• Latest threads
    • Custom feed
      • Updates
        Old 30th June 2002, 04:28   #1 (permalink)
        Teutonaddict
        Teutonaddict's Avatar
        NE1 w/ 1st-hand experience w/ Sachs Perf Clutch?
        Harold C? 540is?
        Still waiting to find out from a board member if the Sachs Performance Clutch is or is not a true bolt-on replacement. My local speed shop said their distributor (SSF) thought the install took some machining of the dual-mass flywheel.
        Anyone find otherwise? Thanks for the info!
        BOTH SOLD!!
        '00 Carbon Black/Black All-Leather/Sportive
        #101421
        Teutonaddict is offline
        Old 16th July 2002, 16:41   #2 (permalink)
        HaroldC
        HaroldC's Avatar
        Teuton,
        Sorry for the delay, i've been out of town for the past few weeks. The word from Sachs NA is that there should be no machining and that it is a direct bolt on replacement.
        I am going a different route - I am going to install a custom aluminum flywheel built by VAC motorsports. The lightweight flywheel weighs only 11 pounds, versus the 38 lbs for the stock dual-mass unit. There is going to be some flywheel chatter at idle, but I am willing to make that trade off for quicker response. Since I track my car, I would like to be able to heel-toe quicker, which is not possible with the heavy dual-mass flywheel.
        If anyone else is interested www.vacmotorsports.com
        Check them out
        Harold
        '07 M5 Silverstone II (RIP)
        '03 M3 Titanium Silver
        '08 X5 4.8 Space Gray
        HaroldC is offline
        Old 16th July 2002, 17:25   #3 (permalink)
        Teutonaddict
        Thanks, Harold!
        I hear what Sachs says about "should be a direct bolt-on," but people out there installing them say otherwise.
        I also learned in the interim that the M5 stock clutch is made by LuK, Inc. and not Sachs. I'm still waiting on a call from LuK regarding any aftermarket solutions they have....
        As for my situation, I finally got BMW to agree to assist in my clutch replacement, after MUCH wrangling. They're going to split the costs with me as a goodwill gesture, unless they find a component failure, at which point it would all be covered under warranty.
        Your lightweight flywheel option sounds interesting. Mind if I ask roughly what it costs to have one custom made? PM me if you'd rather.
        Thanks for getting back to me!
        -Dave
        BOTH SOLD!!
        #101421
        Forum Jump
        Im back! -- with a clutch story.... 1C00lVC E39 M5 and E52 Z8 Discussion 5 9th June 2003 23:33
        Proper way to break in the Sachs clutch? XrayMD E39 M5 and E52 Z8 Discussion 18 12th October 2002 05:55
        Sachs is NOT the OEManufacturer of our E39 M5 clutch!! Teutonaddict E39 M5 and E52 Z8 Discussion 14 2nd July 2002 19:53
        Any updates on the sachs clutch FamilyM5 E39 M5 and E52 Z8 Discussion 7 28th June 2002 18:56
        clutch smell rennen E39 M5 and E52 Z8 Discussion 16 12th December 2001 15:04
        Page generated in 0.18133 seconds with 11 queries
