DSC Light Permenantly ON. ABS Fine. - BMW M5 Forum and M6 Forums
Old 8th September 2011, 15:00   #1
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
Hi guys,
When I started the car this morning the DSC light did not go of as it normally does. Pressing the DSC button does nothing. There are NO other warning lights.
I tried afew things on the way to work and the DSC is definitely off, as my sideways exit from the Tesco's roundabout proved .
The ABS however appeas to be fine, as I actually didn't crash into the back of the Saab 93 that was trying to beat me to work, and then messed up his M4/A4 exit strategy just by West London Audi.
I'll plug ABO into INPA when I get home later and get some codes off her, but I wondered if anyone had any previous experience or just thoughts on the matter? I did some searching and it seems that a dodgy DSC unit causes the ABS light to come on as well, so I'm hoping it's not that.
I'll post again when I've got the INPA results but feel free to chip in if you have an idea how much pain my wallet is about to go through!
Barney.
100%Cocoa is offline   Reply With Quote
Old 8th September 2011, 15:21   #2
cab
cab's Avatar
Garage: 2002 LMB/Caramel (sold)
It could be one of the wheel sensors - you can check that with INPA (it will show you all 4 sensors and the codes). However, on the wife's 530i (identical symptoms) it was the ABS module which I had rebuilt for $185 USD + shipping (took a week). Several places on E-bay, etc. Tons of threads on the BMW ABS module on Bimmerforums.com I used BBA Remanufacturing (recommended on the other board) who actually may have a UK location.
cab is offline   Reply With Quote
Old 8th September 2011, 15:25   #3
yellowgixxer
yellowgixxer's Avatar
Garage: E39 M5 in Le Mans Blue
Hi Barney,
I think that if a wheel sensor goes u/s then it takes the ABS out as well. Certainly did on mine. Do you have anything else weird happening? Mileometer not going up, for example? Because perhaps you're just good at modulating your brakes and the ABS actually isn't working at all?
I'm going to hope for that because it's the cheapest option. Other than a blown fuse, of course. Is there a DSC fuse?
SB
yellowgixxer is online now   Reply With Quote
Old 8th September 2011, 15:46   #4
Strike
Strike's Avatar
Garage: 2002 Jet Black
Check the brake light microswitch on the brake pedal. Sometimes it comes loose and can cause that. Happened to mine. Don't know how it happened but checked it, snapped it into place, all was well again.
2002 Jet Black/Imola Red Sport
Dinan Stage I Software
K&N Filters - Brake Ducts
K40 Undetectable
AXXIS ULT pads
Black/White CF Roundels
Body Color Grills
Greyscale ///M Logos
Smoked Tails
30% Tint
Intravee II
Strike is offline   Reply With Quote
Old 8th September 2011, 16:14   #5
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Different DSC unit on this car ,but it is all I have. My sisters 3 wagon had DSC only light and it was a steering angle sensor. I forget exactly what the reset procedure was but I think it was as simple as lock to lock steering wheel rotation. The other thing people were giving me as a possibility was the G force sensor. Never got that far because the steering had the code. Don't think you will have a problem figuring it out once you plug it in.
Sailor24 is offline   Reply With Quote
Old 8th September 2011, 17:11   #6
Lunker325
Lunker325's Avatar
Garage: 02 Sterling Grey/Silverstone
Sales Feedback: (7)
Also check your brake fluid level. Happened to me a while ago, topped off the brake fluid, been fine ever since.
12th Gen Bluetooth * Intravee II, Alpine KCA-420i, Alpine TUA-T550 HD Radio * Alpine SPX-17 REF 6.5" F & SPS-500 5.25" R Speakers * OEM Sirius * JL Audio XD600/6 6 Channel Amp(DSP Removed) * Audio Control DQXS * Custom ED Sub Box with 2 x SQ10's * Infinity 611a Sub Amp * Dinan Exhaust * Powerchip MAF-less tune * E60 SSK * ZHP Illuminated Shift Knob * Jet Black Rear Valance * Headlight Armor light smoke tinted tails * 18x10 SSR GT3 wheels F&R * Euro Hella Headlights * Predator Ice AE's with 5W Luxeon K2 Star and 1000 mA PowerPuck Driver * Seasonal OEM Heated Steering Wheel Retrofit * F & R Illuminated Door Sills * Ultimate Pedals * Full Interior LED's * 6000K HID Fogs * MKIV Nav * Passport 9500ci * Griots Italian Air Horn * Slimm's leather tilting armrest * Dinan Stage 1 Suspension *...
Lunker325 is offline   Reply With Quote
Old 8th September 2011, 18:42   #7
100%Cocoa
100%Cocoa's Avatar
Thanks fro the replies guys. I'll be off home in a mo so we'll see what INPA shows up. Fingers crossed it's a nice simple one! I'll try the ABS again too just to be sure too.
Old 8th September 2011, 18:44   #8
lothar
Garage: 2003 Ti. Silver M5
I had a similar issue, but the light would intermittently come on (car usually started without it lit up). I had a number of steering angle sensor faults. Cleared the errors, recalibrated the sensor and it hasn't been back since.
lothar is offline   Reply With Quote
Old 8th September 2011, 19:12   #9
ACHTUNGM5
ACHTUNGM5's Avatar
Garage: 2001 M5 TITANIUM SILVER
brake fluid
ACHTUNGM5 is online now   Reply With Quote
Old 8th September 2011, 20:53   #10
100%Cocoa
100%Cocoa's Avatar
So...... I've spent a while browsing my modules and I think we have an answer. I'll just attach the pics and let you see for yourself.....
A few points first:
1) The car was completely normal on the way home. No lights and all functions seemed ok. Don't you just love intermittent faults
2) The fault seems obvious when you see the error code screen grabs......
3) When I read the analogue readings, the DSC light, Brake Pad Light & ABS light all came on and the DSC button did nothing. They went off after a while though and everything's fine again. Has anyone else got experience of this?
4) I included a bunch of other pics as I thought those without INPA would be curious to see just a tiny snippet of the wealth of information it can give you!
Now the pics -
No hot air from blower, cold air works fine, fan works fine. amessimon E39 M5 and E52 Z8 Discussion 14 19th October 2011 20:31
SES Light (But Runs Fine) captain_anonymous_2003 E39 M5 and E52 Z8 Discussion 26 15th December 2009 22:38
fine FINE! I'll post pics of my M5! w00t!! *formal introduction* btmlinedan E39 M5 and E52 Z8 Discussion 26 28th August 2009 17:22
***One Fine Day*** M-Crazy Owners Gallery 4 31st October 2007 02:20
SES light but car runs fine?? jordantii E39 M5 and E52 Z8 Discussion 7 2nd August 2005 22:24
