph good...l think it's good for the conditions ???? and the 13.7 sec about normal??? Whatya think 1/4 mile experts.
I look forward to trying again later in the year with better conditions.
APPLES
2000 M5 LeMans blue
Headers/cats/exhaust/KW suspension/sway bars/UUC shifter/UUC clutch/BBS LM 19's.
2003 M5...actually MIB's (master yoda)
2004 Lamborghini Gallardo Pearl Yellow. HRE 840r 19's front 20's rear
2006 Ford GT Heritage blue
www.m5ute.com
Apples is offline
Old 30th June 2002, 23:39   #2
Gustav
Administrator
Gustav's Avatar
For a G Tech it definetly should be low 13s. I got 13,3-13.4 on my M3 3,2 with 321 HP. Although it was very cold then.
Best timeslip here is RaMsEs with a time of 12,9 or so I think.
Gustav is offline
Old 1st July 2002, 01:46   #3
2001's X5/Z8
2001's X5/Z8's Avatar
Garage: BLACK 2001 X5 4.4
Send a message via AIM to 2001's X5/Z8
Apples,
Like I told you earlier, 116mph is pretty good, I think if the weather is right (40-50degrees and low humidity) you might be able to get 117 or 118 out of her. As far as time goes, I think in those ideal condtions, with traps speeds like that, you should be able to get low 12's out of her (good traction a must). Mid 12's should come with ease, if you do a small burnout on your street tires, just heat em' up a little.....
I tried to organize a track night a while back, but it fell through. When the winter comes around we should put a bunch of nuts together and storm the drag strip.....It would be pretty cool to compare cars in real life driving conditions, not just on a dyno.........
2001 Z8 BLACK/RED K&N FILTERS POWERCHIP ECU UPGRADE (Thanks Apples)
365RWHP
350RWTQ
Sold, please take care of her
2001 X5 4.4 SPORT BLACK/BLACK K&N FILTER.
M3 Come.. M3 Go
2001's X5/Z8 is offline
Old 1st July 2002, 04:36   #4
Vadim-SoCal
Vadim-SoCal's Avatar
Garage: '02 C32 AMG Silver/'01 Black M5 incoming
Apples:
116 mph sounds very good. But be carefull, G-tech are known to be imprecise. Personally, I recommend and use AP22 from www.race-technology.com, it is more consistent and gives you more information.
By the way if you want to convert your MPH into HP use following formula:
HP = ((MPH x 0.00426)*3) x Weight
so in your case 116 x 0.00426 = 0.4942, cubed it is 0.121 times 4200, your HP is 507 at the flywheel.
Judging from your dyno of 408HP at the wheels, your flywheel HP at 15% loss should be 480HP.
Pretty close.
Vadim-SoCal is offline
Old 1st July 2002, 06:40   #5
IloveM5s
Garage: hotwheels
The GTech finishing speed, and a track trap speed are two different things. At a track, you pass by two markers (spced apart obviouslly) at the end of the track, and based on the time taken to cover this distance, your trap speed is calculated. So at the track, it is not the speed you're finishing the 1/4 mile with, but rather an average of the last X ft. (I forgot the exact distance).. The Gtech, calculates your speed once at the end of the run, so it will obviouslly be a tad higher..
gee I hope that made at least a little sense
IloveM5s is offline
Old 1st July 2002, 06:44   #6
IloveM5s
Garage: hotwheels
There's absolutely no benefit in doing a burn out in street radials. Slicks, yes, but slicks are made of an entirely different compound, in which a burnout is necessary to bring the sticky residue (I'm not up on the lingo) to the tires surface..
IloveM5s is offline
Old 1st July 2002, 06:51   #7
2001's X5/Z8
I thouroughly disagree, and so do the laws of physics.
The higher the tempature of any piece rubber, the softer it becomes. Therefore, doing a burnout on ANY type of tire increases that tires ability to maintain traction....That is an irrefutable and undisputable fact
Old 1st July 2002, 07:32   #8
Ty
Garage: Buying My First!
I'm lost, the last time i read the forums at this site was about october of 2001. I remember Apples talking about picking a license plate for his new Nowack M5. Did something go wrong dude I thought you were going to have like 517 hp at the flyweel Could someone fill me in
Ty is offline
Old 1st July 2002, 07:50   #9
alpywhite
alpywhite's Avatar
Garage: 2006 BMW M5, Silverstone
Great trap speed so far Apples.
alpywhite
2001 Z8 - Black/Black
2006 M5 - Silverstone/Silverstone/Aluminum
2003 M5 - Titanium/Black/Aluminum
alpywhite is offline
Old 1st July 2002, 08:17   #10
tfung
tfung's Avatar
trap speed sounds good, but the time may be a bit low... but then again, I wouldn't trust g-techs for they are known to be inaccurate...
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
OT : How to shave 2 seconds off your 1/4 mile run for $0!! Matrox Off Topic Forum 3 18th April 2003 18:08
1/4 mile time for SMGII M3? NA1 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 7 5th June 2002 00:10
How fast does the M5 do the 1/8 mile in? EBMCS03 E39 M5 and E52 Z8 Discussion 17 18th July 2001 06:09
I saw an Imola Red ///M5 run a 13.01 1/4 mile!! jsh/AZ E39 M5 and E52 Z8 Discussion 16 4th February 2001 23:56
Page generated in 0.25869 seconds with 11 queries
