12th September 2011, 07:19
#31
2003 M5 matte black
Originally Posted by agreenrhino
The primary reason they are used in European racing is because there is not a lot of QUALITY options for the late final drives.
-- Brett Anderson KMS - Koala Motorsport Inc
Fixed....
Mike,the price is not that bad on the Drexler,was more expensive a few years ago.
I think their driveshafts are expensive....but so are GKN Motorsport.
If I have to buy a budget diff for a non-LSD car,I go for a Quaife.
If I need something serious,Drexler it is.
Simple as that.
-rebuild in winter 2011/2012
-"submarine edition",a bit boost and some M5 parts...
