Engine feels like it's "chugging" under load at low rpm. - Page 3 - BMW M5 Forum and M6 Forums
Old 31st August 2011, 16:54   #21
ger
ger's Avatar
Garage: M5 Le Mans Blue
When one of my cam sensors started to go bad I had some strange behaviour at the lower revs. Put in a new one (exh, bank 1 iirc) and it went away, behaving nicely at low revs again.
Get the car scanned, it will probably have a stored code but the engine light will not come on, unless it happens more than a certain number of times.
Hth.
11/2000 M5 Le Mans Blue
My car's thread
ger is offline   Reply With Quote Quick reply to this message
Old 31st August 2011, 16:58   #22
Strike
Strike's Avatar
Garage: 2002 Jet Black
Originally Posted by feeblebob View Post
Mentioned in post 13 above. Do TPS's generally throw a light or a code?
I was exaggerating. I actually mentioned them already on page one. lol. No they don't always. I was having the identical symptoms for awhile with no codes being set at all and I would dodge the problem by staying in a different rpm range. Then it started to occur more frequently at other rpms and finally set a code for throttle potentiometer. Replaced them both. Perfect.
2002 Jet Black/Imola Red Sport
Dinan Stage I Software
K&N Filters - Brake Ducts
K40 Undetectable
AXXIS ULT pads
Black/White CF Roundels
Body Color Grills
Greyscale ///M Logos
Smoked Tails
30% Tint
Intravee II
Strike is offline   Reply With Quote Quick reply to this message
Old 20th October 2011, 17:13   #23
Resinears
Resinears's Avatar
Garage: 2000 M5 LeMans Blue / 1998 540i6 Oxford Green / 2001 Hayabusa
Update
Just an update to make the thread a little more useful for future searchers...
The car finally threw a code (I forget what actual Peake code it was), for the exhaust cam position sensor on bank 2. I replaced that last night, and all is well. No more chugging at low rpm/load. It also seems that the exhaust has less over-run burble when coming off the throttle and listening to the rpms come down. I think it pulls better throughout the rev range as well.
2000 M5
1998 540 with good stuff
2001 Hayabusa!!
2007 KTM Superduke 990
Rav 4 Winter
Resinears is offline   Reply With Quote Quick reply to this message
Old 20th October 2011, 19:07   #24
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
How long in miles did this go on before it finally thru a code? Just food for thought, even though the other three are not throwing codes don't you think they could be downhill too. There is a reason some of us replace the originals at some point with the updated ones.
Sailor24 is offline   Reply With Quote Quick reply to this message
Old 20th October 2011, 19:45   #25
Resinears
Resinears's Avatar
My car has less than 100,000 km. I paid $180 for the sensor from the dealer so I could install it riight away, so I was reluctant to order up 4 as a "just in case". Had the sensor been on the intake side of bank 2, I probably would suggest doing both, but I was thankful that I didn't have to. Access to the exhaust sensor was bad enough for me. As far as your "there is a reason some of us replace the originals at some point with updated ones" statement, I've read differing opinions, and it seems the bank 2 exhaust sensor is more prone to failure than the others. It's not like I replaced one of two MAFs.
Broken "Lower Right Engine Compartment Cover" and "Stabilizer Support" wrecks E39 M5 and E52 Z8 Discussion 10 10th November 2014 16:22
Engine feels like it's "chugging" under load at low rpm. Resinears E39 M5 and E52 Z8 Discussion 2 26th August 2011 22:31
"Engine Malfunction: reduced power!" & "Increased Emissions" OTDoc E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 2nd November 2008 01:15
"Engine Malfunction; Reduced power!" & "Increased Emissions" OTDoc E60 M5 and E61 M5 Touring Discussion 16 9th August 2008 04:25
How Soon is "Soon" in "Service Engine Soon" Warning? Rcl4668 E39 M5 and E52 Z8 Discussion 2 17th January 2003 22:54
